Hi, I've got some issue with the [netsend] module on Bela Mini- from what I've observed so far the situation is as follows:
I run Bela Mini in standalone mode (i.e. not connected to the laptop) and I'm using a wifi dongle to connect to a network. Pure Data patch sends out some data in OSC protocol via [netsend]. Every now and then the whole patch restarts. My suspicion is that it happens due to the loss of connection to the network - the patch crashes when I try to send out some data via OSC (e.g. I press a button which sends a midi note number). The only time it happend while Bela was connected to the laptop, there was some info printed out in the IDE console, but I've neglected to copy it (when I'm trying to recreate the situation now with Bela connected to the laptop, strangely it doesn't happen, even if I turn off the wifi router to which Bela is connected). So I don't have any report from the console that I could post here, unfortunately.
The main question, though, is as follows: is there a way to make [netsend] behave the same way it does when Pd runs on a laptop - i.e. when the device disconnects from the network, rather than crash, [netsend] sends "0" to it's left outlet, which could be used to try and reestablish the connection? I don't mind if I loose snippets of OSC data every now and then, but a crash and a restart is a major problem for me.
