thanks so much for this!
i have the pd patch running ( a simple version with no sample switching etc.) ctlin 1 (mod wheel) controls the sample speed. it all works with an attached controller, but the sample is not loaded, instead it uses the "default sound" (the content i saved in the table in pd) EDIT: ahem, wait a minute, let me check something, i think i forgot to change the length for my sampler logic when loading the new table...hang on.
i have this render.cpp file:
____ _____ _ _
| __ )| ____| | / \
| _ \| _| | | / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/ \_\
http://bela.io
A project of the Augmented Instruments Laboratory within the
Centre for Digital Music at Queen Mary University of London.
http://www.eecs.qmul.ac.uk/~andrewm
(c) 2016 Augmented Instruments Laboratory: Andrew McPherson,
Astrid Bin, Liam Donovan, Christian Heinrichs, Robert Jack,
Giulio Moro, Laurel Pardue, Victor Zappi. All rights reserved.
The Bela software is distributed under the GNU Lesser General Public License
(LGPL 3.0), available here: https://www.gnu.org/licenses/lgpl-3.0.txt
#include <Midi.h>
#include <Scope.h>
#include <cmath>
#include <Heavy_bela.h>
#include <string.h>
#include <stdlib.h>
#include <string.h>
#include <SampleLoader.h>
#include <SampleData.h>
// Bela Midi
static Midi midi;
unsigned int hvMidiHashes[7];
unsigned int gScopeChannelsInUse;
float* gScopeOut;
// Bela Scope
static Scope* scope = NULL;
* HEAVY CONTEXT & BUFFERS
HeavyContextInterface *gHeavyContext;
float *gHvInputBuffers = NULL, *gHvOutputBuffers = NULL;
unsigned int gHvInputChannels = 0, gHvOutputChannels = 0;
uint32_t multiplexerTableHash;
float gInverseSampleRate;
* HEAVY FUNCTIONS
// TODO: rename this
#define LIBPD_DIGITAL_OFFSET 11 // digitals are preceded by 2 audio and 8 analogs (even if using a different number of analogs)
void printHook(HeavyContextInterface *context, const char *printLabel, const char *msgString, const HvMessage *msg) {
const double timestampSecs = ((double) hv_msg_getTimestamp(msg)) / hv_getSampleRate(context);
rt_printf("Message from Heavy patch: [@ %.3f] %s: %s\n", timestampSecs, printLabel, msgString);
// digitals
hv_sendFloatToReceiver(gHeavyContext, hv_stringToHash((char*)receiverName), (float)state);
// rt_printf("%s: %d\n", (char*)receiverName, state);
// TODO: turn them into hv hashes and adjust sendDigitalMessage accordingly
char hvDigitalInHashes[16][21]={
{"bela_digitalIn11"},{"bela_digitalIn12"},{"bela_digitalIn13"},{"bela_digitalIn14"},{"bela_digitalIn15"},
{"bela_digitalIn16"},{"bela_digitalIn17"},{"bela_digitalIn18"},{"bela_digitalIn19"},{"bela_digitalIn20"},
{"bela_digitalIn21"},{"bela_digitalIn22"},{"bela_digitalIn23"},{"bela_digitalIn24"},{"bela_digitalIn25"},
{"bela_digitalIn26"}
// For a message to be received here, you need to use the following syntax in Pd:
// [send receiverName @hv_param]
static void sendHook(
const char *receiverName,
hv_uint32_t sendHash,
const HvMessage *m) {
// Bela digital run-time messages
// TODO: this first block is almost an exact copy of libpd's code, should we add this to the class?
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between 11 and 26
static const int prefixLength = 15; // strlen("bela_digitalOut")
if(strncmp(receiverName, "bela_digitalOut", prefixLength)==0){
if(receiverName[prefixLength] != 0){ //the two ifs are used instead of if(strlen(source) >= prefixLength+2)
if(receiverName[prefixLength + 1] != 0){
int receiver = ((receiverName[prefixLength] - '0') * 10);
receiver += (receiverName[prefixLength+1] - '0');
unsigned int channel = receiver - LIBPD_DIGITAL_OFFSET; // go back to the actual Bela digital channel number
bool value = (hv_msg_getFloat(m, 0) != 0.0f);
if(channel < 16){ //16 is the hardcoded value for the number of digital channels
dcm.setValue(channel, value);
return;
// Bela digital initialization messages
switch (sendHash) {
case 0x70418732: { // bela_setDigital
// Third argument (optional) can be ~ or sig for signal-rate, message-rate otherwise.
