ben_wizards
If you add this at the top of render.cpp
#include <I2c_Codec.h>
extern I2c_Codec *gAudioCodec;
then you should be able to write to the audio codec with
gAudioCodec->writeRegister(register, value)
(see some examples in core/I2c_Codec.cpp
Unfortunately anything you would do during setup would be overwritten by the actual codec initialization, so you should try to run it in an auxiliary task (which is scheduled from render()
), or do it at the first call to render()
, something like
static bool init = false;
if(init == false){
gAudioCodec->writeRegister(register, value);
init = true;
Also, a couple of notes on the snippets of code you posted above:
1) I am not sure what degree of precision you can expect from sinf_neon(rad)
when rad
is outside the range of 0
to 2*M_PI
. Even if the precision of the function is not an issue, you should always make sure you wrap the phase in order to avoid troubles with the finite precision of float
(e.g.: after a few seconds or minutes that your project is running, the frequency of the sinewave will change and eventually degrade to a DC signal).
2) in case you already are wrapping the phase between 0
and 2*M_PI
, then (sinf_neon(gphasex*3))/3*x
is NOT going to give you a sine wave, because gphasex*3
would be affected by the wrapping. The resulting wave will probably contain lots of high frequency and potentially cause aliasing.
Also, applying a filter in the digital domain is not likely to help much with aliasing, unless aliasing is concentrated in a band where you have no signal.
One last thing, the forum engine understands markdown, so when pasting your code you are encouraged to use backticks ( ` ) around it, so that it is displayed in a monospace character. For blocks of code, use three backticks ( ``` ) before and after, this also gives some sort of syntax highlighting and different background color.
