giuliomoro Hi, it returns something new.
root@bela:~# make -C ~/Bela EXAMPLE=01-Basics/minimal CL="--verbose --board CtagFace" run
make: Entering directory '/root/Bela'
No process to kill
Building render.cpp...
...done
Linking...
...done
Running /root/Bela/projects/exampleTempProject/exampleTempProject --verbose --board CtagFace
Starting with period size 16 ;analog enabled
DAC level 0.000000 dB; ADC level -6.000000 dB; headphone level -6.000000 dB
Detected hardware: CtagFaceBela
User input: CtagFace
Hardware to be used: CtagFace
PRU memory mapped to ARM:
digital: 0xb60c3000 0xb60c3400
audio: 0xb60c4000 0xb60c4100 0xb60c4200 0xb60c4280
analog: (nil) (nil) (nil) (nil)
analog offset: 0x49f3e000 0x49f3e000 0x49f3e000 0x49f3e000
Using embedded PRU code
_________________Audio Thread!
PRU interrupt timeout, -1 110 Connection timed out
audio frame 32, errorCode: 1
PRU event loop timed out
audio frame 64, errorCode: 1
The PRU stopped responding. Is the light still blinking? It would be very helpful if you could send the output of the `dmesg` command to the developers to help track down the issue. Quitting.
Makefile:515: recipe for target 'runonly' failed
make: *** [runonly] Error 1
