Ah! Thanks so much. That did it. Of course, I was running AT= on a project without any custom source files, so the compiler was never invoked at all :facepalm:
FYI, we have decided to use OSC for all the communication between the Touchkeys process and Pd. This simplifies things, and the actual MIDI on/off we require is just encapsulated in an OSC message automatically anyway.
As you suggested, I have edited the way the Mappings work to avoid unnecessary reallocation during a state change. My solution was to add a member MRPMapping* mrpMapping_; to the PianoKey class, which is pre-allocated when the class is instantiated. The mapping is simply reset() and engage()d when active, and disengage()d when idle. Seems to work well so far. That was certainly a good suggestion!
The next stage is seeing how it runs on the Bela, as is (likely extremely slow, if at all) and then seeing what we can strip out. My gut would be to look at the Scheduler classes first, and try to eliminate them. I think there is a chance that all actions (except for timeouts, obviously) could simply be performed immediately, without too much ill effect. We may not need timeouts at all, really, since we are not receiving from an OSC or MIDI device (other than sysex messages from the external audio routing hardware). If we do, then we could simply delegate only the timeout actions to the scheduler, and perform all other actions (mappings, mainly) immediately. It's a theory that is worth testing, at least.
Let me know if you have any more insights in to the matter, you've been more than helpful so far.
Edit: For reference/posterity, here's the final compile command:
g++ -std=c++14 -I/usr/local/include/libpd/ -I/home/juniper/Downloads/liblo-0.29 -I/home/juniper/Downloads/boost_1_69_0 -I/root/Bela/include -I/root/Bela/build/pru/ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -DNDEBUG -O3 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"Main.d" -MT"Main.o" -o "Main.o" "../Main.cpp"
