right, so no software workaround possible. The deal involves a hardware hack:
- with a wire cutter, carefully clip P1.07 (
usb1 VI
) between the PocketBeagle and the BelaMini cape. The closer you are to the PB the better. - bend the leg out to ensure it does not short together again
For example:
Option 1:
- use a jumper wire on the BelaMini headers to connect any of the
VOUT
pins (P1.24
orP2.13
) toP1.07
(this is also displayed above, where the blue wire is jumpering P1.24 to P1.07) - once everything work fine, cut off the bent-out leg of P1.07
Option 2:
- use a piece of wire to make the same connection as in option 1, soldering at both ends. This is tricky in that you'd have to take the signal from the bottom of the PB (e.g.: from P1.24
), and route the wire somehow to the bent out leg of P1.07.
