I have had puredata up and running before, but for some reason it isn't working now when I run any of the examples. At some point I updated the IDE, don't know if that could have done something wrong?
The "about bela" says "Bela Version 0.2.1, August 2017". I've never changed the image since I got it last year.
I'm on OSX 10.12.6
Here's the log output:
Linking..../build/core/default_libpd_render.o: In function sendDigitalMessage(bool, unsigned int, void*)':core/default_libpd_render.cpp:(.text+0x52c): undefined reference tolibpd_float'./build/core/default_libpd_render.o: In function Bela_messageHook(char const*, char const*, int, _atom*)':core/default_libpd_render.cpp:(.text+0x5cc): undefined reference tolibpd_is_float'core/default_libpd_render.cpp🙁.text+0x5e0): undefined reference to libpd_get_float'core/default_libpd_render.cpp:(.text+0x66c): undefined reference tolibpd_is_symbol'core/default_libpd_render.cpp🙁.text+0x680): undefined reference to libpd_get_symbol'./build/core/default_libpd_render.o: In functionfdLoop(void)':core/default_libpd_render.cpp🙁.text+0x8bc): undefined reference to libpd_sys_microsleep'./build/core/default_libpd_render.o: In functionsetup':core/default_libpd_render.cpp🙁.text+0xca8): undefined reference to libpd_blocksize'core/default_libpd_render.cpp:(.text+0xcdc): undefined reference tolibpd_set_printhook'core/default_libpd_render.cpp🙁.text+0xce8): undefined reference to libpd_set_floathook'core/default_libpd_render.cpp:(.text+0xcf4): undefined reference tolibpd_set_messagehook'core/default_libpd_render.cpp🙁.text+0xd00): undefined reference to libpd_set_noteonhook'core/default_libpd_render.cpp:(.text+0xd0c): undefined reference tolibpd_set_controlchangehook'core/default_libpd_render.cpp🙁.text+0xd18): undefined reference to libpd_set_programchangehook'core/default_libpd_render.cpp:(.text+0xd24): undefined reference tolibpd_set_pitchbendhook'core/default_libpd_render.cpp🙁.text+0xd30): undefined reference to libpd_set_aftertouchhook'core/default_libpd_render.cpp:(.text+0xd3c): undefined reference tolibpd_set_polyaftertouchhook'core/default_libpd_render.cpp🙁.text+0xd48): undefined reference to libpd_set_midibytehook'core/default_libpd_render.cpp:(.text+0xd4c): undefined reference tolibpd_init'core/default_libpd_render.cpp🙁.text+0xd58): undefined reference to libpd_add_to_search_path'core/default_libpd_render.cpp:(.text+0xd64): undefined reference tolibpd_add_to_search_path'core/default_libpd_render.cpp🙁.text+0xd7c): undefined reference to libpd_init_audio'core/default_libpd_render.cpp:(.text+0xd88): undefined reference tolibpd_get_sys_soundin'core/default_libpd_render.cpp🙁.text+0xd90): undefined reference to libpd_get_sys_soundout'core/default_libpd_render.cpp:(.text+0xd9c): undefined reference tolibpd_start_message'core/default_libpd_render.cpp🙁.text+0xda4): undefined reference to libpd_add_float'core/default_libpd_render.cpp:(.text+0xdb8): undefined reference tolibpd_finish_message'core/default_libpd_render.cpp🙁.text+0xdf4): undefined reference to libpd_bind'core/default_libpd_render.cpp:(.text+0xe00): undefined reference tolibpd_bind'core/default_libpd_render.cpp🙁.text+0xe0c): undefined reference to libpd_bind'core/default_libpd_render.cpp:(.text+0xe18): undefined reference tolibpd_bind'core/default_libpd_render.cpp🙁.text+0xe24): undefined reference to libpd_bind'./build/core/default_libpd_render.o:core/default_libpd_render.cpp:(.text+0xe30): more undefined references tolibpd_bind' follow./build/core/default_libpd_render.o: In function setup':core/default_libpd_render.cpp:(.text+0xec0): undefined reference tolibpd_openfile'core/default_libpd_render.cpp🙁.text+0xee8): undefined reference to libpd_arraysize'core/default_libpd_render.cpp:(.text+0xf18): undefined reference tolibpd_start_message'core/default_libpd_render.cpp🙁.text+0xf28): undefined reference to libpd_add_float'core/default_libpd_render.cpp:(.text+0xf40): undefined reference tolibpd_finish_message'core/default_libpd_render.cpp🙁.text+0xf58): undefined reference to libpd_float'./build/core/default_libpd_render.o: In functionrender':core/default_libpd_render.cpp🙁.text+0x13fc): undefined reference to libpd_noteon'core/default_libpd_render.cpp:(.text+0x1430): undefined reference tolibpd_noteon'core/default_libpd_render.cpp🙁.text+0x1454): undefined reference to libpd_polyaftertouch'core/default_libpd_render.cpp:(.text+0x1478): undefined reference tolibpd_controlchange'core/default_libpd_render.cpp🙁.text+0x1498): undefined reference to libpd_programchange'core/default_libpd_render.cpp:(.text+0x14b8): undefined reference tolibpd_aftertouch'core/default_libpd_render.cpp🙁.text+0x14e4): undefined reference to libpd_pitchbend'core/default_libpd_render.cpp:(.text+0x1504): undefined reference tolibpd_sysrealtime'core/default_libpd_render.cpp🙁.text+0x19c4): undefined reference to libpd_write_array'core/default_libpd_render.cpp:(.text+0x1b30): undefined reference tolibpd_process_sys'./build/core/default_libpd_render.o: In function cleanup':core/default_libpd_render.cpp:(.text+0x21bc): undefined reference tolibpd_closefile'clang-3.8: error: linker command failed with exit code 1 (use -v to see invocation)make: ** [/root/Bela/projects/exampleTempProject/exampleTempProject] Error 1Bela stopped
Code tags seemed to crop the text somehow, so it looks pretty weird i know. sorry
