I have managed to boot it and install the new kernel, then I started looking at OpenGL. I had some vague memory I had already looked at this on the old image and had installed the TI stuff.
So I put in the "old" card and booted to see it that was the case and couldn't see anything, then I put in the new card and it wouldn't boot.
So at that point I flashed the card again and we are where we are now!
This is what we get booting from EMMC:
U-Boot SPL 2017.03-dirty (Nov 08 2017 - 18:25:49)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2017.03-dirty (Nov 08 2017 - 18:25:49 +0000)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
Reset Source: Power-on reset has occurred.
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
mmc_init: -95, time 13
** Bad device mmc 0 **
reading uEnv.txt
1696 bytes read in 5 ms (331.1 KiB/s)
booting from eMMC
initrd_file=uInitrd
legacy image
** Bad device mmc **
mmc_init: -95, time 12
So it looks like you are correct, I thought the EMMC was wiped but there is something there, I will wipe it now...
