hey guys,
just my two cents here.
I m working on a project with Bela and successfully using PD externals compiled with a Raspberry Pi3.
I started from the assumption that if the external was compiled on ARM, then it might work on another ARM based Linux platform and indeed most of them did work (including cyclone).
@giuliomoro : any possible negative consequences by doing this?
Thank you
L
It really depends on the Pd external in question and its dependencies. Only the file m_pd.h is guaranteed to never change for Pd (or to change in a backwards compatible way). This means that as long as the external was built for an older version of Pd than the one you have and it was only using m_pd.h, then you are most likely fine, assuming:
- same architecture
- that you have on your system any shared libraries that your external depends on
- that the shared libraries you have are compatible (e.g.: your version is the same or is backwards compatible)
however, if the externals use some more of Pd's .h files, then in order to have guaranteed working externals, they'd have to be built specifically for the version of Pd you are running on. This means same version, but also same fork. In the case of our fork, the changes are minimal, and you'd probably be fine with something built for the same version of Pd.
cyclone does use some Pd's internal .h, so I'd recommend you build it on the board, however you are free to try with the pre-built binaries and check if practically it works ok or not.
Ok clear, thanks a lot for the explanation.
I actually compiled with success also libraries with other dependencies (like the brilliant TimbreID by William Brent), always on a RPi3, then copied the binaries in my Bela project folder. But yeah, will definitely try to compile something directly on the Bela next time.
Anyway, for what it matters, I haven't experienced any problems so far with debian pre-built cyclone (although I have used a fraction of the available objects).
My biggest worry was more if that could lead to crashes or any sort of instability?
giuliomoro Thanks. That worked, patching on Bela is going to be so much smoother with these as a former Max-head! Important to note that you need to include the cyclone/ part of the object name..I wouldn't have thought of that.
    cmm Important to note that you need to include the cyclone/ part of the object name..I wouldn't have thought of that.
    yes I mentioned it up here
    giuliomoro (e.g.: [cyclone/delay~]),
    This is due to the folder structure of the Cyclone externals: all the externals live as file in the cyclone/ folder. If you want, you can add another line
    	libpd_add_to_search_path("../pd-externals/cyclone");
    to the core/default_libpd_render.cpp file, https://github.com/BelaPlatform/Bela/blob/master/core/default_libpd_render.cpp#L382-L383, if you want the setting to be applied to all your projects, or provide a custom render.cpp file with this change if you want it to be applied only to a specific project.
    • cmm replied to this.
      giuliomoro yeah, I would have been lost if you hadn't said that, I was going in circles until I remembered your post. It's not something I've ever needed to do in Pd before.
      You have to do it also in Pd unless you set up the path in the preferences.
      12 days later
      giuliomoro Hi, could you exactly explain how to do that? it doesn't seem to work for me...i have a patch .pd with a external library object; which file should i place inside projects/pd-externals? the .c or the .pd_linux? At the moment neither is working for me...
      It's always the .pd_linux that needs to go in projects/pd-externals. If you have a library external, then you have to create an object with the name of the library FIRST, then you can create all the objects from the library. For instance:
      [zexy]
      then
      [pack~]
      CAVEAT: the main library object ([zexy]) needs to be created BEFORE you try to create the individual objects. The order in which objects are created is the order in which they are in the plain-text representation of the Pd patch. Basically, there is no way of telling just by looking at the patch, and you cannot arbitrarily move them around in the text file. So the solution is: cut everything except the main library object, then paste everything: the newly pasted objects will be created by Pd after whatever was there.
      Alternatively, the proper way of doing it should be: [declare -lib zexy], but I have not tested this on Bela.
        giuliomoro So if i am using cyclone for example i will need cyclone.pd_linux plus object.pd_linux for each object i need? I tried to compile in the IDE the cyclone_lib.c file and it generated a cyclone_lib.pd_linux but it still prompts the same error: couldn't create...
        Would you mind posting the process in steps or something similar?
          londonpride I also tried to do it without the library object.
          - uploaded the object.c
          - uploaded a Makefile specific for the object.
          - uploaded the needed headers and run the makefile in the IDE console.
          Worked like a charm for some objects but others would still prompt: couldn't create...
            londonpride Worked like a charm for some objects but others would still prompt: couldn't create...
            What objects fail to create?
            londonpride uploaded a Makefile specific for the object.
            How did you generate the Makefile?
            londonpride Would you mind posting the process in steps or something similar?
