fixed that now they all show up. Can you please go through them and delete duplicates?
This >>>>
[ 1.081280] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (89, <AValid), retry #1, port1 00000104
looks suspicious. You have several of those in the BAT one. It's strange because it comes after some successful ones, such as :
0.926316] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.926346] musb-hdrc: MHDRC RTL version 2.0
[ 0.926357] musb-hdrc: setup fifo_mode 4
[ 0.926383] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.926551] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.926596] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 0.926956] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.926974] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.926987] usb usb2: Product: MUSB HDRC host driver
[ 0.926998] usb usb2: Manufacturer: Linux 4.4.113-ti-xenomai-r149 musb-hcd
[ 0.927010] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 0.928223] hub 2-0:1.0: USB hub found
[ 0.928301] hub 2-0:1.0: 1 port detected
maybe you already did it, but just checking: what do you get when you power from VBAT and you connect the USB and then you do lsusb ? And does that get updated when you disconnect/reconnect the USB device?
