ok, some more testing done...it all works when switching out plugins in the chain from render.cpp which is great!
to bypass a plugin at slot 1 and enable slot 2 (and vice versa) and connect to the rest of the chain i have to do something like this:
if (!vocoder) {
	gLv2Host.disconnect(3,0);
	gLv2Host.bypass(1,0);
	gLv2Host.bypass(2,1);
	gLv2Host.connect(1,0,3,0);
	} else {
	gLv2Host.bypass(1,1);
	gLv2Host.bypass(2,0);
	gLv2Host.connect(-1,1,2,1);
	gLv2Host.connect(0,0,2,0);
	gLv2Host.connect(2,0,3,0);
note that in the vocoder case i also have to send the direct adc signal to the second input, to get carrier and modulator :-)
ideally, since you said an input can only have one port connected the disconnects should not be needed if i run another connect, right? so whenever the connect function is run it should run the respective disconnect function first.
in the state it is now if i don't do the disconnects like so:
if (!vocoder) {
	} else {
the vocoder does not work (i just get a frozen sound, like a repeated buffer or similar) once i switch back to non vocoder (autotune plugin) it works again.
full code, or at least the name and order of the plugins? disconnect() assigns an empty buffer to the disconnected inputs, but that should be overridden by the next call to connect(). This may not be true for the input (-1) and output (numSlots).
here is the code:
#include <vector>
#include "Lv2Host.h"
Lv2Host gLv2Host;
int gAudioFramesPerAnalogFrame;
int gLedPin = 0;
float gUpdateInterval = 0.05;
	settings->interleave = 0;
//scales to choose
bool chromatic[12] {1,1,1,1,1,1,1,1,1,1,1,1,};
bool major[12] {1,0,1,0,1,1,0,1,0,1,0,1,};
bool minor[12] {1,0,1,1,0,1,0,1,1,0,0,1,};
bool penta[12] {1,0,1,0,1,0,0,1,0,1,0,0,};
bool whole[12] {1,0,1,0,1,0,1,0,1,0,1,0,};
bool dim[12]   {1,0,0,1,0,0,1,0,0,1,0,0,};
bool octave = 0;
bool powercut = 0;
bool echo = 0;
//pointer to choosen scale
bool *scale = chromatic;
bool gIsNoteOn = 0;
int tap_count = 0;
int frame_count = 0;
int gVelocity = 0;
int gNote = 0;
int gControl = 0;
int gCCVal = 0;
bool vocoder = 1;
void midiMessageCallback(MidiChannelMessage message, void* arg){
/*	if(arg != NULL){
		rt_printf("Message from midi port %s ", (const char*) arg);
//	message.prettyPrint();
	if(message.getType() == kmmNoteOn){
	gNote =	message.getDataByte(0);
	gVelocity = message.getDataByte(1);
		gIsNoteOn = gVelocity > 0;
		if(message.getType() == kmmControlChange){
			gControl = message.getDataByte(0);
			gCCVal = message.getDataByte(1);
Midi midi;
const char* gMidiPort0 = "hw:1,0,0";
	midi.readFrom(gMidiPort0);
	midi.writeTo(gMidiPort0);
	midi.enableParser(true);
	midi.setParserCallback(midiMessageCallback, (void*) gMidiPort0);
	// these should be initialized by Bela_userSettings above
	if((context->flags & BELA_FLAG_INTERLEAVED) || context->audioSampleRate != context->analogSampleRate)
		fprintf(stderr, "Using Lv2Host requires non-interleaved buffers and uniform sample rate\n");
		return false;
	if(!gLv2Host.setup(context->audioSampleRate, context->audioFrames,
				context->audioInChannels, context->audioOutChannels))
		fprintf(stderr, "Unable to create Lv2 host\n");
		return false;
	std::vector<std::string> lv2Chain;
	lv2Chain.emplace_back("http://moddevices.com/plugins/caps/Noisegate");
//	lv2Chain.emplace_back("http://moddevices.com/plugins/caps/Compress");
