I have 8 1k slide potentiometers running on 8 out of 16 channels of a multiplexer cap (all connected to 5v and ground on a bela rev a2 05/16), the readings are somewhat responsive but there seems to be some crosstalk from the channel values on the console (on multiplexer capelet pd example).
when 0.0 channel slider is all the way up (peak value at ~ 0.017)
when 0.0 and 0.1 // (channel 1,2 peak at ~ 0.019)
when 0.0, 0.1, 1.0 // (channel 1, 2, 3 peak at ~ 0.022)
when 0.0, 0.1, 1.0, 1.1 // (// 1,2,3,4 peak at ~ 0.027)
when 0.0, 0.1, 1.0, 1.1, 2.0 // (// 1,2,3,4,5 peak at ~ 0.037)
when 0.0, 0.1, 1.0, 1.1, 2.0, 2.1 // (// 1,2,3,4,5, 6 peak at ~ 0.053)
and so forth... basically all values get lifted every time a new channel reaches its maximum value.
what would be a workaround over this issue?
cheers.
