I see what's happening, this is also the source of trouble you are having elsewhere. Use this instead:
ifdef PROJECT
ifndef CSOUND_FILE
PROJECT_SETTINGS_JSON = $(PROJECT_DIR)/settings.json
CURRENT_FILENAME = $(shell cat $(PROJECT_SETTINGS_JSON) 2> /dev/null | tr "," "\n" | grep "fileName.*\.csd\>" | sed 's/.*"fileName"\s*:\s*"\(.*\.csd\>\)"/\1/' )
override CSOUND_FILE = $(PROJECT_DIR)/$(CURRENT_FILENAME)
endif
endif
Swapping to this version of the CustomMakefileTop.in script did repair the trills, but sadly, it does not work as the other one did. When you select a .csd file from the project and hit the "Build & Run" button, the previous script would push the file to the Bela (as if it were in _main.csd) - and was a huge timesaver and workflow improver.
This version does say loading file in the console, but then it reports the following error message:
Building project ...
Build finished
Makefile:153: *** Invalid/empty project. A project needs to have at least one .cpp or .c or .cc or _main.pd or _main.scd or  or run.sh file.  Stop.
Hopefully it is an easy fix.
Dr.B.
Hmm, that's strange, as it works for me.
Can you show me the file list for this project and also the content of the settings.json file in the project folder? This file is hidden normally, but you can show it by going to the IDE settings and enabling "View hidden files", then it should show up among your project files.
    giuliomoro It is very curious. Some of the .csd files do work.
    - you select them
    - they appear in the IDE
    - you edit them there
    - you push the 'Build & Run' icon/button
    - They build and run ! Success.
    Others, like the Generative Haiku.csd or some of the MIDI instruments do not
    - the console reports
    Build finished
    Makefile:153: *** Invalid/empty project. A project needs to have at least one .cpp or .c or .cc or main.pd or main.scd or or run.sh file. Stop.
    AND it is noteworthy, that with 6.15 the following libraries are missing and warnings appear
    Build finished
    Running project ...
    0"060.998| WARNING: [main] duplicate call from main program to xenomai_init() ignored
    0"061.299| WARNING: [main] (xeno-config --no-auto-init disables implicit call)
    0dBFS level = 32768.0
    --Csound version 6.15 (float samples) Oct 15 2020
    [commit: c329d91b2527e96f05ecb47837e2bfd3b68f5be7]
    libsndfile-1.0.27
    realtime mode enabled
    WARNING: [mcould not open library '/usr/lib/csound/plugins-6.0/libfluidOpcodes.so' (libfluidsynth.so.1: cannot open shared object file: No such file or directory)
    WARNING: could not open library '/usr/lib/csound/plugins-6.0/libosc.so' (liblo.so.7: cannot open shared object file: No such file or directory)[m
    [mUnifiedCSD: /root/Bela/projects/Aug2/DSP-Cook-AnalogEcho.csd
    STARTING FILE
    Creating options
    Creating orchestra
    closing tag
    Creating score
    rtmidi: ALSA Raw MIDI module enabled
    Elapsed time at end of orchestra compile: real: 0.044s, CPU: 0.031s
    sorting score ...
    ... done
    Elapsed time at end of score sort: real: 0.047s, CPU: 0.031s
    setting dummy interface
    graphics suppressed, ascii substituted
    orch now loaded
    SECTION 1:
    Initialising spinlock...
