I haven't used GDB before, should I install it on BELA (how?) or on my PC? Thanks!
Thanks! This is what I got:
(gdb) directory /root/Bela
Source directories searched: /root/Bela:$cdir:$cwd
(gdb) run
Starting program: /root/Bela/projects/Bela-006/Bela-006
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0xb6c95450 (LWP 992)]
[New Thread 0xb63d4450 (LWP 995)]
Thread 3 "serial-thread" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb63d4450 (LWP 995)]
0xb6d0e6ee in strlen () from /lib/arm-linux-gnueabihf/libc.so.6
(gdb)
Type backtrace to see what function in your code called the strlen()
    Another thing: do the arm... functions return any value that indicates success or failure? You should check those values and act upon them. Typically, if an initialisation function returns error, you are not meant to call other functions on the same object.
    The error is likely somewhere in this file, drive.cpp, because this is the only of the SDK file I have changed, in order to make it work on Bela:
    // #include <libraries/Serial/Serial.h>
    #include "Serial.h"
    #include <sys/time.h>
    #include <sys/ioctl.h>
    extern "C" {
    	#include "drive.h"
    struct timeval time_now;
    const int maxLen = 128;
    unsigned long timeout_start;
    Serial gSerial;
    /* Timing Functions */
    //   H O S T _ P A U S E
    // host_pause() pauses for the given number of seconds
    void host_pause(float delay_sec) {
    	sleep(delay_sec * 1000);
      // delay in milliseconds
    //   H O S T _ G E T _ T I M E O U T
    // host_get_timeout() gets the timeout period of the given port in seconds
    float   host_get_timeout(int port) {
      return 1;
      // can't see this function being called anywhere
    //   H O S T _ S E T _ T I M E O U T
    // host_set_timeout() sets the length of all future timeout periods to the given # of seconds
    void host_set_timeout(int port, float timeout_sec) {
      //SerialArm.setTimeout(timeout_sec * 1000);
      // blank
      //gSerial.setTimeout(timeout_sec);
    //   H O S T _ S T A R T _ T I M E O U T
    // host_start_timeout() starts a timer for the specified port.
    // Call timed_out_yet() to find out whether time is up.
    void host_start_timeout(int port) {
      //timeout_start = millis();
      timeout_start = gettimeofday(&time_now, NULL);
    //   H O S T _ T I M E D _ O U T
    // host_timed_out() returns True if the previously-started timeout
    // period is over.  Returns False if not.
    int host_timed_out(int port) {
      return ((gettimeofday(&time_now, NULL) - timeout_start) > 3);
    /* Serial i/o Functions */
    /* Fixing up baud rate parameters */
    //   H O S T _ F I X _ B A U D
    // host_fix_baud() finds nearest valid baud rate to the one given.
    // Takes small arguments as shorthand:
    // 115 --> 115200, 38 or 384 --> 38400, 96 --> 9600 etc.
    void host_fix_baud(long int *baud) {
      // unify baud rate formats
    /* Configuring Serial Ports */
    //   H O S T _ O P E N _ S E R I A L
    // host_open_serial() opens the given serial port with specified baud rate
    // Always uses 8 data bits, 1 stop bit, no parity.
    // Returns False (zero) if called with zero baud rate.
    int host_open_serial(int port, long int baud) {
      if (baud == 0) {
        return 0;
      // SerialArm.begin(baud);
      gSerial.setup ("/dev/ttyS4", baud);
      return 1;
    //   H O S T _ C L O S E _ S E R I A L
    // host_close_serial() closes the given serial port.
    //  NEVER call this without first calling host_open_serial() on the same port.
    void host_close_serial(int port) {
      //SerialArm.end();
      // blank
    //   H O S T _ F L U S H _ S E R I A L
    // host_flush_serial() flushes and resets the serial i/o buffers
    void host_flush_serial(int port) {
    	char tempBuffer[maxLen];
    	int ret = gSerial.read(tempBuffer, maxLen, 100);
    	while (ret > 0)
    		// Do nothing
    /* Input and Output */
    //   H O S T _ R E A D _ C H A R
    // host_read_char() reads one character from the serial input buffer.
