Hi, any idea how could I access UART4 incoming data in Pd?
Using UART1 on Bela Mini
Oh that takes some work. Do you know a bit of C++?
I am learning now... looking into the possibility of combining Pd and C++ through a custom render. Is this a good place to start?
yes. A practical example of Pd communicating to an I2C device is shown here. If you simply need to read from UART at regular intervals and send the latest reading to Pd, you could use the structure of the sections marked as #ifdef ENABLE_EVO
as a starting point for your application, and instead of using the Evo.h
file, you'd have #include <libraries/Serial/Serial.h>
and then create an object of the Serial
class.
If instead you need to transmit messages back and forth things are a bit more complex.
Thanks @giuliomoro. I am trying to read from UART rather than transmit messages back and forth. By trying to reconfigure the Evo (and serial) examples, I managed to get messages into Pd. The messages I get in Pd, however, have a different format than the original format of the incoming UART data (they seem to appear as a float count of the characters of the message). As I include a serial class and library, I had to substitute gEvo.gotDistance() with something else, which in this case was gSerial.write(serialBuffer, maxLen, 100). Any Idea what do I need to change here to get the original format of the UART messages in Pd?
Hm can you post your full code?
Here it is.
#define ENABLE_EVO
#define ENABLE_Serial
#define BELA_LIBPD_GUI
#include <stdio.h>
#define PD_THREADED_IO
#include <libpd/z_libpd.h>
extern "C" {
#include <libpd/s_stuff.h>
#include <string>
#include <sstream>
#include <algorithm>
#define ENABLE_TRILL
// #ifdef ENABLE_EVO
// #include "Evo.h"
// Evo gEvo;
// int gEvoI2cBus = 1; // the I2c bus the sensor is connected to
// int gEvoI2cAddress = 0x31; // "Primary Slave Address"
// int gEvoReadSleepMs = 10; // how often to read from the Evo
// int gEvoSendIntervalMs = 100; // how often to send Evo reading to Pd
// const char gEvoReceiverName[] = "evo"; // the name of the corresponding Pd [receive ...] object
// float gEvoValue; // the evoReadTask sets this and render() sends it to Pd
// void evoReadTask(void*)
// while(!Bela_stopRequested())
// if(gEvo.readI2C()) {
// fprintf(stderr, "Error reading. Stopping\n");
// Bela_requestStop();
// break;
// gEvoValue = gEvo.getDistance();
// usleep(gEvoReadSleepMs * 1000);
// #endif // ENABLE_EVO
#ifdef ENABLE_Serial
Serial gSerial;
int gSerialReadSleepMs = 10; // how often to read from the Evo
int gSerialSendIntervalMs = 100; // how often to send Evo reading to Pd
const char gSerialReceiverName[] = "serial-uart4"; // the name of the corresponding Pd [receive ...] object
float gSerialValue; // the evoReadTask sets this and render() sends it to Pd
void serialReadTask(void*)
unsigned int maxLen = 512;
char serialBuffer[maxLen];
// read from the serial port with a timeout of 100ms
int ret = gSerial.read(serialBuffer, maxLen, 100);
if (ret > 0) {
printf("Received: %.*s\n", ret, serialBuffer);
gSerialValue = gSerial.write(serialBuffer, maxLen, 100);
usleep(gSerialReadSleepMs * 1000);
#endif // ENABLE_Serial
#if (defined(BELA_LIBPD_GUI) || defined(ENABLE_TRILL))
template <typename T>
int getIdxFromId(const char* id, std::vector<std::pair<std::string,T>>& db)
for(unsigned int n = 0; n < db.size(); ++n)
if(0 == strcmp(id, db[n].first.c_str()))
return n;
return -1;
#endif // BELA_LIBPD_GUI || ENABLE_TRILL
#ifdef ENABLE_TRILL
#include <tuple>
AuxiliaryTask gTrillTask;
Pipe gTrillPipe;
static std::vector<std::string> gTrillAcks;
static std::vector<std::pair<std::string,Trill*>> gTouchSensors;
// how often to read the cap sensors inputs.
