When I disconnect the 5v or GND of the IR sensor the noise becomes a lot, lot less, but there's still this typical noise present that seems to be influenced by the processes that are running on the Bela. All 8 expander channels have this same sound.
The audio out of the Bela capelet itself is perfectly quiet! When I remove the expander capelet and then connect the IR sensor, the audio out stays quiet.
The revision I am on is: Bela image, v0.3.8h, 5 January 2023. I actually tested the same setup with another Bela that still had an older v 0.3.6b image on it and another audio expander: it had exactly the same behaviour concerning the noise coming from the expander capelet.
When I use your zero sending patch, the sound changes in a more continuous noise sound. I made a recording of a resonance speaker, first you hear the rhythmic noise and then when you hear the plop you're patch has started and it changes into this other noise.
Maybe it has something to do with my expander settings?