	lv2Chain.emplace_back("http://gareus.org/oss/lv2/fat1");
	lv2Chain.emplace_back("http://drobilla.net/plugins/mda/TalkBox");
	lv2Chain.emplace_back("http://guitarix.sourceforge.net/plugins/gx_oc_2_#_oc_2_");
	lv2Chain.emplace_back("http://drobilla.net/plugins/mda/SubSynth");
	lv2Chain.emplace_back("http://drobilla.net/plugins/mda/Detune");
	lv2Chain.emplace_back("http://drobilla.net/plugins/mda/Stereo");
	lv2Chain.emplace_back("http://calf.sourceforge.net/plugins/VintageDelay");
	lv2Chain.emplace_back("http://guitarix.sourceforge.net/plugins/gx_reverb_stereo#_reverb_stereo");
	for(auto &name : lv2Chain)
		gLv2Host.add(name);
	if(0 == gLv2Host.count())
		fprintf(stderr, "No plugins were successfully instantiated\n");
		return false;
	if(context->analogFrames)
//noisegate
gLv2Host.setPort(0, 0, -20);
	gLv2Host.setPort(0, 2, -30);
	//autotune
	gLv2Host.setPort(1, 6, 0.5);
	gLv2Host.setPort(1, 7, 0.02);
//	gLv2Host.setPort(2, 9, 24);
	gLv2Host.setPort(1, 11, 1); //fastmode
	gLv2Host.setPort(1, 12, 1); //c
	gLv2Host.setPort(1, 13, 0);
	gLv2Host.setPort(1, 14, 0);
	gLv2Host.setPort(1, 15, 1);
	gLv2Host.setPort(1, 16, 0);
	gLv2Host.setPort(1, 17, 1);
	gLv2Host.setPort(1, 18, 0);
	gLv2Host.setPort(1, 19, 1);
	gLv2Host.setPort(1, 20, 0);
	gLv2Host.setPort(1, 21, 0);
	gLv2Host.setPort(1, 22, 1);
	gLv2Host.setPort(1, 23, 0);
//vocoder (talkbox)
gLv2Host.setPort(2, 0, 1); //wet signal
gLv2Host.setPort(2, 2, 0); //choose carrier channel
gLv2Host.setPort(2, 3, 1); //quality
	// octaver off by default
            	gLv2Host.setPort(3, 3, 0);
				gLv2Host.setPort(3, 4, 0);
				gLv2Host.setPort(3, 2, 0.3);
					//mda subsynth
				//	gLv2Host.setPort(4,1, 0);
	gLv2Host.setPort(4, 3, 1);
	gLv2Host.setPort(4, 4, 0);
	//mda detune
	gLv2Host.setPort(5, 0,0.1 );
	gLv2Host.setPort(5, 1,0.5 );
gLv2Host.setPort(5, 3,0.3 );
	gLv2Host.setPort(5, 2, 0.3);
//mda stereo
	gLv2Host.setPort(6, 0, 0.5);
	gLv2Host.setPort(6, 1, 0.3);
	//echo
	gLv2Host.setPort(7, 11, 0);
	gLv2Host.setPort(7, 10, 0);
	gLv2Host.setPort(7, 4, 100);
//	gLv2Host.setPort(7, 15, 1);
	//_reverb
	gLv2Host.setPort(8, 0, 40);
	gLv2Host.setPort(8, 3, 0.1);
	//connect carrier to vocoder directly (without mono fx, gate and compressor)
//	gLv2Host.connect(-1,1,2,1);
//	scope.setup(4, context->audioSampleRate);
	// Turn LED on
	pinMode(context, 0, gLedPin, OUTPUT); // Set pin as output
	digitalWrite(context, 0, gLedPin, 1); //Turn LED on
	if (!vocoder) {
	} else {
frame_count++;
if (frame_count > (1000*tap_count)) {
	tap_count = 0;
//	static bool pluginsOn[3] = {true, true, true};
	// set inputs and outputs
	const float* inputs[context->audioInChannels];
	float* outputs[context->audioOutChannels];
	for(unsigned int ch = 0; ch < context->audioInChannels; ++ch)
		inputs[ch] = (float*)&context->audioIn[context->audioFrames * ch];
	for(unsigned int ch = 0; ch < context->audioOutChannels; ++ch)
		outputs[ch] = &context->audioOut[context->audioFrames * ch];
			// do the actual processing on the buffers specified above
	gLv2Host.render(context->audioFrames, inputs, outputs);
			switch (gControl) {
				case 7: {
						gLv2Host.setPort(2, 3, float(gCCVal/127));
					break;
				case 8: {
						gLv2Host.setPort(4, 0, float(gCCVal>>5)/4.0);
					break;
				case 9: {
						gLv2Host.setPort(7, 6, (gCCVal/8) + 1);
					//	gLv2Host.setPort(7, 1, float(gCCVal/ 127.0));
					break;
				case 10: {
