giuliomoro All the grounds are together (including the floating one, not floating anymore).
I don't think that power supply quality is an issue as everything was tested with all the sources from a bench supply, too.
The +5V regulator is Recom R-785.0-1.0 (but I also tested it simpler, no regulator, 5V coming from the bench supply).
The analog inputs are not used, not connected to anything.
+/-9V are there because we want to prevent overload on input and to have good voltage on balanced output.
What sends me crazy is that without a buffer, everything is straightforward: connect guitar to audio input, power supply to bela mini, everything is clean.
As soon as I put the audio buffer in the middle, everything goes crazy (not simply noise but very strong noise).
This happens in all simplest configurations, including this one:
- bela mini besides a breadboard, an op-amp with two resistors on the breadboard, guitar to the op-amp. Nothing else. Guitar to bela: perfect. Guitar to buffer (unity gain): disaster.
Same situation, guitar to buffer, bela mini powered only from the USB connection: everything fine.
External supply to bela mini and audio buffer can't go together.