// [in 14 ~(
// [s bela_setDigital]
bool disable = false;
if (!(hv_msg_isSymbol(m, 0) && hv_msg_isFloat(m, 1))) return;
const char *symbol = hv_msg_getSymbol(m, 0);
direction = INPUT;
direction = OUTPUT;
disable = true;
} else {
return;
int channel = hv_msg_getFloat(m, 1) - LIBPD_DIGITAL_OFFSET;
if(disable == true){
dcm.unmanage(channel);
return;
if(hv_msg_isSymbol(m, 2)){
const char *s = hv_msg_getSymbol(m, 2);
if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
isMessageRate = false;
break;
case 0xEC6DA2AF: { // bela_noteout
if (!hv_msg_hasFormat(m, "fff")) return;
midi_byte_t pitch = (midi_byte_t) hv_msg_getFloat(m, 0);
midi_byte_t velocity = (midi_byte_t) hv_msg_getFloat(m, 1);
midi_byte_t channel = (midi_byte_t) hv_msg_getFloat(m, 2);
rt_printf("noteon: %d %d %d\n", channel, pitch, velocity);
midi.writeNoteOn(channel, pitch, velocity);
break;
case 0xD44F9083: { // bela_ctlout
midi_byte_t value = (midi_byte_t) hv_msg_getFloat(m, 0);
midi_byte_t controller = (midi_byte_t) hv_msg_getFloat(m, 1);
rt_printf("controlchange: %d %d %d\n", channel, controller, value);
midi.writeControlChange(channel, controller, value);
break;
case 0x6A647C44: { // bela_pgmout
if (!hv_msg_hasFormat(m, "ff")) return;
midi_byte_t program = (midi_byte_t) hv_msg_getFloat(m, 0);
midi_byte_t channel = (midi_byte_t) hv_msg_getFloat(m, 1);
rt_printf("programchange: %d %d\n", channel, program);
midi.writeProgramChange(channel, program);
break;
case 0x545CDF50: { // bela_bendout
unsigned int value = ((midi_byte_t) hv_msg_getFloat(m, 0)) + 8192;
rt_printf("pitchbend: %d %d\n", channel, value);
midi.writePitchBend(channel, value);
break;
case 0xDE18F543: { // bela_touchout
midi_byte_t pressure = (midi_byte_t) hv_msg_getFloat(m, 0);
rt_printf("channelPressure: %d %d\n", channel, pressure);
midi.writeChannelPressure(channel, pressure);
break;
case 0xAE8E3B2D: { // bela_polytouchout
midi_byte_t pressure = (midi_byte_t) hv_msg_getFloat(m, 1);
rt_printf("polytouch: %d %d %d\n", channel, pitch, pressure);
midi.writePolyphonicKeyPressure(channel, pitch, pressure);
break;
case 0x51CD8FE2: { // bela_midiout
midi_byte_t byte = (midi_byte_t) hv_msg_getFloat(m, 0);
int port = (int) hv_msg_getFloat(m, 1);
midi.writeOutput(byte);
break;
default: break;
* SETUP, RENDER LOOP & CLEANUP
// leaving this here, trying to come up with a coherent interface with libpd.
// commenting them out so the compiler does not warn
// 2 audio + (up to)8 analog + (up to) 16 digital + 4 scope outputs
//static const unsigned int gChannelsInUse = 30;
//static unsigned int gAnalogChannelsInUse = 8; // hard-coded for the moment, TODO: get it at run-time from hv_context
//static const unsigned int gFirstAnalogChannel = 2;
static const unsigned int gFirstDigitalChannel = 10;
static const unsigned int gFirstScopeChannel = 26;
static unsigned int gDigitalSigInChannelsInUse;
static unsigned int gDigitalSigOutChannelsInUse;
if(context->audioInChannels != context->audioOutChannels ||
context->analogInChannels != context->analogOutChannels){
// It should actually work, but let's test it before releasing it!