					gLv2Host.setPort(8, 2, float(gCCVal/ 127.0));
					break;
		if(gIsNoteOn == 1){
			//logic to switch between non "tonal" and "semitonal" scales
			if ((scale == whole) | (scale == dim)) scale = chromatic;
		switch (gNote) {
			case 20: {
			if (!echo) {
				gLv2Host.setPort(7, 10, 0.3);
				echo = 1;
			} else {
				echo = 0;
				break;
			case 21: {
			/*	if (tap_count == 4) {
				float bpm =	float(60.0/float(frame_count * 8 / 11025.0));
			//	gLv2Host.setPort(7, 4, bpm);
				rt_printf("bpm: %f\n",bpm);
					tap_count = 0;
				if (!tap_count) frame_count = 0;
				if (tap_count < 4) tap_count++;
				vocoder = !vocoder;
				break;
			case 22: {
			if (!octave) {
				gLv2Host.setPort(3, 3, 0.5);
				gLv2Host.setPort(3, 4, 0.5);
				octave = 1;
			} else {
				octave = 0;
				break;
			case 23: {
				// subsynth
				if (!powercut) {
					gLv2Host.setPort(4, 2, 1);
					powercut = 1;
				} else {
				gLv2Host.setPort(4, 2, 0);
				powercut = 0;
				break;
			case 36: {
					//set scale, in key of c, no offset
	for(unsigned int n = 0; n < 12; n++){
	gLv2Host.setPort(2, n + 12, scale[n]);
  // 	rt_printf("value%d: %d\n", n, scale[n]);
			break;
		case 37: {
			//set scale, in key of c# offset of 1 halftone
			if (scale == chromatic) scale = whole;
	gLv2Host.setPort(1, ((n+1)%12 + 12), scale[(n)]);
//	rt_printf("value%d: %d\n", (n+1)%12, scale[n]);
			break;
	case 38: {
	//set scale, in key of d offset of 2 halftones
	gLv2Host.setPort(1, ((n+2)%12 + 12), scale[(n)]);
			break;
    case 39: {
				scale = chromatic;
				break;
	case 40: {
	//set scale, in key of d# offset of 3 halftones
	if (scale == chromatic) scale = dim;
	gLv2Host.setPort(1, ((n+3)%12 + 12), scale[(n)]);
	break;
	case 41: {
	//set scale, in key of e offset of 4 halftones
	gLv2Host.setPort(1, ((n+4)%12 + 12), scale[(n)]);
	break;
	case 42: {
	//set scale, in key of f offset of 5 halftones
	gLv2Host.setPort(1, ((n+5)%12 + 12), scale[(n)]);
	break;
	case 43: {
		scale = major;
		break;
	case 44: {
	//set scale, in key of f# offset of 6 halftones
	gLv2Host.setPort(1, ((n+6)%12 + 12), scale[(n)]);
	break;
	case 45: {
	//set scale, in key of g offset of 7 halftones
	gLv2Host.setPort(1, ((n+7)%12 + 12), scale[(n)]);
	break;
	case 46: {
	//set scale, in key of g# offset of 8 halftones
	gLv2Host.setPort(1, ((n+8)%12 + 12), scale[(n)]);
	break;
			case 47: {
				scale = minor;
				break;
				case 48: {
	//set scale, in key of a offset of 9 halftones
	gLv2Host.setPort(1, ((n+9)%12 + 12), scale[(n)]);
	break;
	case 49: {
	//set scale, in key of a# offset of 10 halftones
	gLv2Host.setPort(1, ((n+10)%12 + 12), scale[(n)]);
	break;
	case 50: {
	//set scale, in key of b offset of 11 halftones
	gLv2Host.setPort(1, ((n+11)%12 + 12), scale[(n)]);
	break;
			case 51: {
				scale = penta;
				break;
		gIsNoteOn = 0;
void cleanup(BelaContext* context, void* userData) {
this code works as intended. to reproduce the "error"/bug you have to remove the two disconnects at start of render() i.e.
if (!vocoder) {
	// gLv2Host.disconnect(3,0);
	} else {
to reproduce you will have to switch the plugins live (currently by sending a note on 21), simply setting bool vocoder does not show the bug. so to make it clear again, leaving the disconnects out produces a frozen sound when i switch to the vocoder part, having the disconnects in there solves it.
