Hmmm.
Is the name of the [receive] object in the Pd patch exactly the same as the one you are sending to from C++?
Maybe try to change both to hello so there is less chance of an error.
Also, try to connect your [receive] object directly to an oscillator (maybe after multiplying [* 10]), such as:
[receive hello]
[* 10]
[phasor~]
[dac~]
just in case the message is being received but there is a problem with the printing.
If this still does not work, can you try to run:
examples/08-PureData/digital/_main.pd
connecting at least one button to one of the inputs and see if you receive those messages?