fprintf(stderr, "Error: TODO: a different number of channels for inputs and outputs is not yet supported\n");
return false;
/* HEAVY */
hvMidiHashes[kmmNoteOn] = hv_stringToHash("__hv_notein");
// hvMidiHashes[kmmNoteOff] = hv_stringToHash("noteoff"); // this is handled differently, see the render function
hvMidiHashes[kmmControlChange] = hv_stringToHash("__hv_ctlin");
// Note that the ones below are not defined by Heavy, but they are here for (wishing) forward-compatibility
// You need to receive from the corresponding symbol in Pd and unpack the message, e.g.:
//[r __hv_pgmin]
//[unpack f f]
//| [print pgmin_channel]
//[print pgmin_number]
hvMidiHashes[kmmProgramChange] = hv_stringToHash("__hv_pgmin");
hvMidiHashes[kmmPolyphonicKeyPressure] = hv_stringToHash("__hv_polytouchin");
hvMidiHashes[kmmChannelPressure] = hv_stringToHash("__hv_touchin");
hvMidiHashes[kmmPitchBend] = hv_stringToHash("__hv_bendin");
gHeavyContext = hv_bela_new_with_options(context->audioSampleRate, 10, 2, 0);
gHvInputChannels = hv_getNumInputChannels(gHeavyContext);
gHvOutputChannels = hv_getNumOutputChannels(gHeavyContext);
// add the lines below
char fileName[] = "sample0.wav";
int sampleLen = getNumFrames(fileName);
hv_uint32_t tableHash = hv_stringToHash("sample-table0");
hv_table_setLength(gHeavyContext, tableHash, sampleLen); // resize the table
float * table = hv_table_getBuffer(gHeavyContext, tableHash); // once resized, get a pointer to the array
int channel = 0; // take the first channel of the file
int startFrame = 0; // start from the beginning
int lastFrame = sampleLen; // until the end of the file
getSamples(fileName, table, channel, startFrame, lastFrame);
gScopeChannelsInUse = gHvOutputChannels > gFirstScopeChannel ?
gHvOutputChannels - gFirstScopeChannel : 0;
gDigitalSigInChannelsInUse = gHvInputChannels > gFirstDigitalChannel ?
gHvInputChannels - gFirstDigitalChannel : 0;
gDigitalSigOutChannelsInUse = gHvOutputChannels > gFirstDigitalChannel ?
gHvOutputChannels - gFirstDigitalChannel - gScopeChannelsInUse: 0;
printf("Starting Heavy context with %d input channels and %d output channels\n",
gHvInputChannels, gHvOutputChannels);
printf("Channels in use:\n");
printf("Digital in : %u, Digital out: %u\n", gDigitalSigInChannelsInUse, gDigitalSigOutChannelsInUse);
printf("Scope out: %u\n", gScopeChannelsInUse);
if(gHvInputChannels != 0) {
gHvInputBuffers = (float *)calloc(gHvInputChannels * context->audioFrames,sizeof(float));
if(gHvOutputChannels != 0) {
gHvOutputBuffers = (float *)calloc(gHvOutputChannels * context->audioFrames,sizeof(float));
// Set heavy print hook
hv_setPrintHook(gHeavyContext, printHook);
// Set heavy send hook
hv_setSendHook(gHeavyContext, sendHook);
midi.readFrom("hw:1,0,0");
midi.writeTo("hw:1,0,0");
midi.enableParser(true);
if(gScopeChannelsInUse > 0){
#if __clang_major__ == 3 && __clang_minor__ == 8
fprintf(stderr, "Scope currently not supported when compiling heavy with clang3.8, see #265 https://github.com/BelaPlatform/Bela/issues/265. You should specify `COMPILER gcc;` in your Makefile options\n");
exit(1);
#endif
scope = new Scope();
scope->setup(gScopeChannelsInUse, context->audioSampleRate);
// Bela digital
if(context->digitalChannels > 0){
for(unsigned int ch = 0; ch < context->digitalChannels; ++ch){
dcm.setCallbackArgument(ch, hvDigitalInHashes[ch]);
// unlike libpd, no need here to bind the bela_digitalOut.. receivers
// but make sure you do something like [send receiverName @hv_param]
// when you want to send a message from Heavy to the wrapper.