float touchSensorSleepInterval = 0.007;
void readTouchSensors(void*)
for(unsigned int n = 0; n < gTouchSensors.size(); ++n)
Trill& touchSensor = *gTouchSensors[n].second;
int ret;
const Trill::Device type = touchSensor.deviceType();
if(Trill::NONE == type)
ret = 1;
else
ret = touchSensor.readI2C();
if(!ret)
gTrillPipe.writeNonRt(n);
#endif // ENABLE_TRILL
#ifdef BELA_LIBPD_GUI
Pipe gGuiPipe;
Gui gui;
struct bufferDescription
std::string name;
int id;
int size;
static std::vector<struct bufferDescription> gGuiDataBuffers;
static std::vector<std::string> gGuiControlBuffers;
struct guiControlMessageHeader
uint32_t size;
uint32_t type;
uint32_t id;
bool guiControlDataCallback(JSONObject& root, void* arg)
int ret = true;
for(unsigned int n = 0; n < gGuiControlBuffers.size(); ++n)
const auto& b = gGuiControlBuffers[n];
std::wstring key = JSON::s2ws(b);
if (root.end() != root.find(key))
JSONValue* found = root[key];
struct guiControlMessageHeader header;
header.id = n;
char* array;
if(found->IsString())
std::string value = JSON::ws2s(found->AsString());
header.type = 's';
header.size = value.size();
array = (char*)alloca(header.size);
memcpy(array, value.c_str(), header.size);
} else if(found->IsNumber())
float value = found->AsNumber();
header.type = 'f';
header.size = sizeof(value);
memcpy(array, &value, header.size);
} else {
continue;
// do two separate reads: the pipe is datagram-based
// so it would be impossible to receive partial messages
// at the other end
gGuiPipe.writeNonRt(header);
gGuiPipe.writeNonRt(&array[0], header.size);
// we have successully parsed this message, so the
// default parser shouldn't when we return
// note: in practice there may be times when we'd want
// to have the default parser handle this message
// (e.g.: when an "event" field is also present), but
// for now we ignore them
ret = false;
continue;
return ret;
static unsigned int gScopeChannelsInUse = 4;
static unsigned int gFirstAnalogInChannel;
static unsigned int gFirstAnalogOutChannel;
settings->interleave = 0;
float* gInBuf;
float* gOutBuf;
#define PARSE_MIDI
int gMidiVerbose = 1;
const int kMidiVerbosePrintLevel = 1;
void dumpMidi()
if(midi.size() == 0)
return;
"Num",
"Name",
"In",
"Out",
"Pd channels"
n,
gMidiPortNames[n].c_str(),
n * 16 + 1,
n * 16 + 16
Midi* newMidi;
newMidi = new Midi();
#ifdef PARSE_MIDI
newMidi->enableParser(true);
#else
newMidi->enableParser(false);
#endif /* PARSE_MIDI */
if(verboseSuccess)
if(newMidi->isInputEnabled())
if(verboseSuccess)
if(verboseError)
fprintf(stderr, "Failed to open MIDI device %s\n", name.c_str());
return nullptr;
} else {
return newMidi;
unsigned int port = 0;
while(*channel >= 16){
*channel -= 16;
port += 1;
return port;
if(gMidiVerbose >= kMidiVerbosePrintLevel)
port < midi.size() && midi[port]->writeNoteOn(channel, pitch, velocity);
port < midi.size() && midi[port]->writeControlChange(channel, controller, value);
port < midi.size() && midi[port]->writeProgramChange(channel, program);
port < midi.size() && midi[port]->writePitchBend(channel, value);
port < midi.size() && midi[port]->writeChannelPressure(channel, pressure);
port < midi.size() && midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
if(port > (int)midi.size()){
port = 0;
port < midi.size() && midi[port]->writeOutput(byte);
rt_printf("%s", received);
libpd_float((const char*)receiverName, (float)state);
