yes
heavy on newest bela release
giuliomoro thanks, this works!
Did some tests for CPU usage with the three compilers. On a v0.3.6b image:
Techno-world:
heavy/gcc-6.3 25%
heavy/clang-3.9 21%
heavy/clang-6.0 24%
Your reverbtest patch:
heavy/gcc-6.3 16%
heavy/clang-3.9 18%
heavy/clang-6.0 16%
noting that, in both cases, clang-3.9
needs the fix above in order to run.
The fact that clang-6.0 is slower on techno-world
is pretty annoying, though.
giuliomoro interesting...
so that is the value, the IDE shows,or how do you measure? might need to check on my actual granular patch...
It's actually the value you see by doing
watch -n 0.5 cat /proc/xenomai/sched/stat
which is what the IDE grabs and displays. Running the above in the terminal is more lightweight than through the IDE, so you can run it even if the CPU usage is so high that the IDE is not responsive.
ok, so i notice something funny:
when the IDE is not running my patch is running at 69 to 70 %, when i run the IDE that value fluctuates from 58 to 70 %
The CPU usage indicator in the IDE takes into account all the threads of the program, and both their Xenomai CPU usage (as shown in /proc/xenomai/sched/stat
) and their Linux CPU usage (as shown by the top
command). So for instance, if you have the scope window open, and you are using the Scope, then the CPU usage will differ between the IDE and the terminal, but in the IDE it should be higher. So I don't think it makes sense to explain your case.
Is there anything in the patch that would change the CPU usage over time? Wanna send it over?
giuliomoro Is there anything in the patch that would change the CPU usage over time? Wanna send it over?
i don't think so. also when the IDE is not running the CPU usage stays the same all the time. note that i used the "watch" method in both cases (with and without IDE) to measure usage.
sure, i'll send the patch.
I have included the aligned new
allocator in the heavy template file on my repo : https://github.com/giuliomoro/hvcc/commit/35a5bda6063025e2fc99904e1c47702152924c08 so now the fix will be automatically applied to newly built projects. Also fixed behaviour (on the Bela side) when the expected MIDI interface is not connected (https://github.com/BelaPlatform/Bela/commit/19349c4760b03e19fb3dfd343b604cebd1c506f9 ).
As for the performance of your patch, it runs at about 26% for me, not sure if it's because I don't have any buttons/MIDI hooked up.
what? 26% with clang? which version? how could not connected buttons have an influence on cpu load? i will check out your repo and see. since i have a spare bela i can also try with a bareboard
that's clang-3.9
, stock compiler on the board. Maybe you still have some files that were built with -g -O0
above? -g
adds debugging info to the file, but -O0
disable all optimizations. Maybe try cleaning the project (delete the build/
folder in there, or equivalently run make -C ~/Bela PROJECT=projectName clean
and rebuild?
lokki ? how could not connected buttons have an influence on cpu load?
I don't know if there is something you do with buttons and MIDI that changes the CPU processing? Your patch is too complicated for me to understand it at a glance!
giuliomoro I don't know if there is something you do with buttons and MIDI that changes the CPU processing? Your patch is too complicated for me to understand it at a glance!
sorry, of course it is a mess actually
i only start writing to tables and change which tables are played back with the buttons. midi is only for note input to change playback speed and aftertouch to scroll through the table when in "scrub" mode. i am now recompiling with your new hvcc repo, and i will disconnect all midi controllers to see if it makes a difference in load. but my CPU was a steady 69 to 70 % regardless of any midi activity or button presses. that is why i was so astonished, the simple fact that a midi device and buttons are connected should not make that much of a difference.
EDIT: ahem stupid me i guess, should i be looking at the bela-audio load? that is as you suggested 26-28% i was looking at the ROOT process which takes 70%..
Every 0.5s: cat /proc/xenomai/sched/stat bela: Wed May 8 19:10:56 2019
CPU PID MSW CSW XSC PF STAT %CPU NAME
0 0 0 4353657 0 0 00018000 70.0 [ROOT]
0 1681 9 11 26 0 000600c0 0.0 granular
0 1691 2 3 4 0 000480c0 0.0 bela-midiIn_hw:0,0,0
0 1692 2 3 4 0 000480c0 0.0 bela-midiOut_hw:0,0,0
0 1693 5 761787 761794 0 00048046 28.1 bela-audio
0 0 0 2427976 0 0 00000000 0.7 [IRQ16: [timer]]
0 0 0 380980 0 0 00000000 0.7 [IRQ180: rtdm_pruss_irq_irq]
does that look reasonable? does ROOT just take all that is left to get to 100% then? (i seem to remember some discussion in the forum between you and thetechnobear where this came up as well)
lokki EDIT: ahem stupid me i guess, should i be looking at the bela-audio load? that is as you suggested 26-28% i was looking at the ROOT process which takes 70%..
Yes!
lokki ? does ROOT just take all that is left to get to 100% then?
yes. That is the time dedicated to Linux (including threads from your Bela program that run in secondary mode). For reference, if you were using 70% of the CPU for audio, the IDE would basically stop working, and commands on the terminal would be fairly sloppy.
ah good. sorry for the noise then
one more question regarding cpu load:
i get some underrun one block dropped messages when i run my patch. however i can never ever hear any dropouts, could those messages be wrong or am i just lucky i never hear them (maybe because all changes to table playback speed and direction only happen via a samplehold~ of the controlling phasor)