9 days later
giuliomoro coming back to the heavy lv2 custom render file i have a strange behaviour that you maybe can explain?
if i run this simple test patch:
 ____  _____ _        _
| __ )| ____| |      / \
|  _ \|  _| | |     / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/   \_\
http://bela.io
A project of the Augmented Instruments Laboratory within the
Centre for Digital Music at Queen Mary University of London.
http://www.eecs.qmul.ac.uk/~andrewm
(c) 2016 Augmented Instruments Laboratory: Andrew McPherson,
  Astrid Bin, Liam Donovan, Christian Heinrichs, Robert Jack,
  Giulio Moro, Laurel Pardue, Victor Zappi. All rights reserved.
The Bela software is distributed under the GNU Lesser General Public License
(LGPL 3.0), available here: https://www.gnu.org/licenses/lgpl-3.0.txt
int gCount = 0; //counts elapsed samples
int tap = 0; //count taps
#define DEBOUNCE_TIME 40 //how long the button has to be "off" to be considered off
bool cState_b0 = 0;
bool cState_b1 = 0;
bool pState_b0 = 1;
bool pState_b1 = 1;
int debounce_b0 = 0;
int debounce_b1 = 0;
int switch_fx = 0;
int old_fx = 1;
     pinMode(context,0,1, OUTPUT); // LED1
     pinMode(context,0,2, OUTPUT); // LED2
     pinMode(context,0,3, INPUT); //Button 1
     pinMode(context,0,4, INPUT); //Button 2
	for(unsigned int n = 0; n < context->digitalFrames; ++n){
		cState_b0 = digitalRead(context, n, 4);
        cState_b1 = digitalRead(context, n, 3);
        gCount++;
	if (gCount > 100000*(tap+1)) tap = 0;
	if (!cState_b0 && pState_b0) {
  switch_fx = (switch_fx + 1)%3;
if (cState_b0 && !pState_b0) {
  if (debounce_b0 < DEBOUNCE_TIME) {
    debounce_b0++;
    cState_b0 = 0;
  } else debounce_b0 = 0;
pState_b0 = cState_b0;
if (!cState_b1 && pState_b1) {
	//taptempo
	if (!tap) gCount = 0;
	tap = tap + 1;
	if (tap == 5) {
		tap = 0;
	float tempo = 240.0/float(gCount/context->digitalSampleRate);
	rt_printf("tempo: %f\n", tempo);
if (cState_b1 && !pState_b1) {
  if (debounce_b1 < DEBOUNCE_TIME) {
    debounce_b1++;
    cState_b1 = 0;
  } else debounce_b1 = 0;
pState_b1 = cState_b1;
if (switch_fx != old_fx) {
switch (switch_fx) {
 case 0: {
   digitalWrite(context, 0, 1, 1);
   digitalWrite(context, 0, 2, 1);
   break;
 case 1: {
   digitalWrite(context, 0, 1, 0);
   break;
  case 2: {
   digitalWrite(context, 0, 2, 0);
   break;
old_fx = switch_fx;
	// Nothing to do here
everything works as expected, as i press the button either both, the left or the right LED are lit up to indicate at which switch_fx i am.
however if i run the same things in my big render.cpp file (the one with heavy and lv2) i put the above code into the heavy (default render() function). of course before my if statements that switch out the heavy and lv2 part.
now for the strange part:
the switching works just fine, but the LED's don't go dark when they should, they stay lit all the time albeit at a little different brightnesses depending on the value of switch_fx. as soon as i remove the if (switch_fx != old_fx) { bracket around the digitalWrite part it works as expected, but it seems like a waste of CPU to run the digitalWrite even if nothing has changed. or is this just how it works? but why would it then work in the example patch by just writing once per change?
