Perhaps 'CustomMakefileTop.in' should be located in the current project directory and not in the root directory?
Running currently open Csound file
I see what's happening, this is also the source of trouble you are having elsewhere. Use this instead:
ifdef PROJECT
ifndef CSOUND_FILE
PROJECT_SETTINGS_JSON = $(PROJECT_DIR)/settings.json
CURRENT_FILENAME = $(shell cat $(PROJECT_SETTINGS_JSON) 2> /dev/null | tr "," "\n" | grep "fileName.*\.csd\>" | sed 's/.*"fileName"\s*:\s*"\(.*\.csd\>\)"/\1/' )
override CSOUND_FILE = $(PROJECT_DIR)/$(CURRENT_FILENAME)
endif
endif
Swapping to this version of the CustomMakefileTop.in script did repair the trills, but sadly, it does not work as the other one did. When you select a .csd file from the project and hit the "Build & Run" button, the previous script would push the file to the Bela (as if it were in _main.csd) - and was a huge timesaver and workflow improver.
This version does say loading file in the console, but then it reports the following error message:
Building project ...
Build finished
Makefile:153: *** Invalid/empty project. A project needs to have at least one .cpp or .c or .cc or _main.pd or _main.scd or or run.sh file. Stop.
Hopefully it is an easy fix.
Dr.B.
Hmm, that's strange, as it works for me.
Can you show me the file list for this project and also the content of the settings.json
file in the project folder? This file is hidden normally, but you can show it by going to the IDE settings and enabling "View hidden files", then it should show up among your project files.
giuliomoro It is very curious. Some of the .csd files do work.
- you select them
- they appear in the IDE
- you edit them there
- you push the 'Build & Run' icon/button
- They build and run ! Success.
Others, like the Generative Haiku.csd or some of the MIDI instruments do not
- the console reports
Build finished
Makefile:153: *** Invalid/empty project. A project needs to have at least one .cpp or .c or .cc or main.pd or main.scd or or run.sh file. Stop.
AND it is noteworthy, that with 6.15 the following libraries are missing and warnings appear
Build finished
Running project ...
0"060.998| WARNING: [main] duplicate call from main program to xenomai_init() ignored
0"061.299| WARNING: [main] (xeno-config --no-auto-init disables implicit call)
0dBFS level = 32768.0
--Csound version 6.15 (float samples) Oct 15 2020
[commit: c329d91b2527e96f05ecb47837e2bfd3b68f5be7]
libsndfile-1.0.27
realtime mode enabled
WARNING: [mcould not open library '/usr/lib/csound/plugins-6.0/libfluidOpcodes.so' (libfluidsynth.so.1: cannot open shared object file: No such file or directory)
WARNING: could not open library '/usr/lib/csound/plugins-6.0/libosc.so' (liblo.so.7: cannot open shared object file: No such file or directory)[m
[mUnifiedCSD: /root/Bela/projects/Aug2/DSP-Cook-AnalogEcho.csd
STARTING FILE
Creating options
Creating orchestra
closing tag
Creating score
rtmidi: ALSA Raw MIDI module enabled
Elapsed time at end of orchestra compile: real: 0.044s, CPU: 0.031s
sorting score ...
... done
Elapsed time at end of score sort: real: 0.047s, CPU: 0.031s
setting dummy interface
graphics suppressed, ascii substituted
orch now loaded
SECTION 1:
Initialising spinlock...
Starting realtime mode queue: 0xb50b9010 thread: 0x12371b0
I am not sure how you would like me to show you the file list for the project
- The Project is called Aug2
- The list of files in the project are:
main.csd
ALGO-Aikin-Groovish
ALGO-McCurdy-Haiku4
Bela-Trill1.csd
DSP-Alex-mTog-SubInstruments
DSP-Cook-Harmoniser.csd
DSP-Cook-LorenzChorus.csd
DSP-Cook-mStressonCC.csd
DSP-Cook-Mutator.csd
DSP-dB+Hans-mTog-CCmultFX
DSP-FLOSS-Audio2Control
DSP-McCurdy-mGrain
DSP-Pedro-mTog-NLresBank
DSP-Pedro-mTog-NLstresBank
DSP-Pedro-mTog-NLStresIncr
DSP-Siena-mTog-chanGetSetFX.csd
DSP-Siena-MultiFX_0803.csd
DSP-Victor-mTog-LiveLoop
MIDI-615toggle.csd
MIDI-Adam-HansPluck
MIDI-cntCreate.csd
MIDI-ctrlPresetV6-ffitch.csd
MIDI-FM-cc1-8
MIDI-Gabe-mTog-ccSwitch4.csd
MIDI-micro-cpstunSwitch.csd
MIDI-micro-FOF-Bohlen-Pierce.csd
MIDI-micro-NoisePitch-B-Pierce.csd
MIDI-MoogVCF
MIDI-Pedro-mTog-2EventInsts
MIDI-RCB-sndwarp.csd
MIDI-Turnon-Event.csd
MIDI-Turnon-Scoreline.csd
my_ctrlinits.txt
my_ctrlpresets.txt
NL-bob.csd
NL-lag.csd
NL-sterrain.csd
NL-Toot1-RCB.csd
NL-trighold.csd
NL-vps.csd
settings.json
z-AdrienS.aif
z-no_fluteC3.wav
z-OboeScaleS.aif
z-sp_hamlet.aif
z-sp_hellorcb.aif
zCosmoBlur.udo
zCosmoChorus.udo
zCosmoFakeGrainer.udo
zCosmoLowPass.udo
zCosmoRandDelay.udo
zCosmoReverb.udo
zFox.wav
The contents of the settings.json folder is:
{"fileName":"settings.json","CLArgs":{"-p":"16","-C":"4","-B":"16","-H":"-6","-N":"1","-G":"1","-M":"0","-D":"0","-A":"0","--pga-gain-left":"10","--pga-gain-right":"10","user":"","make":"","-X":"0","audioExpander":"0","-Y":"","-Z":"","--disable-led":"0"}}
This file 'MIDI-615toggle.csd' (which requires Version 6.15 to run successfully) - does work with your script.
