Hi all,
I've just updated bela from the master branch,
I'm getting this error while trying to run the "hello world" from the pd examples,
if anyone has a clue about what's wrong I would really appreciate it
PD: the "sinetone" example from the code examples works ok
Build finished
linker error detected, set verbose build output in settings for details
Running project...
Linking....
/build/core/default_libpd_render.o
: In function `sendDigitalMessage(bool, unsigned int, void*)':
core/default_libpd_render.cpp:(.text+0x52c): undefined reference to `libpd_float'
./build/core/default_libpd_render.o: In function `Bela_messageHook(char const*, char const*, int, _atom*)':
core/default_libpd_render.cpp:(.text+0x5cc): undefined reference to `libpd_is_float'
core/default_libpd_render.cpp:(.text+0x5e0): undefined reference to `libpd_get_float'
core/default_libpd_render.cpp:(.text+0x66c): undefined reference to `libpd_is_symbol'
core/default_libpd_render.cpp:(.text+0x680): undefined reference to `libpd_get_symbol'
./build/core/default_libpd_render.o: In function `fdLoop(void*)':
core/default_libpd_render.cpp:(.text+0x8bc): undefined reference to `libpd_sys_microsleep'
./build/core/default_libpd_render.o: In function `setup':
core/default_libpd_render.cpp:(.text+0xca8): undefined reference to `libpd_blocksize'
core/default_libpd_render.cpp:(.text+0xcdc): undefined reference to `libpd_set_printhook'
core/default_libpd_render.cpp:(.text+0xce8): undefined reference to `libpd_set_floathook'
core/default_libpd_render.cpp:(.text+0xcf4): undefined reference to `libpd_set_messagehook'
core/default_libpd_render.cpp:(.text+0xd00): undefined reference to `libpd_set_noteonhook'
core/default_libpd_render.cpp:(.text+0xd0c): undefined reference to `libpd_set_controlchangehook'
core/default_libpd_render.cpp:(.text+0xd18): undefined reference to `libpd_set_programchangehook
'core/default_libpd_render.cpp:(.text+0xd24): undefined reference to `libpd_set_pitchbendhook'
core/default_libpd_render.cpp:(.text+0xd30): undefined reference to `libpd_set_aftertouchhook'
core/default_libpd_render.cpp:(.text+0xd3c): undefined reference to `libpd_set_polyaftertouchhook'
core/default_libpd_render.cpp:(.text+0xd48): undefined reference to `libpd_set_midibytehook'
core/default_libpd_render.cpp:(.text+0xd4c): undefined reference to `libpd_init'
core/default_libpd_render.cpp:(.text+0xd58): undefined reference to `libpd_add_to_search_path'
core/default_libpd_render.cpp:(.text+0xd64): undefined reference to `libpd_add_to_search_path'
core/default_libpd_render.cpp:(.text+0xd7c): undefined reference to `libpd_init_audio'
core/default_libpd_render.cpp:(.text+0xd88): undefined reference to `libpd_get_sys_soundin'
core/default_libpd_render.cpp:(.text+0xd90): undefined reference to `libpd_get_sys_soundout'
core/default_libpd_render.cpp:(.text+0xd9c): undefined reference to `libpd_start_message'
core/default_libpd_render.cpp:(.text+0xda4): undefined reference to `libpd_add_float'
core/default_libpd_render.cpp:(.text+0xdb8): undefined reference to `libpd_finish_message'
core/default_libpd_render.cpp:(.text+0xdf4): undefined reference to `libpd_bind'
core/default_libpd_render.cpp:(.text+0xe00): undefined reference to `libpd_bind'
core/default_libpd_render.cpp:(.text+0xe0c): undefined reference to `libpd_bind' core/default_libpd_render.cpp:(.text+0xe18): undefined reference to `libpd_bind' core/default_libpd_render.cpp:(.text+0xe24): undefined reference to `libpd_bind'
./build/core/default_libpd_render.o:core/default_libpd_render.cpp:(.text+0xe30): more undefined references to `libpd_bind' follow
core/default_libpd_render.cpp:(.text+0xec0): undefined reference to `libpd_openfile'
core/default_libpd_render.cpp:(.text+0xee8): undefined reference to `libpd_arraysize'
core/default_libpd_render.cpp:(.text+0xf18): undefined reference to `libpd_start_message'
core/default_libpd_render.cpp:(.text+0xf28): undefined reference to `libpd_add_float'
core/default_libpd_render.cpp:(.text+0xf40): undefined reference to `libpd_finish_message'
core/default_libpd_render.cpp:(.text+0xf58): undefined reference to `libpd_float'
./build/core/default_libpd_render.o: In function `render':core/default_libpd_render.cpp:(.text+0x13fc): undefined reference to `libpd_noteon'
core/default_libpd_render.cpp:(.text+0x1430): undefined reference to `libpd_noteon'
core/default_libpd_render.cpp:(.text+0x1454): undefined reference to `libpd_polyaftertouch'
core/default_libpd_render.cpp:(.text+0x1478): undefined reference to `libpd_controlchange'
core/default_libpd_render.cpp:(.text+0x1498): undefined reference to `libpd_programchange'
core/default_libpd_render.cpp:(.text+0x14b8): undefined reference to `libpd_aftertouch'
core/default_libpd_render.cpp:(.text+0x14e4): undefined reference to `libpd_pitchbend'
core/default_libpd_render.cpp:(.text+0x1504): undefined reference to `libpd_sysrealtime'
core/default_libpd_render.cpp:(.text+0x19c4): undefined reference to `libpd_write_array'
core/default_libpd_render.cpp:(.text+0x1b30): undefined reference to `libpd_process_sys'
./build/core/default_libpd_render.o: In function `cleanup':
core/default_libpd_render.cpp:(.text+0x21bc): undefined reference to `libpd_closefile'
clang-3.8: error: linker command failed with exit code 1 (use -v to see invocation)
make[6]: *** [/root/Bela/projects/exampleTempProject/exampleTempProject] Error 1
Bela stopped
