again, it seems like this project is not starting Pd at all ... maybe a corrupted file?
Try ls -l /root/Bela/project/ProjectName/ProjectName
if the size of the file is 0, then it surely is corrupted.
Either way, can you clean the project and try to build again? Also, what files are in the project? Is there a .cpp file? If there is, is it a custom render for libpd?
jestern77 journacltl -u bela_startup | cat doesn't work (command not found), you mean from the root directory right? I logged with ssh root@192.168.7.2 then used journacltl -u bela_startup | cat
uops! forgot an l:
journalctl -u bela_startup
Anyhow, it seems that the problem has nothing to do with it being run at boot, so no need to try this again until we get it to run ok in the IDE.