- It loads into the IDE and then you hit build and run (without copying to _main and it builds and runs :
<CsoundSynthesizer>
<CsOptions>
-Mhw:1,0,0 -+rtmidi=NULL --daemon -dm0
</CsOptions>
<CsInstruments>
nchnls = 2
0dbfs = 1
gicntA cntCreate 1 ; a toggle
gicntNoteA cntCreate 1 ; ignore note-off message - turn MIDI notes into toggles
gicntB cntCreate 1
gicntNoteB cntCreate 1
gicntC cntCreate 1
gicntNoteC cntCreate 1
instr 1
kkey sensekey
printk2 kkey
if (kkey == 97) then ; ASCII 'a' = 97
k1 count gicntA
if k1==0 then
event "i", 2, 0, -1
else
event "d", 2, 0, -1
endif
endif
if (kkey == 115) then ; ASCII 's' = 115
k1 count gicntB
if k1==0 then
event "i", 3, 0, -1
else
event "d", 3, 0, -1
endif
endif
if (kkey == 100) then ; ASCII 'd' = 100
k1 count gicntC
if k1==0 then
event "i", 4, 0, -1
else
event "d", 4, 0, -1
endif
endif
inote notnum
print inote
if (inote == 60) then
i2 count_i gicntNoteA
print i2
if i2==0 then
event_i "i", 2, 0, -1
else
event_i "d", 2, 0, -1
endif
endif
if (inote == 62) then
i2 count_i gicntNoteB
print i2
if i2==0 then
event_i "i", 3, 0, -1
else
event_i "d", 3, 0, -1
endif
endif
if (inote == 64) then
i2 count_i gicntNoteC
print i2
if i2==0 then
event_i "i", 4, 0, -1
else
event_i "d", 4, 0, -1
endif
endif
endin
instr 2
kenv linenr .25,.1,.1,.01
asig oscil kenv, 261.63
outs asig,asig
endin
instr 3
kenv linenr .25,.05,.1,.01
asig oscil kenv, 293.665
outs asig,asig
endin
instr 4
kenv linenr .25,.02,.1,.01
asig oscil kenv, 329.628
outs asig,asig
endin
</CsInstruments>
<CsScore>
i1 0 z
</CsScore>
</CsoundSynthesizer>
This one (ALGO-Aikin-Groovish) - is the Bela 'Theme Song' in my classes - by Jim Aikin from Keyboard Magazine fame, required you to copy it to _main before it will build and run
<CsoundSynthesizer>
<CsOptions>
-dm0
</CsOptions>
<CsInstruments>
sr = 44100
ksmps = 16
nchnls = 2
0dbfs = 1
seed 127
giSine ftgen 0, 0, 8192, 10, 1
gaRevL init 0
gaRevR init 0
gkMetro init 0
gkCtr init 0
gkLineA init 0
gkLineB init 0
gkLineC init 0
instr gControl
gkMetro metro 7
if (gkMetro == 1) then
gkCtr = gkCtr + 1
endif
ih = p3 * 0.5
iq = p3 * 0.25
ie = p3 * 0.125
gkLineA linseg 1, ie, 0, iq, 1, ie, 0, ih, 1
gkLineB linseg 1, iq, 0, iq, 1, iq, 0, iq, 1
gkLineC linseg 0, ie, 1, ie, 0, ie, 1, ie, 0, ie, 1, ie, 0, ie, 1, ie, 0
endin
instr SourceA
kdiv oscil 2, 0.2, giSine, 0.2
kdiv = int(kdiv + 5) - int(gkLineC * 3)
ktrig init 0
if ((gkCtr % kdiv == 0) && (gkMetro == 1)) then
ktrig = 1
else
ktrig = 0
endif
schedkwhen ktrig, 0, 12, 11, 0, 0.2 + (0.2 * gkLineB), 100, 0.5, 0.7
endin
instr SourceB
kdiv oscil 2, 0.17, giSine, 0.7
kdiv = int(kdiv + 4) + int(gkLineC * 3)
ktrig init 0
ktrig = 1
else
ktrig = 0
endif
schedkwhen ktrig, 0, 12, 12, 0, 0.2, 200, 0.3, 0.4, 1, 1, 1.2
endin
instr SourceC
kdiv oscil 1.5, 0.143, giSine
kdiv = int(kdiv + 3) + int(gkLineC * 3)
ktrig init 0
ktrig = 1
else
ktrig = 0
endif
schedkwhen ktrig, 0, 12, 12, 0, 0.2, 300, 0.05, 0.1, 1, 3, 0.7
endin
instr SourceD
