Hi all,
I'm busily soldering my Pepper board together. I've reached step 16 but I'm struggling to understand the notes about the 10 or 16 pin power connection.
I'm using the full kit so only have to solder the bottom ten pins... I can't fit the connector if I put all 16 pins in like the image shows though.
Am I right in thinking I should trim the header so that it is only ten pins and I can easily fit the power connector?
Apologies for asking obvious questions... this is he most complicated thing I've soldered and I'm nervous!
    Tristan Am I right in thinking I should trim the header so that it is only ten pins and I can easily fit the power connector?
    Correct. Sorry the guide was written before we started shipping these connectors
