spencer yes! I've successfully gotten serial data going into SuperCollider via the built-in UARTS. Although I have to say that reading serial data in and out in this way (using sclang's SerialPort class) is buggy and seems to be causing audio glitches at times. I'm not really sure why this is... maybe @giuliomoro has some hunches?
More recently I was able to develop an I2C UGen to support Trill sensors. This has been much less error-prone than doing serial communication via SC lang. My hunch is that for most cases this is the approach to take... (i.e. building a UGen that does the specific low-level sensor communication via serial or I2C and packages it up into a nice format on the server) .... and my hunch as to why is that everything on Bela is based on the audio thread having high priority, and so having a process that is not being supervised by the audio thread (sclang) launching low-level system calls causes issues..
Another possible approach, that I have not yet tried, is to have a stand-alone C++ program that handles serial communications and pipes it into sclang via OSC. This would provide at least a less arduous approach than writing low-level UGens..
