You probably mean render.cpp as the file in question. Please hold...
Also, I got the files to run again...
Bela stopped
Building project ...
Build finished
Running project ...
KNOB is ACTIVE: 0, 0.008343
KNOB is ACTIVE: 3, 0.002147
KNOB 0 is INACTIVE. Value: 0.008910
KNOB 3 is INACTIVE. Value: 0.002220
Startup Delay Expired
So, something with the knobs in the source need to be altered or removed for now, i.e. I am not using knobs.
Here is render.cpp:
// klingon-tone sketch,
#include <stdlib.h>
// #include <libraries/math_neon/math_neon.h>
#include <math.h>
#include "klingon.h"
#define N_KNOBS 5
#define DRIVE 0
#define TONE 1
#define LEVEL 2
#define DRY 3
#define BOOST 4
float *ch0, *ch1;
int gAudioFramesPerAnalogFrame;
int gStartup_Control_Delay;
// klingon-tone implementation based conceptually on typical guitar stompbox OD like King of Tone
klingon* kot;
//Control functions related struct and processing
typedef struct knobs_t
float fs;
float ifs;
int N;
int channel;
bool active;
int active_timer;
int active_time;
float *frame;
float b0;
int scan_time;
float dk_thrs;
float y1, y2;
float s0;
int scan_timer;
} knobs;
knobs* make_knob(knobs* k, int channel, int N, float fs, float scan_time, float active_time, float tau, float thrs)
k = (knobs*) malloc(sizeof(knobs));
k->frame = (float*) malloc(sizeof(float)*N);
k->fs = fs;
k->ifs = 1.0/fs;
k->N = N;
k->channel = channel;
for(int i = 0; i < N; i++)
k->frame[i] = 0.0;
k->b0 = expf(-k->ifs/tau);
k->scan_time = ((int) (fs*scan_time)) / N;
k->active_time = ((int) (fs*active_time) ) / N;
k->dk_thrs = thrs;
k->y1 = k->y2 = 0.0;
k->scan_timer = 0;
k->active = false;
k->active_timer = 0;
return k;
//Filter analog inputs
// Detect changes in position
void knob_filter_run(knobs* k)
float x = 0.0;
//2 first order low-pass filters on analog inputs to smooth knob controls
for(int i = 0; i < k->N; i++)
x = k->frame[i];
k->y1 = x + (k->y1 - x) * k->b0;
x = k->y1;
k->y2 = x + (k->y2 - x) * k->b0;
//then check for changes
if(++k->scan_timer >= k->scan_time)
k->scan_timer = 0;
float dk = fabs(k->y2 - k->s0);
if(dk > k->dk_thrs)
k->active_timer = k->active_time;
//rt_printf("KNOB dk: %d, %f\n", k->channel, k->y2);
k->s0 = k->y2;
if(k->active_timer > 0)
if(k->active == false)
rt_printf("KNOB is ACTIVE: %d, %f\n", k->channel, k->y2);
k->active = true;
k->active_timer--;
else
if(k->active == true)
rt_printf("KNOB %d is INACTIVE. Value: %f\n", k->channel, k->y2);
k->active = false;
void
knob_destructor(knobs* k)
free(k);
//Control knobs:
knobs **kp;
// Extract a single audio channel from BelaContext and format for effect code input
void format_audio_buffer(BelaContext* context, float *outbuffer, int channel)
// Read the audio input and half the amplitude
outbuffer[n] = audioRead(context, n, channel);
// Extract a single analog channel from BelaContext and format for flanger code input
void format_analog_buffer(BelaContext* context, knobs *k)
float ain = k->y1; //starts out with previous value -- just to initialize with something sane and make the compiler happy
for(unsigned int n = 0; n < k->N; n++)
if(!(n % gAudioFramesPerAnalogFrame))
ain = analogRead(context, n/gAudioFramesPerAnalogFrame, k->channel);
// double-stuff it
k->frame[n] = ain;
knob_filter_run(k);
if(gStartup_Control_Delay <= 0)
if(gStartup_Control_Delay == 0)
rt_printf("Startup Delay Expired\n");
gStartup_Control_Delay = -1;
if(k->active)
switch(k->channel)
case DRIVE:
kot_set_drive(kot, map(k->y2, 0.0, 1.0, 12.0, 45.0) );
break;
case TONE:
kot_set_tone(kot, map(k->y2, 0.0, 1.0, -60.0, 0.0) );
break;
case LEVEL:
kot_set_level(kot, map(k->y2, 0.0, 1.0, -40.0, 0.0) );
break;
case BOOST:
kot_set_boost(kot, k->y2);
break;
case DRY:
kot_set_mix(kot, powf(10.0, map(k->y2, 0.0, 1.0, -60.0, 0.0)/20.0) );
break;
default:
break;
else
gStartup_Control_Delay--;
ch0 = (float*) malloc(sizeof(float)*context->audioFrames);
ch1 = (float*) malloc(sizeof(float)*context->audioFrames);
// Create the klingon : make_klingon() initializes sane (usable) default settings
kot = make_klingon(kot, 1, context->audioFrames, context->audioSampleRate);
//Bypass is the least intuitive function:
// If second argument is true, it forces bypass state.
// If second argument is false, it toggles bypass state.
// The second call below is all that is needed after make_klingon(), since the constructor function
// sets bypass state to true. A call to kot_set_bypass(kot, false) would then toggle to active-state
// since it is already initialized to bypass state (true).
// However for clarity in the example it is explicitly set to false, then toggled to demonstrate the normal sequence when
// the current bypass state is unknown.
kot_set_bypass(kot, true);
kot_set_bypass(kot, false);
//Setup analog control input functions
kp = (knobs**) malloc(sizeof(knobs*)*N_KNOBS);
for(int i = 0; i < N_KNOBS; i++)
//make_knob(knobs* k, int channel, int N, float fs, float scan_time, float active_time, float tau, float thrs)
kp[i] = make_knob(kp[i], i, context->audioFrames, context->audioSampleRate, 0.15, 1.0 , 0.01, 0.005);
gStartup_Control_Delay = (int) (context->audioSampleRate*2.0);
//separate audio inputs into their own buffers
format_audio_buffer(context, ch1, 1);
format_audio_buffer(context, ch0, 0);
//Scan analog inputs and set settings
format_analog_buffer(context, kp[i]);
//Run the klingon on ch0
klingon_tick(kot, ch0);
//Send it to the output
// Write klingon through ch0, pass-through ch1
audioWrite(context, n, 0, ch0[n]);
audioWrite(context, n, 1, ch1[n]);
// Deallocate memory allocated during program execution
free(ch0);
free(ch1);
klingon_cleanup(kot);
//deallocate memory from knobs
knob_destructor(kp[i]);
free(kp);
Thank you...
