Hereโs the click overlay... so we can see pins (possibly) used.
from here
Most of the WiFi cards seems to use UART.
( I think they also used AN/RST, which are P1 p2&4, which I think is clashing with PRU1 (9/11)? so that might be an issue ... Im a bit confused about what light blue means... does it mean you can disable, but you 'lose features'?)
so seems the uart would be fine, as long as you just position 1, and uart4
generally looks like you'll get a few different options depending which position you used, seems like bela does not clash with the P2 connections, but does clash with P1
note: to be clear, click in pos 2 is fig 45 rotated 180 degrees, i.e. AN/PWN point to the outside of the board in both positions
this means whilst in pos1 you cannot use SPI (as it would be SPI0) , in pos2 you can since its using SPI1, similarly you use UART4 (Pos1) or UART0(pos2)
Anyway will look deeper once my BelaMini arrives ๐
I guess it should be possible to come up with a list of click boards that are compatible with belamini which might be quite useful for users.
EDIT: feel free to move this questions to a new topic, if you prefer to keep this for more belamini announcement type posts, rather than technical.