    Full code? It could be that something else is resetting the value of those channels and/or changing their direction
    sure (still in development, so a bit messy)
     ____  _____ _        _
    | __ )| ____| |      / \
    |  _ \|  _| | |     / _ \
    http://bela.io
    #include <cmath>
    #include <Heavy_bela.h>
    #include <string.h>
    #include <stdlib.h>
    #include <string>
    #include <sstream>
    #include <algorithm>
    #include <array>
    #include <SampleLoader.h>
    #include <SampleData.h>
    #include <BelaContextFifo.h>
    #include <vector>
    Lv2Host gLv2Host;
    int gLedPin = 0;
    //float gUpdateInterval = 0.05;
    bool heavy_lv2 = 0;
    //patch switching switch
    #define DEBOUNCE_TIME 200 //how long the button has to be "off" to be considered off
    bool cState_b0 = 0;
    bool pState_b0 = 1;
    bool cState_b1 = 0;
    bool pState_b1 = 1;
    int fx_nr = 0;
    int old_fx = 1;
    //scales to choose
    bool octave = 0;
    bool powercut = 0;
    bool echo = 0;
    bool gIsNoteOn = 0;
    int gVelocity = 0;
    int gNote = 0;
    int gControl = 0;
    int oldControl = 0;
    int gCCVal = 0;
    int choose_fx = 0;
    int tap_count = 0;
    bool vocoder = 1;
    BelaContextFifo gBcf;
    double gBlockDurationMs;
    static unsigned int gAudioChannelsInUse;
    unsigned int gScopeChannelsInUse;
    static unsigned int gFirstAnalogChannel;
    static unsigned int gDigitalChannelOffset;
    static unsigned int gDigitalSigInChannelsInUse;
    static unsigned int gDigitalSigOutChannelsInUse;
    float* gScopeOut;
    // Bela Scope
    static Scope* scope = NULL;
    bool gDigitalEnabled = 0;
    // Bela Midi
    unsigned int hvMidiHashes[7]; // heavy-specific
    void longRender(BelaContext* context, void* arg)
    	/*	if (fx_nr == 1) {
    	} else if (fx_nr == 2) {
    		if (fx_nr == 1) {
    	gLv2Host.disconnect(5,0);
    	gLv2Host.bypass(3,0);
    	gLv2Host.bypass(4,0);
    	gLv2Host.bypass(5,1);
    	gLv2Host.connect(3,0,4,0);
    	gLv2Host.connect(4,0,6,0);
    	} else if (fx_nr==2) {
    	gLv2Host.disconnect(6,0);
    	gLv2Host.bypass(3,1);
    	gLv2Host.bypass(4,1);
    	gLv2Host.bypass(5,0);
    	gLv2Host.connect(2,0,5,0);
    	gLv2Host.connect(5,0,6,0);
    frame_count++;
    	tap_count = 0;
     // code here runs at "long" blocksize
    	switch (gControl) {
    				case 7: {
    						gLv2Host.setPort(2, 3, float(gCCVal/127.0));
    					break;
    				case 8: {
    					break;
    				case 9: {
    						gLv2Host.setPort(8, 6, (gCCVal/8) + 1);
    					break;
    				case 10: {
    					gLv2Host.setPort(9, 2, float(gCCVal/ 127.0));
    					break;
    		if(gIsNoteOn == 1){
    		switch (gNote) {
    			case 20: {
    			if (!echo) {
    				gLv2Host.setPort(8, 10, 0.3);
    				echo = 1;
    			} else {
    			gLv2Host.setPort(8, 10, 0);
    				echo = 0;
    				break;
    			case 21: {
    					tap_count = 0;
    				vocoder = !vocoder;
    				break;
    			case 22: {
    			if (!octave) {
    				gLv2Host.setPort(3, 3, 1);
    				gLv2Host.setPort(3, 4, 1);
    				octave = 1;
    			} else {
    				octave = 0;
    				break;
    			case 23: {
    				// subsynth
    				if (!powercut) {
    					powercut = 1;
    				} else {
    				powercut = 0;
    				break;
    			case 36: {
    	gLv2Host.setPort(1, n + 12, scale[n]);
    			break;
    		case 37: {
    			break;
    	case 38: {
    			break;
        case 39: {
    				scale = chromatic;
    				break;
    	case 40: {
    	break;
    	case 41: {
    	break;
    	case 42: {
    	break;
    	case 43: {
    		scale = major;
    		break;
    	case 44: {
    	break;
    	case 45: {
    	break;
    	case 46: {
    	break;
    			case 47: {
    				scale = minor;
    				break;
    				case 48: {
    	break;
    	case 49: {
    	break;
    	case 50: {
    	break;
    			case 51: {
    				scale = penta;
    				break;
    		gIsNoteOn = 0;
    void longThread(void*)
       while(!gShouldStop)
        //   BelaContext* context = gBcf.pop(BelaContextFifo::kToLong, gBlockDurationMs * 2);
        BelaContext* context = gBcf.pop(BelaContextFifo::kToLong, 100); // wait up to 100ms
            if(context)
           //     ((InternalBelaContext*)context)->audioFramesElapsed = audioFramesElapsed; // keep track of elapsed samples if your longRender needs it
