What would be the preferred process for importing new UGens into the Bela?
I have a prototyped plugin I've written, that I'd like to test with Bela. Am I correct in saying that the Bela image (0.3.2) as distributed doesn't contain the full sc source required to build the plugin? (I did a search for some files in the sc source and they didn't show up).
If so, my question is: would it be preferable to
(a) download the sc source code to the Bela in order to compile from my plugin source 'in situ'? Or,
(b) compile from my source on a different linux machine, then import the files into the appropriate plugin and helpfile directories on the Bela?
I'm fairly new to this sort of low level stuff, so all reasoning/explanations wold be good to hear!