            Was this not good enough?
              giuliomoro i compiled [cyclone/cycle~] using the .c source code and worked perfectly, [cyclone/gate~] on the other hand compiled and created the .pd_linux file but would still fail to generate.
              I created the makefile in sublime text and it worked for [cyclone/cycle~]
              I am sorry if you misunderstood my asking for the steps, i didn't mean to diminish your explanation or anything is just that i am a bit of a newbie using pd on bela. I've only worked with c++ on bela before.
              What is in these Makefiles? Why don't you use the one that comes with the project?
              a month later
              Hello, I'm having a few issues compiling pd externals. I've worked through this post without success and I eventually found this very helpful guide: https://forum.bela.io/d/580-compiling-pd-externals-a-guide which clears most things up.
              However, I'm still getting errors - "make: *** No targets specified and no makefile found. Stop" for [cyclone], [comport] and [list-abs] objects. I read the post above on [cyclone] and have taken the following steps:
              • Updated Bela code
              • Downloaded the PD fork and copied it into /root/pure-data
              • then went back to Bela/projects/pd-externals/externals/cyclone and tried
                'make PDINCLUDEDIR=/root/pure-data/src/ PDLIBDIR=/root/Bela/projects/pd-externals install'
              But I'm getting "make: *** No rule to make target "install". Stop.
              Any ideas?
                Great, thanks. Managed to successfully compile [cyclone] and [list-abs] objects now.
                Having a slight issue with the cyclone -- coll object though. It turns the project window blank (although it doesn't say 'couldn't create' in the console). Not sure what's going on with it.
                Also I haven't managed to compile the [comport] object. I can't find a Makefile for it. But in the readme file it says:
                compile:
                 Unix (Linux):
                  make pd_linux,  make pd_irix5, make pd_irix6, make pd_darwin
                  should produce a comport.pd_linux, ....
                this is all new to me so not really sure what to do with that... do I still need a makefile from somewhere?
                  Where is the source code for the [comport] object?
                  emerson Having a slight issue with the cyclone -- coll object though. It turns the project window blank (although it doesn't say 'couldn't create' in the console). Not sure what's going on with it.
                  I cannot reproduce this. Can you send the Pd file?
                  Ok, so now got the source code for [comport] from the puredata.info site, which has a make file in it. Copied the new comport folder to the pd-externals folder on Bela but getting:
                  Makefile:191: recipe for target 'comport.o' failed
                  make: *** [comport.o] Error 1
                  root@bela:~/Bela/projects/pd-externals/pd-comport# make PD_INCLUDE=/root/Bela/projects/pd-externals
                   -I"/root/Bela/projects/pd-externals/pd" -Wall -W -g -DPD -DVERSION='"0.2"' -fPIC -O6 -funroll-loops -fomit-frame-pointer -o "comport.o" -c "comport.c"
                  comport.c:24:18: fatal error: m_pd.h: No such file or directory
                   #include "m_pd.h"
                  compilation terminated.
                  for whatever I try. It says to use PD_INCLUDE = $(PD_PATH)/include in the make file.
                  I tried:
                  make PD_INCLUDE=/usr/local/include/libpd/
                  make PD_INCLUDE=/root/Bela/projects/pd-externals install
                  make PD_INCLUDE=/usr/local/include/libpd PDLIBDIR=/root/Bela/projects/pd-externals install
                  make PD_INCLUDE=/root/pure-data/src/ PDLIBDIR=/root/Bela/projects/pd-externals install
                  This is what's in the [comport] folder:
                  CHANGES.txt  Makefile    comport-help.pd  comport-stress-test.pd  comport.dsp
                  comport.pd_darwin LICENSE.txt  README.txt  comport-meta.pd  comport.c
                  comport.dsw  makefile_win
                  can you link to the source code? I struggle to find it on the website. Is it the "get comport for all platforms" download link from https://puredata.info/downloads/comport/releases/0.2 ?
                  Inspecting the Makefile in there, there is one line:
                  CFLAGS = -I"$(PD_INCLUDE)/pd" -Wall -W -g
                  so it seems to append /pd to whatever value you give to PD_INCLUDE=. I'd recommend you edit the Makefile and remove that /pd so you can pass the correct path straight from the command line.
                  Additionally, PDLIBDIR= is not taken into consideration by this Makefile, and the paths used for the install target are a bit complicated. I'd recommend you just manually copy the generated comport.pd_linux file to ~/Bela/projects/pd-externals/.
