I've posted a link but it's awaiting approval...
RNBO error (since Max update?)
try the dev-1.2.6 branch now
Sorted Nice one!
Thanks so much
for posterity, anyone finding themselves in having a different rnbo version from the one supported by the branches on the rnbo.example.bela repo should try the following:
- get the non working exported files on the board (e.g.: in
/root/export
) cd
to the rnbo.example.bela folder- run
./update_rnbo.sh /root/export
- hope everything goes fine
background:
the rnbo-generated cpp files in the rnbo
folder are normally built by including them all from the RNBO.cpp
file. That's pretty unorthodox, and on a small embedded computer like Bela it would mean extremely long compile times - assuming it would actually compile at all before it runs out of memory. I am not here to judge, it's an approach that works for them so they can keep using it, but on Bela we have to build each one of those files individually. Unfortunately those cpp files are missing some critical includes that need to be added in when building them individually, so this is the reason why we cannot just use the files generated by rnbo but actually need to do some processing on them. The annoying thing is that these changes could be applied upstream at zero build- or runtime- cost to them, but even though I reported this the day after the relase of rnbo, it hasn't been applied yet.
I would much rather be using Pd for Bela stuff in all honesty, but I'm just not familiar enough with it compared to Max - thanks for your speedy work here though
Hi there,
The RNBO currently in Max is quite a different version than the dev. Can you elaborate on this process a bit?
I tried following but get:
root@bela ~/Bela/projects/rnbo.example.bela-main# ./update_rnbo.sh /root/export
bash: line 56: ./update_rnbo.sh: Permission denied
I also tried creating a zip file similar to your zip on GitHub from the Max export folder although this was missing some files.
I'm not familiar with this process so appreciate your patience.
Thank you,
robin bash: line 56: ./update_rnbo.sh: Permission denied
whenever you get that, make sure the permissions on the file are appropriate: chmod +x ./update_rnbo.sh
and then it should run. I just updated to 1.3.2 and the automated update failed because the patches don't apply cleanly. So I made a new main-1.3.2 branch for you. Try this out: https://github.com/giuliomoro/rnbo.example.bela/tree/main-1.3.2
I also updated the update_rnbo.sh script hoping it will work again next time.
Thanks for the updated branch. No errors now, so should be working fine. I still have issues on my end so currently working through those. Will report back.
Appreciated!
All working great now, thank you.
For future RNBO updates, is there an easy method for me to update the package myself? I.e. replace files from the RNBO export into a prior BELA package?
robin For future RNBO updates, is there an easy method for me to update the package myself?
I use the update_rnbo.h
file in the project. If it fails, I fix it and try again, as I did this time.