multiplexerTableHash = hv_stringToHash(multiplexerArray);
if(context->multiplexerChannels > 0){
pdMultiplexerActive = true;
hv_table_setLength(gHeavyContext, multiplexerTableHash, multiplexerArraySize);
hv_sendFloatToReceiver(gHeavyContext, hv_stringToHash("bela_multiplexerChannels"), context->multiplexerChannels);
int num;
while((num = midi.getParser()->numAvailableMessages()) > 0){
message = midi.getParser()->getNextChannelMessage();
switch(message.getType()){
case kmmNoteOn: {
//message.prettyPrint();
// rt_printf("message: noteNumber: %f, velocity: %f, channel: %f\n", noteNumber, velocity, channel);
hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmNoteOn], 0, "fff",
(float)noteNumber, (float)velocity, (float)channel+1);
break;
case kmmNoteOff: {
* with a velocity of 0.
// note we are sending the below to hvHashes[kmmNoteOn] !!
(float)noteNumber, (float)0, (float)channel+1);
break;
case kmmControlChange: {
hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmControlChange], 0, "fff",
(float)value, (float)controller, (float)channel+1);
break;
case kmmProgramChange: {
hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmProgramChange], 0, "ff",
(float)program, (float)channel+1);
break;
case kmmPolyphonicKeyPressure: {
//TODO: untested, I do not have anything with polyTouch... who does, anyhow?
hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmPolyphonicKeyPressure], 0, "fff",
(float)channel+1, (float)pitch, (float)value);
break;
case kmmChannelPressure:
hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmChannelPressure], 0, "ff",
(float)value, (float)channel+1);
break;
case kmmPitchBend:
int value = ((message.getDataByte(1) << 7) | message.getDataByte(0));
hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmPitchBend], 0, "ff",
break;
case kmmNone:
case kmmAny:
break;
// De-interleave the data
if(gHvInputBuffers != NULL) {
for(unsigned int ch = 0; ch < gHvInputChannels; ch++) {
if(ch >= context->audioInChannels+context->analogInChannels) {
// THESE ARE PARAMETER INPUT 'CHANNELS' USED FOR ROUTING
// 'sensor' outputs from routing channels of dac~ are passed through here
break;
} else {
// If more than 2 ADC inputs are used in the pd patch, route the analog inputs
// i.e. ADC3->analogIn0 etc. (first two are always audio inputs)
if(ch >= context->audioInChannels) {
int m = n/2;
float mIn = context->analogIn[m*context->analogInChannels + (ch-context->audioInChannels)];
gHvInputBuffers[ch * context->audioFrames + n] = mIn;
} else {
gHvInputBuffers[ch * context->audioFrames + n] = context->audioIn[n * context->audioInChannels + ch];
if(pdMultiplexerActive){
memcpy(hv_table_getBuffer(gHeavyContext, multiplexerTableHash), (float *const)context->multiplexerAnalogIn, multiplexerArraySize * sizeof(float));
// Bela digital in
// note: in multiple places below we assume that the number of digital frames is same as number of audio
// Bela digital in at message-rate
dcm.processInput(context->digital, context->digitalFrames);
// Bela digital in at signal-rate
if(gDigitalSigInChannelsInUse > 0)
unsigned int j, k;
float *p0, *p1;
const unsigned int gLibpdBlockSize = context->audioFrames;
const unsigned int audioFrameBase = 0;
float* gInBuf = gHvInputBuffers;
// block below copy/pasted from libpd, except
// 16 has been replaced with gDigitalSigInChannelsInUse
unsigned int digitalFrame = audioFrameBase + j;
k < gDigitalSigInChannelsInUse; ++k, p1 += gLibpdBlockSize) {