// rt_printf("%s: %d\n", (char*)receiverName, state);
#ifdef ENABLE_TRILL
void setTrillPrintError()
rt_fprintf(stderr, "bela_setTrill format is wrong. Should be:\n"
"[mode <sensor_id> <prescaler_value>(\n"
" or\n"
"[threshold <sensor_id> <threshold_value>(\n"
" or\n"
"[prescaler <sensor_id> <prescaler_value>(\n");
void Bela_listHook(const char *source, int argc, t_atom *argv)
if(0 == strcmp(source, "bela_guiOut"))
if(!libpd_is_float(&argv[0]))
rt_fprintf(stderr, "Wrong format for bela_gui, the first element should be a float\n");
return;
unsigned int bufNum = libpd_get_float(&argv[1]);
if(libpd_is_float(&argv[1])) // if the first element is a float, we send an array of floats
float buf[argc - 1];
for(int n = 1; n < argc; ++n)
t_atom *a = &argv[n];
if(!libpd_is_float(a))
rt_fprintf(stderr, "Wrong format for bela_gui\n"); // this should never happen, because then the selector would've not been "float"
return;
buf[n - 1] = libpd_get_float(a);
gui.sendBuffer(bufNum, buf, argc - 1);
return;
} else { // otherwise we send each element of the list separately
if (libpd_is_float(a)) {
float x = libpd_get_float(a);
gui.sendBuffer(bufNum, x);
} else if (libpd_is_symbol(a)) {
const char *s = libpd_get_symbol(a);
gui.sendBuffer(bufNum, s, strlen(s)); // TODO: should it be strlen(s)+1?
return;
if(1 != argc || !libpd_is_float(argv))
rt_fprintf(stderr, "Wrong format for bela_setMidi, expected: [verbose <n>(\n");
} else {
gMidiVerbose = libpd_get_float(argv);
rt_printf("MIDI verbose: %d\n", gMidiVerbose);
return;
int num[3] = {0, 0, 0};
if(!libpd_is_float(&argv[n]))
fprintf(stderr, "Wrong format for bela_setMidi, expected:[hw 1 0 0(");
return;
if(newMidi)
midi.push_back(newMidi);
dumpMidi();
return;
bool disable = false;
direction = INPUT;
direction = OUTPUT;
disable = true;
} else {
return;
if(argc == 0){
return;
return;
int channel = libpd_get_float(&argv[0]) - gLibpdDigitalChannelOffset;
if(disable == true){
dcm.unmanage(channel);
return;
if(argc >= 2){
t_atom* a = &argv[1];
if(libpd_is_symbol(a)){
if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
isMessageRate = false;
return;
if(0 == strcmp(source, "bela_setGui"))
if(0 == strcmp(symbol, "new"))
if(
argc < 2
|| !libpd_is_symbol(argv)
|| !libpd_is_symbol(argv + 1)
return;
const char* mode = libpd_get_symbol(argv);
const char* name = libpd_get_symbol(argv + 1);
if(0 == strcmp(mode, "control"))
gGuiControlBuffers.emplace_back(name);
return;
if(0 == strcmp(mode, "array"))
// because of
// https://github.com/libpd/libpd/issues/274
// (again), we cannot access the arrays right
// here (as it would deadlock on loadbang), so
// we have to defer creation of the Gui
// buffers until render() runs
gGuiDataBuffers.emplace_back(bufferDescription{.name = name, .id = -1, .size = 0});
return;
return;
#ifdef ENABLE_TRILL
if(0 == strcmp(source, "bela_setTrill"))
bool err = false;
uint8_t address = 0xff;
if(argc < 3)
err = true;
else if (!libpd_is_symbol(argv) // sensor_id
|| !libpd_is_float(argv + 1) // bus
|| !libpd_is_symbol(argv + 2) // device
err = true;
if(argc >= 4)
if(libpd_is_float(argv + 3))
address = libpd_get_float(argv + 3);
else
err = true;
if(err)
rt_fprintf(stderr, "bela_setTrill wrong format. Should be:\n"
"[new <sensor_id> <bus> <device> <address>(\n");
return;
const char* name = libpd_get_symbol(argv);
unsigned int bus = libpd_get_float(argv + 1);
const char* deviceString = libpd_get_symbol(argv + 2);