    // returns -1 if input buffer is empty
    int host_read_char(int port) {
    	int ret = gSerial.read(tempBuffer, 1, 100);
    	if (ret > 0)
    		int ch = int(tempBuffer);
    		return ch;
    	else {
    		return -1;
    //   H O S T _ R E A D _ B Y T E S
    // host_read_bytes() will try to read a specified number of bytes
    // until the timeout period of time expires.  It returns the number
    // of bytes it actually read.
    int host_read_bytes(int port, char *buf, int count, float timeout) {
      // host_set_timeout(port, timeout);
      // Serial.print("HOST_READ_BYTES");
      // return SerialArm.readBytesUntil('\0', buf, count);
      int read;
      int ch;
      /* setup the timeout */
      read = 0;
      host_start_timeout(port);
      while (!host_timed_out(port))
        if ((ch = host_read_char(port)) != -1) {
          *buf = (char) ch;
          buf++;
          if (++read == count)
            break;
      return read;
    //   H O S T _ W R I T E _ C H A R
    // host_write_char() writes one character to the serial output buffer
    // Returns False (zero) if buffer is full
    // Returns True (non-zero) if successful
    int host_write_char(int port, int ch) {
      gSerial.write((const char*)ch);
      return 1;
    //   H O S T _ W R I T E _ S T R I N G
    // host_write_string() writes a null-terminated string to the output buffer
    // Returns False (zero) if not enough rooom
    int host_write_string(int port, char *str) {
      gSerial.write(str);
      return 1;
    /* Getting Serial Port Status */
    //   H O S T _ P O R T _ V A L I D
    // host_port_valid() returns True if the specified port number is valid
    int host_port_valid(int port) {
    //   H O S T _ I N P U T _ C O U N T
    // host_input_count() returns the number of chars waiting in the input queue
    int host_input_count(int port) {
      return gSerial.available();
    //   H O S T _ I N P U T _ F U L L
    // host_input_full() tells whether or not the serial input queue is full
    int host_input_full() {
      //return ((64 - SerialArm.available()) == 0);
      m3rten gSerial.write((const char*)ch)
      This one is wrong and should be
      gSerial.write(&ch, 1)
      This gives me:
      cannot initialize a parameter of type 'const char *' with an rvalue of type 'int *'
      right, it's called ch but it's actually an int ...
      so do
        char c = ch;
        gSerial.write(&c, 1);
        return 1;
      Thanks! That seems to work. It got rid of the Segmentation fault.
      Now I get an unknown error while reading serial
      Did the other functions in drive.cpp look ok?
      (I left some blank, because I didn't know what to write...)
      Put a print statement in each function in drive.cpp and see in which order they get called and with what parameters. As you haven't shared a full copy of your code, I have no way of knowing what gets called when. The main question is whether host_open_serial() gets indeed called before any of the read/write/available functions are called and whether any of these functions are executed successfully before this error shows up.
      In host_open_serial() you should also check the return value of gSerial.setup() and return 0 from host_open_serial() if gSerial.setup() returns non-zero. If that is the case it should also print some error, but you don't mention that in your posts.
      In host_flush_serial() there should be no call to gSerial.read(): the buffer is automatically flushed on write.
      in host_read_char(), this line int ch = int(tempBuffer); should be int ch = tempBuffer[0];.
      in host_write_char(), the fixes mentioned above.
      in host_input_full(), always return false.
      Thanks a lot! @"giuliomoro", I’ll update and then troubleshoot with print statements like you suggested. The SDK files are quite long, should I paste them here or post a GitHub link?
      a github link is the best option. Make sure it's the whole Bela project, ready to be run. Also a direct link to the upstream SDK wouldn't hurt.
      This is working now!
      Bela connects to the Microscribe and receives serial data. Adding print statements to the code really helped me troubleshoot this! (My main mistake was forgetting I had commented out the arm_connect() function during testing. Also I had multiplied a pause time value by 1000 beacuse I thought it was supposed to be in microseconds.)
      Thanks a lot for all you help!
