AndyCap p.s. the bela version and uname still stay the same as before
That is expected: that's the version number of the image. Will change if you reflash it.
AndyCap An unexpected error happened while making your board salty
Actually now I remember that this happened the other day. Don't remember what the issue is, but I think it's all good.
Check the content of /root/.bela
That's expected behaviour, unfortunately: it only detects the hardware you are running on, not the "soft" configuration on top of that. We should change that, or add an option.
To check if it works, reboot and run a Bela project with --verbose , it should show Salt at some point!
