Sorry, I hoped to finalize the new I2c class over the weekend. Didn't happen. If you update your board with the instructions above, you will have a mostly working I2c class.
There is C++ example of I2c communication for the MPR121 sensor in examples/06-Sensors/capacitive-touch/.
This does not use the new I2cRt class, but maintains its own I/O loop in a separate thread/
There is also an example Pd patch, if writing user-space I2c drivers from PureData is your thing! The core/default_libpd_render.cpp is the backend for this Pd-I2c, and exemplifies the use of the I2cRt class in include/I2cRt.h which uses writeRt or readRt to write/read to the I2c bus asynchronously from the audio thread.
