great! the mam has a noise gate as well, but i suspect it is on the output rather then the input
Vocoder on Bela
lokki but i suspect it is on the output
This agrees with the block diagram on manual page 16
http://www.univertron.com/SAS/manuals/MAM/MAM%20VF11%20Users%20Manual.pdf
Hi, I'm very interested to make this vocoder. Would it run on the mini Bela, or does it require the full version?
I have done some small bits with arduino/teensy, though new to Bela. Thanks!
SOOTY It runs on Bela mini without any more limitations on the full size Bela. Notice the Bela mini has the same CPU, so processing power is the same.
Bela mini also has enough inputs/outputs to run the vocoder. Let me know if you need pointers to hook it up. The code should work without modification as long as you get the hardware connections done properly.
Let me know if you have troubles and I'm happy to help. I have a Bela mini, so I can work out the kinks if there are any.
Thank you so much, very kind. I will let you know how I get on.