Trill::Device device = Trill::getDeviceFromName(deviceString);
Trill* trill = new Trill(bus, device, address);
if(Trill::NONE == trill->deviceType())
rt_fprintf(stderr, "Unable to create Trill %s device `%s` on bus %u at ", deviceString, name, bus);
if(128 < address)
rt_fprintf(stderr, "default address. ");
else
rt_fprintf(stderr, "address: %#x (%d). ", address, address);
rt_fprintf(stderr, "Is the device connected?\n");
return;
gTouchSensors.emplace_back(std::string(name), trill);
gTrillAcks.push_back(name);
//an ack is sent to Pd during the next audio callback because of https://github.com/libpd/libpd/issues/274
return;
if(argc < 1 || !libpd_is_symbol(argv))
rt_fprintf(stderr, "bela_setTrill: wrong format. It should be\n"
"[<command> <sensor_id> ...(");
return;
const char* sensorId = libpd_get_symbol(argv);
int idx = getIdxFromId(sensorId, gTouchSensors);
if(idx < 0)
rt_fprintf(stderr, "bela_setTrill sensor_id unknown: %s\n", sensorId);
return;
if(0 == strcmp(symbol, "updateBaseline"))
gTouchSensors[idx].second->updateBaseline();
return;
if(0 == strcmp(symbol, "mode"))
if(argc < 2
setTrillPrintError();
return;
const char* modeString = libpd_get_symbol(argv + 1);
Trill::Mode mode = Trill::getModeFromName(modeString);
gTouchSensors[idx].second->setMode(mode);
if(
0 == strcmp(symbol, "threshold")
|| 0 == strcmp(symbol, "prescaler")
if(
argc < 2
return;
float value = libpd_get_float(argv + 1);
if(0 == strcmp(symbol, "threshold"))
gTouchSensors[idx].second->setNoiseThreshold(value);
if(0 == strcmp(symbol, "prescaler"))
if(Trill::prescalerMax < value || 0 > value)
if(0 == value)
value = 0;
if(Trill::prescalerMax < value)
value = Trill::prescalerMax;
rt_printf("bela_setTrill prescaler value out of range, clipping to %u\n", value);
gTouchSensors[idx].second->setPrescaler(value);
return;
return;
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between gLibpdDigitalChannelOffset and (gLibpdDigitalCHannelOffset+gDigitalChannelsInUse)
unsigned int channel = receiver - gLibpdDigitalChannelOffset; // go back to the actual Bela digital channel number
if(channel < gDigitalChannelsInUse){ //number of digital channels
dcm.setValue(channel, value);
std::vector<std::string> gReceiverInputNames;
std::vector<std::string> gReceiverOutputNames;
void generateDigitalNames(unsigned int numDigitals, unsigned int libpdOffset, std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
std::string outBaseString = "bela_digitalOut";
receiverInputNames.push_back(inBaseString + std::to_string(i+libpdOffset));
receiverOutputNames.push_back(outBaseString + std::to_string(i+libpdOffset));
void printDigitalNames(std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
printf("DIGITAL INPUTS\n");
for(unsigned int i=0; i<gDigitalChannelsInUse; i++)
printf("%s\n", receiverInputNames[i].c_str());
printf("DIGITAL OUTPUTS\n");
printf("%s\n", receiverOutputNames[i].c_str());
#ifdef PD_THREADED_IO
void fdLoop(void* arg){
while(!Bela_stopRequested()){
sys_doio();
usleep(3000);
#endif /* PD_THREADED_IO */
Scope scope;
float* gScopeOut;
void* gPatch;
bool gDigitalEnabled = 0;
gSerial.setup("/dev/ttyS4", 9600);
AuxiliaryTask serialCommsTask = Bela_createAuxiliaryTask(serialReadTask, 0, "serial-thread", NULL);
// AuxiliaryTask serialCommsTask = Bela_createAuxiliaryTask(serialReadTask, 0, "serial-thread", NULL);
gui.setup(context->projectName);
