sorry I will hopefully have time tomorrow to try this out myself. It looks like you are missing the pd-lib-builder folder in there. Also, you can delete all of those .pd_darwin files. As per the documentation of the pd-lib-builder/Makefile.pdlibbuilder file, you will need to specify
# PDINCLUDEDIR:
# Directory where Pd API m_pd.h should be found, and other Pd header files.
# Overrides the default search path.
on the command line. That is the folder where the Pd header files live. On Bela, that is /usr/local/include/libpd/
So, once you re-add the missing folder, you can re-run the make command (from within the cyclone folder, same as you did earlier, but with an extra command-line option):
make PDINCLUDEDIR=/usr/local/include/libpd
however, this may still fail if some files are missing.