    Starting realtime mode queue: 0xb50b9010 thread: 0x12371b0
    I am not sure how you would like me to show you the file list for the project
    - The Project is called Aug2
    - The list of files in the project are:
    main.csd
    ALGO-Aikin-Groovish
    ALGO-McCurdy-Haiku4
    Bela-Trill1.csd
    DSP-Alex-mTog-SubInstruments
    DSP-Cook-Harmoniser.csd
    DSP-Cook-LorenzChorus.csd
    DSP-Cook-mStressonCC.csd
    DSP-Cook-Mutator.csd
    DSP-dB+Hans-mTog-CCmultFX
    DSP-FLOSS-Audio2Control
    DSP-McCurdy-mGrain
    DSP-Pedro-mTog-NLresBank
    DSP-Pedro-mTog-NLstresBank
    DSP-Pedro-mTog-NLStresIncr
    DSP-Siena-mTog-chanGetSetFX.csd
    DSP-Siena-MultiFX_0803
    .csd
    DSP-Victor-mTog-LiveLoop
    MIDI-615toggle.csd
    MIDI-Adam-HansPluck
    MIDI-cntCreate.csd
    MIDI-ctrlPresetV6-ffitch.csd
    MIDI-FM-cc1-8
    MIDI-Gabe-mTog-ccSwitch4.csd
    MIDI-micro-cpstunSwitch.csd
    MIDI-micro-FOF-Bohlen-Pierce.csd
    MIDI-micro-NoisePitch-B-Pierce.csd
    MIDI-MoogVCF
    MIDI-Pedro-mTog-2EventInsts
    MIDI-RCB-sndwarp.csd
    MIDI-Turnon-Event.csd
    MIDI-Turnon-Scoreline.csd
    my_ctrlinits.txt
    my_ctrlpresets.txt
    NL-bob.csd
    NL-lag.csd
    NL-sterrain.csd
    NL-Toot1-RCB.csd
    NL-trighold.csd
    NL-vps.csd
    settings.json
    z-AdrienS.aif
    z-no_fluteC3.wav
    z-OboeScaleS.aif
    z-sp_hamlet.aif
    z-sp_hellorcb.aif
    zCosmoBlur.udo
    zCosmoChorus.udo
    zCosmoFakeGrainer.udo
    zCosmoLowPass.udo
    zCosmoRandDelay.udo
    zCosmoReverb.udo
    zFox.wav
    The contents of the settings.json folder is:
    {"fileName":"settings.json","CLArgs":{"-p":"16","-C":"4","-B":"16","-H":"-6","-N":"1","-G":"1","-M":"0","-D":"0","-A":"0","--pga-gain-left":"10","--pga-gain-right":"10","user":"","make":"","-X":"0","audioExpander":"0","-Y":"","-Z":"","--disable-led":"0"}}
    This file 'MIDI-615toggle.csd' (which requires Version 6.15 to run successfully) - does work with your script.
    - It loads into the IDE and then you hit build and run (without copying to _main and it builds and runs :
    <CsoundSynthesizer>
    <CsOptions>
    -Mhw:1,0,0 -+rtmidi=NULL --daemon -dm0
    </CsOptions>
    <CsInstruments>
    nchnls = 2
    0dbfs = 1
     gicntA cntCreate 1     ; a toggle
     gicntNoteA cntCreate 1 ; ignore note-off message - turn MIDI notes into toggles
     gicntB cntCreate 1
     gicntNoteB cntCreate 1
     gicntC cntCreate 1
     gicntNoteC cntCreate 1
    instr 1
    kkey sensekey
    printk2 kkey
    if (kkey == 97) then  ; ASCII 'a' = 97
     k1 count gicntA
     if k1==0 then
      event "i", 2, 0, -1
     else
      event "d", 2, 0, -1
     endif
    endif
    if (kkey == 115) then  ; ASCII 's' = 115
     k1 count gicntB
     if k1==0 then
      event "i", 3, 0, -1
     else
      event "d", 3, 0, -1
     endif
    endif
    if (kkey == 100) then  ; ASCII 'd' = 100
     k1 count gicntC
     if k1==0 then
      event "i", 4, 0, -1
     else
      event "d", 4, 0, -1
     endif
    endif
    inote notnum
