Hi Giulio and bela team!
I have recently to change the PCB and switch to another minibela from my current instrument and it seems that my OLED doesn't work anymore. I usually have it running on boot to print messages on my instrument. When I try to run the patch I get this message:
'opened i2c file 3
set i2c addr 3c
OscReceiver: Unable to initialise UDP socket: 98 Address already in use'
I am not sure what it means since I haven't changed the code myself. I have only replace the minibela and its PCB
Important info:
- The OLED screen is beeing recognized on the same adress as 1x3c
- I had to patches on the project folder for OLED , I disable both of them to try to tun manually. This trial didnt work as well.
- the new minibela had already some OLED code running on background, but I changed to the current SD card of my isntrument.