gui.setControlDataCallback(guiControlDataCallback, nullptr);
gGuiPipe.setup("guiControlPipe", 16384);
// Check Pd's version
int major, minor, bugfix;
return false;
return false;
gDigitalEnabled = 1;
char file[] = "_main.pd";
char folder[] = "./";
return false;
free(str);
// analog setup
printf("Audio channels in use: %d\n", context->audioOutChannels);
printf("Analog channels in use: %d\n", gAnalogChannelsInUse);
printf("Digital channels in use: %d\n", gDigitalChannelsInUse);
// Channel distribution
gFirstAnalogInChannel = std::max(context->audioInChannels, context->audioOutChannels);
gFirstAnalogOutChannel = gFirstAnalogInChannel;
gFirstDigitalChannel = gFirstAnalogInChannel + std::max(context->analogInChannels, context->analogOutChannels);
gLibpdDigitalChannelOffset = gFirstDigitalChannel + 1;
// Create receiverNames for digital channels
generateDigitalNames(gDigitalChannelsInUse, gLibpdDigitalChannelOffset, gReceiverInputNames, gReceiverOutputNames);
// digital setup
if(gDigitalEnabled)
if(gDigitalChannelsInUse > 0){
dcm.setCallbackArgument(ch, (void*) gReceiverInputNames[ch].c_str());
unsigned int n = 0;
if(newMidi)
++n;
} else {
dumpMidi();
return false;
libpd_set_listhook(Bela_listHook);
libpd_init();
gInBuf = get_sys_soundin();
gOutBuf = get_sys_soundout();
// start DSP:
// [; pd dsp 1(
libpd_start_message(1);
libpd_add_float(1.0f);
// Bind your receivers here
for(unsigned int i = 0; i < gDigitalChannelsInUse; i++)
libpd_bind(gReceiverOutputNames[i].c_str());
libpd_bind("bela_setMidi");
libpd_bind("bela_guiOut");
libpd_bind("bela_setGui");
#ifdef ENABLE_TRILL
libpd_bind("bela_setTrill");
// open patch:
if(gPatch == NULL){
return false;
pdMultiplexerActive = true;
sys_dontmanageio(1);
AuxiliaryTask fdTask;
fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", NULL);
dcm.setVerbose(false);
#ifdef ENABLE_TRILL
gTrillTask = Bela_createAuxiliaryTask(readTouchSensors, 51, "touchSensorRead", NULL);
gTrillPipe.setup("trillPipe", 1024);
// if(gEvo.initI2C_RW(gEvoI2cBus, gEvoI2cAddress, -1))
// return false; // wrong bus, or address out of range
// if(gEvo.readI2C()) //verify that we can read from the device
// return false; // ... or fail otherwise
// Bela_runAuxiliaryTask(evoReadTask, 50);
Bela_runAuxiliaryTask(serialReadTask, 50);
while(gGuiControlBuffers.size()) // this won't change within the loop, but it's good not to have to use a separate flag
static struct guiControlMessageHeader header;
static bool waitingForHeader = true;
if(waitingForHeader)
int ret = gGuiPipe.readRt(header);
if(1 != ret)
break;
else
waitingForHeader = false;
if(!waitingForHeader)
char payload[header.size];
int ret = gGuiPipe.readRt(&payload[0], header.size);
if(header.size != ret)
break;
const char* name = gGuiControlBuffers[header.id].c_str();
if('f' == header.type)
if(header.size != sizeof(float))
rt_fprintf(stderr, "Unexpected message length for float: %u\n", header.size);
continue;
float value = ((float*)payload)[0];
libpd_add_float(value);
libpd_finish_message("bela_guiControl", name);
if('s' == header.type)
libpd_symbol(name, payload);
for(auto& b : gGuiDataBuffers)
int id = b.id;
int size = b.size;
const char* name = b.name.c_str();
if(id < 0)
// initialize
size = libpd_arraysize(name);
if(size <= 0)
continue;
} else {
// this is thread-unsafe: what happens if this causes reallocation while the Gui thread is writing to a buffer?
