In any case, the bela-sys hello seems to run (although I haven't dared plug anything in yet see EDIT below)
root@bela:~# ./hello
Bela_initAudio()
Starting in high-performance mode
Starting with period size 16 ;analog enabled
DAC level 0.000000 dB; ADC level 0.000000 dB; headphone level -6.000000 dB
Detected hardware: CtagBeastBela
Hardware specified by user:
Hardware specified in belaconfig:
Hardware to be used: CtagBeastBela
Bela_getHwConfig()
fifoFactor: 1
core audioFrames: 16
PRU memory mapped to ARM:
digital: 0xb6316000 0xb6316400
audio: 0xb6317000 0xb6317200 0xb6317400 0xb6317500
analog: 0xb6307000 0xb6307080 0xb6307100 0xb6307180
analog offset: 0xffff2000 0xffff2080 0xffff2100 0xffff2180
Bela_startAudio
startAudioInilne
Using embedded PRU code
_________________Audio Thread!
^Caudio thread ended
Stopping audio...
Bela_cleanupAudio()
On the other hand, the bela-rs examples only output Setting up, except the sample example which stops at an assertion (probably because it didn't expect to find a Bela BEAST combo)
root@bela:~# ./sample
Setting up
thread '<unnamed>' panicked at 'assertion failed: `(left == right)`
left: `16`,
right: `2`', examples\sample.rs:26:9
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
fatal runtime error: failed to initiate panic, error 9
Aborted
EDIT:
Sound seems to work. The difference regarding the output of the bela-rs hello comes down to not doing bela_sys::Bela_setVerboseLevel(1);
