Thanks, I do appreciate yr help.
Faust compiled on the Bela the second time I tried, so hopefully the first failure was just some random memory failure or something. The standalone Faust compiler seems to work just fine, hooray.
Now that I've built & installed Faust, and modified the bela architectural file, and installed those other RPMs, I'm stuck again. Here's me trying to build bela-faust-jit in a shell (tell me if I got the command right):
cd Bela/projects/bela-faust-jit; make LDLIBS=-lfaust `llvm-config --ldflags --libs all --system-libs` -ltinfo -lssl -lcrypto
make: invalid option -- '/'
make: invalid option -- 'u'
Usage: make [options] [target] ...
In the Bela UI, I get a console error when I try to build bela-faust-jit (I wonder if I modified bela.cpp correctly):
variable type 'BelaUI' is an abstract class column: 8, line: 310
And when I try to use 'faust2bela' in a shell on Bela, I get these errors (maybe just some missing build argument?):
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/default_main.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/DigitalChannelManager.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/GPIOcontrol.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/I2c_Codec.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/I2c_TouchKey.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/Midi.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/OSCClient.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/OSCServer.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/PRU.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/PulseIn.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/RTAudioCommandLine.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/RTAudio.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/Scope.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/UdpClient.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/UdpServer.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/core/WriteFile.cpp: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/libprussdrv.a: No such file or directory
arm-linux-gnueabihf-g++: error: /usr/local/beaglert/libNE10.a: No such file or directory