    print  inote
    if (inote == 60) then
     i2 count_i gicntNoteA
     print i2
     if i2==0 then
      event_i "i", 2, 0, -1
     else
      event_i "d", 2, 0, -1
     endif
    endif
    if (inote == 62) then
     i2 count_i gicntNoteB
     print i2
     if i2==0 then
      event_i "i", 3, 0, -1
     else
      event_i "d", 3, 0, -1
     endif
    endif
    if (inote == 64) then
     i2 count_i gicntNoteC
     print i2
     if i2==0 then
      event_i "i", 4, 0, -1
     else
      event_i "d", 4, 0, -1
     endif
    endif
    endin
    instr 2
    kenv linenr .25,.1,.1,.01
    asig oscil kenv, 261.63
    outs asig,asig
    endin
    instr 3
    kenv linenr .25,.05,.1,.01
    asig oscil kenv, 293.665
    outs asig,asig
    endin
    instr 4
    kenv linenr .25,.02,.1,.01
    asig oscil kenv, 329.628
    	outs asig,asig
    endin
    </CsInstruments>
    <CsScore>
    i1 0 z
    </CsScore>
    </CsoundSynthesizer>
    This one (ALGO-Aikin-Groovish) - is the Bela 'Theme Song' in my classes - by Jim Aikin from Keyboard Magazine fame, required you to copy it to _main before it will build and run
    <CsoundSynthesizer>
    <CsOptions>
    -dm0
    </CsOptions>
    <CsInstruments>
    sr = 44100
    ksmps = 16
    nchnls = 2
    0dbfs = 1
    		seed	127
    giSine	ftgen	0, 0, 8192, 10, 1
    gaRevL	init 0
    gaRevR	init 0
    gkMetro init 0
    gkCtr	init 0
    gkLineA	init 0
    gkLineB	init 0
    gkLineC	init 0
    instr gControl
    gkMetro		metro		7
    if (gkMetro == 1) then
    	gkCtr = gkCtr + 1
    endif
    ih = p3 * 0.5
    iq = p3 * 0.25
    ie = p3 * 0.125
    gkLineA		linseg		1, ie, 0, iq, 1, ie, 0, ih, 1
    gkLineB		linseg		1, iq, 0, iq, 1, iq, 0, iq, 1
    gkLineC		linseg		0, ie, 1, ie, 0, ie, 1, ie, 0, ie, 1, ie, 0, ie, 1, ie, 0
    endin
    instr SourceA
    kdiv		oscil		2, 0.2, giSine, 0.2
    kdiv		=			int(kdiv + 5) - int(gkLineC * 3)
    ktrig		init		0
    if ((gkCtr % kdiv == 0) && (gkMetro == 1)) then
    	ktrig = 1
    else
    	ktrig = 0
    endif
    schedkwhen	ktrig, 0, 12, 11, 0, 0.2 + (0.2 * gkLineB), 100, 0.5, 0.7
    endin
    instr SourceB
    kdiv		oscil		2, 0.17, giSine, 0.7
    kdiv		=			int(kdiv + 4) + int(gkLineC * 3)
    ktrig		init		0
    	ktrig = 1
    else
    	ktrig = 0
    endif
    schedkwhen	ktrig, 0, 12, 12, 0, 0.2, 200, 0.3, 0.4, 1, 1, 1.2
    endin
    instr SourceC
    kdiv		oscil		1.5, 0.143, giSine
    kdiv		=			int(kdiv + 3) + int(gkLineC * 3)
    ktrig		init		0
    	ktrig = 1
    else
    	ktrig = 0
    endif
    schedkwhen	ktrig, 0, 12, 12, 0, 0.2, 300, 0.05, 0.1, 1, 3, 0.7
    endin
    instr SourceD
    kdiv		oscil		2.5, 0.23, giSine
    ktrig		init		0
    	ktrig = 1
    else
    	ktrig = 0
    endif
    schedkwhen	ktrig, 0, 12, 12, 0, 0.2, 400, 0.7, 0.4, 2, 1, 0.4
    endin
    instr SourceE
    kdiv		oscil		2, 0.09, giSine
    ktrig		init		0
    	ktrig = 1
    else
    	ktrig = 0
    endif
    schedkwhen	ktrig, 0, 12, 11, 0, 0.2, 500, 0.95, 0.1
    endin
    instr 11		; a sine tone generator
