Available parameters: 13
[0] bpm
[1] hex_left
[2] switch_hex - controlled by digital in 14
[3] 1_led_clock - controlling digital out 0
[4] hex_right
[5] 2_led_duff - controlling digital out 1
[6] 3_led_kps - controlling digital out 2
[7] 4_led_bw - controlling digital out 3
[8] switch_slide - controlled by digital in 15
[9] 5_led_gain - controlling digital out 4
[10] 6_led_skip - controlling digital out 5
[11] 7_led_eshp - controlling digital out 6
[12] 8_led_elght - controlling digital out 7
parameter 1 (hex_left) and 4 (hex_right) are mapped to the x axis of both trill hex respectively
static std::vector<unsigned int> parametersFromTrillHorizontalLocation = {kNoParam, kNoParam, 1, 4};
and what about the static std::vector<Trill*> trills variable?
static std::vector<Trill*> trills {
new Trill(1, Trill::BAR, 0x20),
new Trill(1, Trill::BAR, 0x21),
new Trill(1, Trill::HEX, 0x40),
new Trill(1, Trill::HEX, 0x41),
Are you actually using the trill-twod branch?
hmm not sure, how do I go about using it? I've followed all of the steps above.
giuliomoro sorry about that! - I thought I was already up to date with the latest rnbo dev-1.2.6 branch -
it works as it should now, thanks Giulio
could I also trouble you with some guidance for a function to hold the last value of the indexes of each trill?
that's sort of complicated. There are three ways of doing it, in increasing order of complexity:
  • only send the location value if it's different from zero.
  • only send the location value if the touch size is different from zero
  • remember past location values and return a recent one - but not the last one - when the touch size goes to zero.
The first and second one share a drawback: the position will change slightly when you release your finger (as the shape of the fingertip on the sensor changes), so that the value that is held will be slightly different from the one that you meant to hold.
The first has the additional drawback of not being able to detect the touch location when the touch is right on the edge of the sensor (i.e.: the finger touching only one of the sensing pads). This is often just a minor inconvenience, but if you expect your values to go to actual zero, it should be taken into account.
The third one has none of these disadvantages but it's significantly more complicated to implement. Would the first one work for your use case?
    5 days later
    The second one is now tentatively implemented in the trill-twod branch (untested). Update the code on your board and see if it works. You need to set trillHold = true for this functionality to be enabled (besides the usual change to the #define BELA_RNBO_USE_TRILL and adding your trills to the vectors as explained above.
    I did that internally in my rnbo patch by setting a conditional statement of latching all location values when the touch size is below a certain value, which works reasonably well.
    but will try this iteration 🙂
    if I wanted to use two trill bars in the following fashion:
    1) as a multi-touch 'keyboard' segmented into 4 areas (on each bar), where the touch/location of one or more fingers would be used as trigger, and touch size of each area would be used to control parameters such as envelop shape or velocity
    2) as an expressive cross-fader/amplitude modulation device between 8 outputs - with 4 assigned on each bar (where location dictates the channel output and touch size the levels) - I could ultimately do this in rnbo by setting up 4 different 'windows' from the sensor readings (0.-0.25. ; 0.25-0.5; 0.5-0.75;0.75-1.00), and assign each of them to a channel with some smooth interpolation
    both of these examples do require the same indices - and multi touch could ultimately be used in both cases.
    I also did notice the LEDs for position feedback example does exactly that https://github.com/BelaPlatform/Bela/blob/master/examples/Trill/bar-led/render.cpp
    so my question is the following, what would I need to do in order to retrieve the touch (and respective size) of one or more fingers located on defined areas of two trill bars new Trill(1, Trill::BAR, 0x20),
    and thereafter map these indices to rnbo parameters - in the render.cpp file
    I pushed an update to trill-twod where you can send multiple touches to the page. To do so, set trillMultitouch = true. Then in parametersFromTrillLocation and the likes, the values will be interpreted as is (assuming you have two elements in the trills vector):
    0 -> trills[0] touch 0
    1 -> trills[1] touch 0
    2 -> trills[0] touch 1
    3 -> trills[1] touch 1
    4 -> trills[0] touch 2
    5 -> trills[1] touch 2
    ... etc
    The rest of what you are asking is quite application-specific so it's best handled with rnbo, or by writing some custom C++ code yourself.
