hello!
I got my Bela some weeks ago and its been working fine.
But suddenly when connecting the blue light does not appear, when I plug the USB in the blue lights just flashes once for about half a second and then nothing.
What could it be?
is/was there anything connected to the board?
yes I had a LDR connected to 3.3V, gnd and A0
OK, so is this a Bela Mini?
Also, is it one or several lights that flash for half a second? Which one(s) ?
    (a video wont upload, but it is this light for just a split of a second)
      thuba split of a second
      So not half a second, just a brief blink. Does it change if you remove the SD card?
      Has the board been resting on a conductive surface while on? Did it shut down suddenly during use when it stopped working?
        giuliomoro no it does not change if I remove the SD card, and it was not on a conductive surface. It shut down when I pluged it in, not while using.
