thuba hello! I got my Bela some weeks ago and its been working fine. But suddenly when connecting the blue light does not appear, when I plug the USB in the blue lights just flashes once for about half a second and then nothing. What could it be?
giuliomoro OK, so is this a Bela Mini? Also, is it one or several lights that flash for half a second? Which one(s) ?
giuliomoro thuba split of a second So not half a second, just a brief blink. Does it change if you remove the SD card? Has the board been resting on a conductive surface while on? Did it shut down suddenly during use when it stopped working?
thuba giuliomoro no it does not change if I remove the SD card, and it was not on a conductive surface. It shut down when I pluged it in, not while using.
