$ ifconfig
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether ac:de:48:00:11:22
inet6 fe80::aede:48ff:fe00:1122%en5 prefixlen 64 scopeid 0x4
status: active
ap1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether 36:7d:da:1b:08:0f
media: autoselect
ether 14:7d:da:1b:08:0f
inet6 fe80::54:769f:dbfe:fb6c%en0 prefixlen 64 secured scopeid 0x6
inet 192.168.178.157 netmask 0xffffff00 broadcast 192.168.178.255
inet6 2001:9e8:16d9:5800:1836:7c67:156f:f688 prefixlen 64 autoconf secured
inet6 2001:9e8:16d9:5800:cdcc:a8ce:a232:d68b prefixlen 64 autoconf temporary
media: autoselect
status: active
awdl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6463<RXCSUM,TXCSUM,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether fa:99:41:d6:72:74
inet6 fe80::f899:41ff:fed6:7274%awdl0 prefixlen 64 scopeid 0x7
media: autoselect
status: active
ether 82:8f:80:24:58:01
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 11 priority 0 path cost 0
ifmaxaddr 0 port 12 priority 0 path cost 0
member: en3 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 13 priority 0 path cost 0
member: en4 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 10 priority 0 path cost 0
media: <unknown type>
status: inactive
inet6 fe80::f899:41ff:fed6:7274%llw0 prefixlen 64 scopeid 0x9
media: autoselect
status: inactive
en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:8f:80:24:58:04
status: inactive
status: inactive
ether 82:8f:80:24:58:00
status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:8f:80:24:58:05
status: inactive
inet6 fe80::a895:6141:3fcd:4bbe%utun0 prefixlen 64 scopeid 0xe
inet6 fe80::cb8d:8056:2353:519f%utun1 prefixlen 64 scopeid 0xf
inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0x10
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::9ac4:567d:db54:641a%utun3 prefixlen 64 scopeid 0x11
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::b968:95ea:75c4:6dc%utun4 prefixlen 64 scopeid 0x12
$ cat /Volumes/BELABOOT/bela.version
cat: /Volumes/BELABOOT/bela.version: No such file or directory
$ ls /dev/tty*bela*
/dev/tty.usbmodem__bela__4
$ ioreg -p IOUSB -w0 -l
+-o Root <class IORegistryEntry, id 0x100000100, retain 26>
| "IOKitBuildVersion" = "Darwin Kernel Version 22.2.0: Fri Nov 11 02:08:47 PST 2022; root:xnu-8792.61.2~4/RELEASE_X86_64"
| "OS Build Version" = "22C65"
| "OSKernelCPUSubtype" = 3
| "OSKernelCPUType" = 16777223
| "OSPrelinkKextCount" = 18
| "IORegistryPlanes" = {"IOPower"="IOPower","IOService"="IOService","IO80211Plane"="IO80211Plane","IOUSB"="IOUSB","CoreCapture"="CoreCapture","IOACPIPlane"="IOACPIPlane","IODeviceTree"="IODeviceTree"}
| "IOConsoleLocked" = No
| "IOConsoleUsers" =