    iLineB = i(gkLineB)
    ibp1 = 0.3 + (iLineB * 0.4)
    ibp2 = 0.2 + (iLineB * 0.1)
    ibp3 = 0.1 + (iLineB * 0.04)
    irand		random	0, 1
    if (irand > ibp1) then
    	ifreq_offset = 0
    elseif (irand > ibp2) then
    	ifreq_offset = 150
    elseif (irand > ibp3) then
    	ifreq_offset = 225
    else
    	ifreq_offset = 300
    endif
    iamprand	random	0.11, 0.23
    iLineA = i(gkLineA)
    iatk = 0.002 + (0.1 - (0.1 * iLineA))
    kline		linsegr	0, iatk, iamprand, p3, iamprand * 0.25, p6, 0
    asig		oscil		kline, p4 + ifreq_offset, giSine
    aL, aR	pan2		asig, p5
    gaRevL = gaRevL + aL
    gaRevR = gaRevR + aR
    		outs		aL, aR
    endin
    instr 12		; a more crisp tone generator
    irand		random	0, 1
    if (irand > 0.5) then
    	ifreq_offset = 0
    elseif (irand > 0.3) then
    	ifreq_offset = 150
    elseif (irand > 0.1) then
    	ifreq_offset = 225
    else
    	ifreq_offset = 300
    endif
    iamprand	random	0.07, 0.17
    iamp = iamprand * p9 * 1.1
    indexrand	random	0.2, 0.3
    iLineA = i(gkLineA)
    iatk = 0.002 + (0.02 - (0.02 * iLineA))
    indexstart	=		indexrand + (iLineA * 0.5)
    indexend	=		indexstart * 0.3
    kindex		line	indexrand, p3, indexend
    kline		linsegr	0, iatk, iamp, p3, iamp * 0.25, p6, 0
    asig		foscil		kline, p4 + ifreq_offset, p7, p8, kindex, giSine
    gaRevL = gaRevL + (aL * (gkLineB + 1))
    gaRevR = gaRevR + (aR * (gkLineB + 1))
    		outs		aL, aR
    endin
    instr Reverb
    iamp = 0.6
    inlevel = 0.4
    isize = 0.75
    icutoff = 2000
    aoutL, aoutR	reverbsc	gaRevL * inlevel, gaRevR * inlevel, isize, icutoff
    gaRevL = 0
    gaRevR = 0
    			outs	aoutL * iamp, aoutR * iamp
    endin
    </CsInstruments>
    <CsScore>
    i "gControl"	0 121
    i "SourceA"		0 120
    i "SourceB"		0 120
    i "SourceC"		0 120
    i "SourceD"		0 120
    i "SourceE"		0 120
    i "Reverb"		0 123
    </CsScore>
    I FOUND IT - I FOUND OUT WHY !!!!
    it turns out that the filenames can only be a certain length, and even though I was adding a .csd to the end of each filename, sometimes the .csd was getting cut off.
    if the filename ends with .csd, your script works perfectly! THANKS
    maybe you should allow for longer filenames (but for sure, I should be more attentive and more clear in my file naming.
    It didn't matter before, because - I was alway copying the file to _main.csd and so... it always ended with .csd!
      yes it definitely was an issue with missing .csd: the current file has to end in .csd in order to be run.
      csounder t turns out that the filenames can only be a certain length, and even though I was adding a .csd to the end of each filename, sometimes the .csd was getting cut off.
      I cannot reproduce this. Could you try to give me step-by-step instructions to reproduce this?
        giuliomoro you may be right about the length of filename not being the issue, I might have just been forgetting to type the .csd when I renamed the files originally.