id = gui.setBuffer('f', size);
b.id = id;
b.size = size;
DataBuffer& dataBuffer = gui.getDataBuffer(id);
// initialize gui buffer with the initial content of the array
libpd_read_array(dataBuffer.getAsFloat(), b.name.c_str(), 0, size);
DataBuffer& dataBuffer = gui.getDataBuffer(b.id);
libpd_write_array(b.name.c_str(), 0, dataBuffer.getAsFloat(), dataBuffer.getNumElements());
#ifdef ENABLE_TRILL
for(auto& name : gTrillAcks)
unsigned int idx = getIdxFromId(name.c_str(), gTouchSensors);
libpd_start_message(3);
libpd_add_symbol(Trill::getNameFromDevice(gTouchSensors[idx].second->deviceType()).c_str());
libpd_add_float(gTouchSensors[idx].second->getAddress());
libpd_add_symbol(Trill::getNameFromMode(gTouchSensors[idx].second->getMode()).c_str());
libpd_finish_message("bela_trillCreated", name.c_str());
gTrillAcks.resize(0);
bool doTrill = false;
for(auto& t : gTouchSensors)
if(Trill::NONE != t.second->deviceType())
doTrill = true;
break;
if(doTrill)
int idx;
while(gTrillPipe.readRt(idx) > 0)
Trill& touchSensor = *gTouchSensors[idx].second;
const char* sensorId = gTouchSensors[idx].first.c_str();
if(Trill::Device::NONE == touchSensor.deviceType())
continue;
const Trill::Mode mode = touchSensor.getMode();
if(Trill::DIFF == mode || Trill::RAW == mode || Trill::BASELINE == mode)
libpd_start_message(touchSensor.getNumChannels());
for(unsigned int n = 0; n < touchSensor.getNumChannels(); ++n)
libpd_add_float(touchSensor.rawData[n]);
} else if(Trill::CENTROID == mode)
if(touchSensor.is1D()) {
libpd_start_message(2 * touchSensor.getNumTouches() + 1);
libpd_add_float(touchSensor.getNumTouches());
for(int i = 0; i < touchSensor.getNumTouches(); i++) {
libpd_add_float(touchSensor.touchLocation(i));
libpd_add_float(touchSensor.touchSize(i));
} else if (touchSensor.is2D()) {
int numTouches = touchSensor.compoundTouchSize() > 0;
libpd_start_message(2 * numTouches + 1);
libpd_add_float(numTouches > 0);
if(numTouches)
libpd_add_float(touchSensor.compoundTouchHorizontalLocation());
libpd_add_float(touchSensor.compoundTouchLocation());
libpd_add_float(touchSensor.compoundTouchSize());
else
continue;
libpd_finish_message("bela_trill", sensorId);
static int count = 0;
unsigned int readIntervalSamples = touchSensorSleepInterval * context->audioSampleRate;
count += context->audioFrames;
if(count > readIntervalSamples)
Bela_scheduleAuxiliaryTask(gTrillTask);
count -= readIntervalSamples;
#ifdef PARSE_MIDI
int num;
switch(message.getType()){
case kmmNoteOn:
break;
case kmmNoteOff:
* with a velocity of 0.
break;
case kmmControlChange:
break;
case kmmProgramChange:
break;
break;
case kmmChannelPressure:
break;
case kmmPitchBend:
int value = ((message.getDataByte(1) << 7)| message.getDataByte(0)) - 8192;
break;
case kmmSystem:
int byte = channel | status;
break;
case kmmNone:
case kmmAny:
break;
#else
int input;
libpd_midibyte(port, input);
// static uint64_t evoLastSent = 0;
// if(context->audioFramesElapsed - evoLastSent > gEvoSendIntervalMs * 0.001f * context->audioSampleRate)
// libpd_float(gEvoReceiverName, gEvoValue);
// evoLastSent = context->audioFramesElapsed;
static uint64_t serialLastSent = 0;
if(context->audioFramesElapsed - serialLastSent > gSerialSendIntervalMs * 0.001f * context->audioSampleRate)
libpd_float(gSerialReceiverName, gSerialValue);
serialLastSent = context->audioFramesElapsed;
//audio input
memcpy(
gInBuf + n * gLibpdBlockSize,
// analog input
memcpy(
// multiplexed analog input
if(pdMultiplexerActive)
unsigned int j;
unsigned int k;
float* p0;
float* p1;
// digital input
if(gDigitalEnabled)
// digital in at message-rate
// digital in at signal-rate
// digital outputs
if(gDigitalEnabled)
// digital out at signal-rate
// scope output
gScopeOut[k] = *p1;
// audio output
memcpy(
//analog output
memcpy(
for(auto a : midi)
delete a;
#ifdef ENABLE_TRILL
for(auto t : gTouchSensors)
// t.first is a std::string, so the memory will be deallocated automatically
delete t.second;
libpd_closefile(gPatch);
delete [] gScopeOut;
right, so you have this:
if (ret > 0) {
What you should do in this function is to set gSerialValue
to the relevant value that you received from the UART and want to send to Pd. There is no need to call gSerial.write()
. What does the data that come from UART look like? Is it a string representing a number? Or an arbitrary string?
