giuliomoro I didn't. So I just need to specify the Bela network IP address in arduino for OSC sending? I was looking at the OSCwifi example in arduino, am I on the right track?
// Please include ArduinoOSCWiFi.h to use ArduinoOSC on the platform
// which can use both WiFi and Ethernet
#include <ArduinoOSCWiFi.h>
// this is also valid for other platforms which can use only WiFi
// #include <ArduinoOSC.h>
// WiFi stuff
const char* ssid = "your-ssid";
const char* pwd = "your-password";
const IPAddress ip(192, 168, 1, 201);
const IPAddress gateway(192, 168, 1, 1);
const IPAddress subnet(255, 255, 255, 0);
// for ArduinoOSC
const char* host = "192.168.1.200";
const int recv_port = 54321;
const int bind_port = 54345;
const int send_port = 55555;
const int publish_port = 54445;
// send / receive varibales
int i;
float f;
String s;
void onOscReceived(const OscMessage& m) {
Serial.print(m.remoteIP());
Serial.print(" ");
Serial.print(m.remotePort());
Serial.print(" ");
Serial.print(m.size());
Serial.print(" ");
Serial.print(m.address());
Serial.print(" ");
Serial.print(m.arg<int>(0));
Serial.print(" ");
Serial.print(m.arg<float>(1));
Serial.print(" ");
Serial.print(m.arg<String>(2));
Serial.println();
void setup() {
Serial.begin(115200);
delay(2000);
// WiFi stuff (no timeout setting for WiFi)
#if defined(ESP_PLATFORM) || defined(ARDUINO_ARCH_RP2040)
#ifdef ESP_PLATFORM
WiFi.disconnect(true, true); // disable wifi, erase ap info
#else
WiFi.disconnect(true); // disable wifi
#endif
delay(1000);
WiFi.mode(WIFI_STA);
#endif
WiFi.begin(ssid, pwd);
WiFi.config(ip, gateway, subnet);
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.print("WiFi connected, IP = ");
Serial.println(WiFi.localIP());
// publish osc messages (default publish rate = 30 [Hz])
OscWiFi.publish(host, publish_port, "/publish/value", i, f, s)
->setFrameRate(60.f);
OscWiFi.publish(host, publish_port, "/publish/func", &millis, µs)
->setIntervalMsec(500.f);
// subscribe osc messages
OscWiFi.subscribe(bind_port, "/bind/values", i, f, s);
OscWiFi.subscribe(bind_port, "/lambda/bind/args",
[&](const int& i, const float& f, const String& s) {
Serial.print("/lambda/bind/args ");
Serial.print(i);
Serial.print(" ");
Serial.print(f);
Serial.print(" ");
Serial.print(s);
Serial.println();
OscWiFi.subscribe(recv_port, "/lambda/msg",
[](const OscMessage& m) {
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.println();
OscWiFi.subscribe(recv_port, "/wildcard/*/test", [](const OscMessage& m) {
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.println();
OscWiFi.subscribe(recv_port, "/need/reply", []() {
Serial.println("/need/reply");
int i = millis();
float f = (float)micros() / 1000.f;
String s = "hello";
OscWiFi.send(host, send_port, "/reply", i, f, s);
OscWiFi.subscribe(recv_port, "/callback", onOscReceived);
void loop() {
OscWiFi.update(); // should be called to receive + send osc
// or do that separately
// OscWiFi.parse(); // to receive osc
// OscWiFi.post(); // to publish osc