kdiv oscil 2.5, 0.23, giSine
ktrig init 0
ktrig = 1
else
ktrig = 0
endif
schedkwhen ktrig, 0, 12, 12, 0, 0.2, 400, 0.7, 0.4, 2, 1, 0.4
endin
instr SourceE
kdiv oscil 2, 0.09, giSine
ktrig init 0
ktrig = 1
else
ktrig = 0
endif
schedkwhen ktrig, 0, 12, 11, 0, 0.2, 500, 0.95, 0.1
endin
instr 11 ; a sine tone generator
iLineB = i(gkLineB)
ibp1 = 0.3 + (iLineB * 0.4)
ibp2 = 0.2 + (iLineB * 0.1)
ibp3 = 0.1 + (iLineB * 0.04)
irand random 0, 1
if (irand > ibp1) then
ifreq_offset = 0
elseif (irand > ibp2) then
ifreq_offset = 150
elseif (irand > ibp3) then
ifreq_offset = 225
else
ifreq_offset = 300
endif
iamprand random 0.11, 0.23
iLineA = i(gkLineA)
iatk = 0.002 + (0.1 - (0.1 * iLineA))
kline linsegr 0, iatk, iamprand, p3, iamprand * 0.25, p6, 0
asig oscil kline, p4 + ifreq_offset, giSine
aL, aR pan2 asig, p5
gaRevL = gaRevL + aL
gaRevR = gaRevR + aR
outs aL, aR
endin
instr 12 ; a more crisp tone generator
irand random 0, 1
if (irand > 0.5) then
ifreq_offset = 0
elseif (irand > 0.3) then
ifreq_offset = 150
elseif (irand > 0.1) then
ifreq_offset = 225
else
ifreq_offset = 300
endif
iamprand random 0.07, 0.17
iamp = iamprand * p9 * 1.1
indexrand random 0.2, 0.3
iLineA = i(gkLineA)
iatk = 0.002 + (0.02 - (0.02 * iLineA))
indexstart = indexrand + (iLineA * 0.5)
indexend = indexstart * 0.3
kindex line indexrand, p3, indexend
kline linsegr 0, iatk, iamp, p3, iamp * 0.25, p6, 0
asig foscil kline, p4 + ifreq_offset, p7, p8, kindex, giSine
gaRevL = gaRevL + (aL * (gkLineB + 1))
gaRevR = gaRevR + (aR * (gkLineB + 1))
outs aL, aR
endin
instr Reverb
iamp = 0.6
inlevel = 0.4
isize = 0.75
icutoff = 2000
aoutL, aoutR reverbsc gaRevL * inlevel, gaRevR * inlevel, isize, icutoff
gaRevL = 0
gaRevR = 0
outs aoutL * iamp, aoutR * iamp
endin
</CsInstruments>
<CsScore>
i "gControl" 0 121
i "SourceA" 0 120
i "SourceB" 0 120
i "SourceC" 0 120
i "SourceD" 0 120
i "SourceE" 0 120
i "Reverb" 0 123
</CsScore>
I FOUND IT - I FOUND OUT WHY !!!!
it turns out that the filenames can only be a certain length, and even though I was adding a .csd to the end of each filename, sometimes the .csd was getting cut off.
if the filename ends with .csd, your script works perfectly! THANKS
maybe you should allow for longer filenames (but for sure, I should be more attentive and more clear in my file naming.
It didn't matter before, because - I was alway copying the file to _main.csd and so... it always ended with .csd!
yes it definitely was an issue with missing .csd
: the current file has to end in .csd
in order to be run.
csounder t turns out that the filenames can only be a certain length, and even though I was adding a .csd to the end of each filename, sometimes the .csd was getting cut off.
I cannot reproduce this. Could you try to give me step-by-step instructions to reproduce this?
giuliomoro you may be right about the length of filename not being the issue, I might have just been forgetting to type the .csd when I renamed the files originally.