                longRender(context, NULL);
    //            audioFramesElapsed += context->audioFrames;
                gBcf.push(BelaContextFifo::kToShort, context);
            } else {
             //   if(gRTAudioVerbose)
               //   rt_fprintf(stderr, "fifoTask did not receive a valid context\n");
                usleep(10000); // TODO: this  should not be needed, given how the timeout in pop() is for a reasonable amount of time
    AuxiliaryTask longThreadTask;
    void dumpMidi()
    	if(midi.size() == 0)
    		return;
    			"Num",
    			"Name",
    			"In",
    			"Out",
    			"Pd channels"
    			n,
    			gMidiPortNames[n].c_str(),
    			n * 16 + 1,
    			n * 16 + 16
    	Midi* newMidi;
    	newMidi = new Midi();
    	newMidi->enableParser(true);
    		if(verboseSuccess)
    	if(newMidi->isInputEnabled())
    		if(verboseSuccess)
    		if(verboseError)
    			fprintf(stderr, "Failed to open  MIDI device %s\n", name.c_str());
    		return nullptr;
    	} else {
    		return newMidi;
    	unsigned int port = 0;
    	while(*channel > 16){
    		*channel -= 16;
    		port += 1;
    	if(port >= midi.size()){
    		// if the port number exceeds the number of ports available, send out
    		// of the first port
    		port = 0;
    	return port;
     *	HEAVY CONTEXT & BUFFERS
    HeavyContextInterface *gHeavyContext;
    float *gHvInputBuffers = NULL, *gHvOutputBuffers = NULL;
    unsigned int gHvInputChannels = 0, gHvOutputChannels = 0;
    uint32_t multiplexerTableHash;
    float gInverseSampleRate;
     *	HEAVY FUNCTIONS
    void printHook(HeavyContextInterface *context, const char *printLabel, const char *msgString, const HvMessage *msg) {
    	const double timestampSecs = ((double) hv_msg_getTimestamp(msg)) / hv_getSampleRate(context);
    	rt_printf("Message from Heavy patch: [@ %.3f] %s: %s\n", timestampSecs, printLabel, msgString);
    // digitals
    	hv_sendFloatToReceiver(gHeavyContext, hv_stringToHash((char*)receiverName), (float)state);
    //	rt_printf("%s: %d\n", (char*)receiverName, state);
    std::vector<std::string> gHvDigitalInHashes;
    void generateDigitalNames(unsigned int numDigitals, unsigned int digitalOffset, std::vector<std::string>& receiverInputNames)
    		receiverInputNames.push_back(inBaseString + std::to_string(i+digitalOffset));
    // For a message to be received here, you need to use the following syntax in Pd:
    // [send receiverName @hv_param]
    static void sendHook(
    		const char *receiverName,
    		hv_uint32_t sendHash,
    		const HvMessage *m) {
    	// Bela digital run-time messages
    	// TODO: this first block is almost an exact copy of libpd's code, should we add this to the class?
    	// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between 11 and 26
    	static const int prefixLength = 15; // strlen("bela_digitalOut")
    	if(strncmp(receiverName, "bela_digitalOut", prefixLength)==0){
    		if(receiverName[prefixLength] != 0){ //the two ifs are used instead of if(strlen(source) >= prefixLength+2)
    			if(receiverName[prefixLength + 1] != 0){
    				int receiver = ((receiverName[prefixLength] - '0') * 10);
    				receiver += (receiverName[prefixLength+1] - '0');
    				unsigned int channel = receiver - gDigitalChannelOffset; // go back to the actual Bela digital channel number
    				bool value = (hv_msg_getFloat(m, 0) != 0.0f);
    				if(channel < gDigitalChannelsInUse){ //gDigitalChannelsInUse is the number of digital channels
    					dcm.setValue(channel, value);
    		return;
    	// More MIDI and digital messages. To obtain the hashes below, use hv_stringToHash("yourString")
    	switch (sendHash) {
    		case 0xfb212be8: { // bela_setMidi
    			if (!hv_msg_hasFormat(m, "sfff")) {
    				fprintf(stderr, "Wrong format for Bela_setMidi, expected:[hw 1 0 0(");
    				return;
    			const char* symbol = hv_msg_getSymbol(m, 0);
    			int num[3] = {0, 0, 0};
    			for(int n = 0; n < 3; ++n)
    				num[n] = hv_msg_getFloat(m, n + 1);
    			Midi* newMidi = openMidiDevice(deviceName.str(), true, true);
    			if(newMidi)
    				midi.push_back(newMidi);
    			dumpMidi();
    			break;
    		case 0x70418732: { // bela_setDigital
    			if(gDigitalEnabled)
    				// Third argument (optional) can be ~ or sig for signal-rate, message-rate otherwise.
