Jetrye Have I got this right: Input level = 0.707Vrms => about -0,8 dBu?
so it says https://www.analog.com/en/design-center/interactive-design-tools/dbconvert.html
Jetrye codec's data-sheet mentions an "input mix attenuation=12dB". Is that possible to set in Bela? (It would make it better suited for guitar input: 4Vpeak and 80k impedance.)
Yes, you can set that setting the input gain in the IDE to a negative value. That will set the PGA to 0dB and work on the attenuator.
Jetrye When you write Headphone outs, is that the three-way Molex output?
yes
Jetrye Is it possible to reach the Bela IDE through an Ethernet connection?
yes. It's set to look for a DHCP server on it by default, but it can be set to have a static IP if that's preferred.
Jetrye Is it possible to find the schematics on Bela, as I did for CTAG
http://github.com/BelaPlatform/bela-hardware
Jetrye Would it be possible to add a link
makes sense