The UART data comes as in the GPS NMEA format as below:
$GPGGA,181908.00,3404.7041778,N,07044.3966270,
W,4,13,1.00,495.144,M,29.200,M,0.10,0000*40
When I print
"printf("Received: %.*s\n", ret, serialBuffer);"
I get the correct format in the IDE.
Not sure how to use that in gSerialValue though.
Do you have some code in Pd that already parses that or do you want to parse the string into discrete numbers in C++ and pass those into Pd?
I'm intending to parse that in Pd. But since I (assumingly) am not transmitting the right data, all I get from the receiving object in Pd is floats, for example:
print: 0
print: 28
print: 19
print: 48
print: 48
unpacking / routing these in Pd is not giving anything more.
Tree But since I (assumingly) am not transmitting the right data, all I get from the receiving object in Pd is floats, for example:
well the code as it is does that.
Tree I'm intending to parse that in Pd.
The way it currently is? Assuming you receive the full string in Pd, how do you split the long string with commas and no spaces into different words/numbers in Pd? That's why I am asking whether parsing in C++ would be easier ...
giuliomoro That's why I am asking whether parsing in C++ would be easier ...
I'll give this a try. thanks
so what you could do is parsing the received string from the auxiliary task and set several global variables. Then from render()
you either call libpd_float()
multiple times (each with a different receiver), or construct a list. Let me know if you need help.
giuliomoro why using libpd_symbol() instead of libpd_float() gives the error: no matching function for call to 'libpd_symbol' ?
libpd_symbol()
requires a char*
as the second argument:
int libpd_symbol(const char *recv, const char *symbol)
how are you calling it ?
//////before setup:
if (ret > 0) {
for(unsigned int n = 0; n < ret; ++n)
printf("Received buffer: %c\n", serialBuffer[n]);
gSerialValue = serialBuffer[n];
//////in render:
libpd_symbol(gSerialReceiverName, gSerialValue);
Well, if gSerialValue
is still a float
, then what you are doing is you are setting in turn to the value of each byte which is received from the UART. render()
will only see the latest value that it has been set to and that's pretty meaningless. A different approach would be to make serialBuffer
a global variable and use libpd_symbol(gSerialReceiverName, serialBuffer)
, however in this case you will occasionally send to Pd a corrupted string: if render()
runs halfway through a UART receive, the first part of the string will be from from the new reading and the second part of the string will be from the previous reading.
A more thread-safe approach is to use a Pipe
to send the string value from serialReadTask()
to render()
. In the Communication/Serial
example there is a Pipe
to send one character at a time from the AuxiliaryTask
to render()
. If the width of the string is constant, you can just create a std::array<char, 84>
at both ends of the pipe and pass data as follows:
Pipe gSerialPipe;
if (ret > 0) {
gSerialPipe.writeNonRt(serialBuffer, ret);
/// in setup()
gSerialPipe.setup("serialpipe", 1024);
/// in render()
size_t len = gSerialPipe.readRt(serialBuffer, maxLen);
if(len > 0) {
serialBuffer[len] = 0; // ensure the string is appropriately null-terminated, or the line below may crash
Thanks for the help @giuliomoro!
Is there any reason why my GPS module looses coordinates values as soon as I run the software? Does this code send anything back to the module via uart4?
as far as I can tell that code doesn't use UART at all. In the code I wrote above we are not writing via UART either, so I don't see how the code could be responsible of malfunctioning of the GPS module as it does not write to it.
Tree Is there any reason why my GPS module looses coordinates values as soon as I run the software?
Not sure what that means.
