can this be made to work? or is it not current functionality in the SC interface?
I saw that pure-date uses [dac~ 27 28 29 30]
so wrongly thought perhaps Out.ar(27,sig) might work, but alas no.... (it seems)
basically the number of hardware outputs is dictated by:
s.options.numOutputBusChannels = 2; // Use only the L/R audio channels
but if you increase this, then the it basically assigned the analog out to the pins
i.e. for =4, you get Out(3,...) = analog out 0, out(4,...) = analog out 1
so i guess this requires SC development, perhaps a Scope ugen?