// replacement for bang~ object
//hv_sendMessageToReceiverV(gHeavyContext, "bela_bang", 0.0f, "b");
hv_processInline(gHeavyContext, gHvInputBuffers, gHvOutputBuffers, context->audioFrames);
for(int n = 0; n < context->audioFrames*gHvOutputChannels; ++n)
printf("%.3f, ", gHvOutputBuffers[n]);
if(n % context->audioFrames == context->audioFrames - 1)
printf("\n");
// Bela digital out
// Bela digital out at signal-rate
if(gDigitalSigOutChannelsInUse > 0)
unsigned int j, k;
float *p0, *p1;
float* gOutBuf = gHvOutputBuffers;
// context->digitalChannels has been replaced with gDigitalSigOutChannelsInUse
unsigned int digitalFrame = (audioFrameBase + j);
k < gDigitalSigOutChannelsInUse; k++, p1 += gLibpdBlockSize) {
// Bela digital out at message-rate
dcm.processOutput(context->digital, context->digitalFrames);
// Bela scope
unsigned int j, k;
float *p0, *p1;
gScopeOut[k] = *p1;
scope->log(gScopeOut);
// Interleave the output data
if(gHvOutputBuffers != NULL) {
for(unsigned int ch = 0; ch < gHvOutputChannels; ch++) {
if(ch >= context->audioOutChannels+context->analogOutChannels) {
// THESE ARE SENSOR OUTPUT 'CHANNELS' USED FOR ROUTING
// they are the content of the 'sensor output' dac~ channels
} else {
if(ch >= context->audioOutChannels) {
int m = n/2;
context->analogOut[m * context->analogOutChannels + (ch-context->audioOutChannels)] = gHvOutputBuffers[ch*context->audioFrames + n];
} else {
context->audioOut[n * context->audioOutChannels + ch] = gHvOutputBuffers[ch * context->audioFrames + n];
hv_delete(gHeavyContext);
free(gHvInputBuffers);
free(gHvOutputBuffers);
delete[] gScopeOut;
delete scope;
i have uploaded the sample0.wav file to resources in the IDE and it compiles fine. any ideas?
here is the PD-Patch:
#N canvas 262 157 1019 709 12;
#X obj 84 457 hip~ 5;
#X obj 2 124 phasor~;
#X obj 34 167 *~;
#X floatatom 4 6 4 0 0 0 speed - -, f 4;
#X obj 79 483 dac~;
#X obj 34 65 / 44100;
#X obj 0 99 /;
#X obj 84 402 +~;
#X obj 42 32 t b f;
#X obj 5 33 f;
#X obj 241 113 *;
#X obj 221 74 f;
#X floatatom 212 -30 5 0 127 0 endpos - -, f 5;
#X obj 211 12 t b f, f 7;
#X obj 128 139 -;
#X obj 117 116 f;
#X obj 151 116 t b f;
#X obj 117 90 *;
#X obj 109 62 f;
#X floatatom 94 -29 5 0 127 0 startpos - -, f 5;
#X obj 107 31 t b f, f 7;
#X obj 164 -84 r samplelength;
#X obj 302 -106 loadbang;
#X obj 84 425 tabread4~ sample-table0;
#X obj 302 -23 s samplelength;
#X msg 303 -50 100;
#X obj 212 -11 / 127;
#X obj 108 8 / 127;
#X msg 301 -82 127;
#X obj 9 -51 / 20;
#X obj 10 -90 ctlin 1 1;
#X obj 515 -2 table sample-table0;
#X connect 0 0 4 0;
#X connect 0 0 4 1;
#X connect 1 0 2 0;
#X connect 2 0 7 0;
#X connect 3 0 9 0;
#X connect 5 0 6 1;
#X connect 6 0 1 0;
#X connect 7 0 23 0;
#X connect 8 0 9 0;
#X connect 8 1 5 0;
#X connect 9 0 6 0;
#X connect 10 0 7 1;
#X connect 10 0 16 0;
#X connect 11 0 10 0;
#X connect 12 0 26 0;
#X connect 13 0 11 0;
#X connect 13 1 10 1;
#X connect 14 0 8 0;
#X connect 14 0 2 1;
#X connect 15 0 14 0;
#X connect 16 0 15 0;
#X connect 16 1 14 1;
#X connect 17 0 15 0;
#X connect 18 0 17 0;
#X connect 19 0 27 0;
#X connect 20 0 18 0;
#X connect 20 1 17 1;
#X connect 21 0 11 0;
#X connect 21 0 18 0;
#X connect 22 0 28 0;
#X connect 22 0 25 0;
#X connect 23 0 0 0;
#X connect 25 0 24 0;
#X connect 26 0 13 0;
#X connect 27 0 20 0;
#X connect 28 0 12 0;
#X connect 29 0 3 0;
#X connect 30 0 29 0;
thanks so much for your help!