    				// [in 14 ~(
    				// [s bela_setDigital]
    				bool disable = false;
    				if (!(hv_msg_isSymbol(m, 0) && hv_msg_isFloat(m, 1))) return;
    				const char *symbol = hv_msg_getSymbol(m, 0);
    					direction = INPUT;
    					direction = OUTPUT;
    					disable = true;
    				} else {
    					return;
    				int channel = hv_msg_getFloat(m, 1) - gDigitalChannelOffset;
    				if(disable == true){
    					dcm.unmanage(channel);
    					return;
    				if(hv_msg_isSymbol(m, 2)){
    					const char *s = hv_msg_getSymbol(m, 2);
    					if(strcmp(s, "~") == 0  || strncmp(s, "sig", 3) == 0){
    						isMessageRate = false;
    			break;
    		case 0xd1d4ac2: { // __hv_noteout
    			if (!hv_msg_hasFormat(m, "fff")) return;
    			midi_byte_t pitch = (midi_byte_t) hv_msg_getFloat(m, 0);
    			midi_byte_t velocity = (midi_byte_t) hv_msg_getFloat(m, 1);
    			int channel = (midi_byte_t) hv_msg_getFloat(m, 2);
    		//	rt_printf("noteon[%d]: %d %d %d\n", port, channel, pitch, velocity);
    			midi[port]->writeNoteOn(channel, pitch, velocity);
    			break;
    		case 0xe5e2a040: { // __hv_ctlout
    			midi_byte_t value = (midi_byte_t) hv_msg_getFloat(m, 0);
    			midi_byte_t controller = (midi_byte_t) hv_msg_getFloat(m, 1);
    		//	rt_printf("controlchange[%d]: %d %d %d\n", port, channel, controller, value);
    			midi[port]->writeControlChange(channel, controller, value);
    			break;
    		case 0x8753e39e: { // __hv_pgmout
    			midi_byte_t program = (midi_byte_t) hv_msg_getFloat(m, 0);
    			int channel = (midi_byte_t) hv_msg_getFloat(m, 1);
    		//	rt_printf("programchange[%d]: %d %d\n", port, channel, program);
    			midi[port]->writeProgramChange(channel, program);
    			break;
    		case 0xe8458013: { // __hv_bendout
    			if (!hv_msg_hasFormat(m, "ff")) return;
    			unsigned int value = ((midi_byte_t) hv_msg_getFloat(m, 0)) + 8192;
    		//	rt_printf("pitchbend[%d]: %d %d\n", port, channel, value);
    			midi[port]->writePitchBend(channel, value);
    			break;
    		case 0x476d4387: { // __hv_touchout
    			midi_byte_t pressure = (midi_byte_t) hv_msg_getFloat(m, 0);
    		//	rt_printf("channelPressure[%d]: %d %d\n", port, channel, pressure);
    			midi[port]->writeChannelPressure(channel, pressure);
    			break;
    		case 0xd5aca9d1: { // __hv_polytouchout, not currently supported by Heavy. You have to [send __hv_polytouchout]
    			midi_byte_t pressure = (midi_byte_t) hv_msg_getFloat(m, 1);
    		//	rt_printf("polytouch[%d]: %d %d %d\n", port, channel, pitch, pressure);
    			midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
    			break;
    		case 0x6511de55: { // __hv_midiout, not currently supported by Heavy. You have to [send __hv_midiout]
    			midi_byte_t byte = (midi_byte_t) hv_msg_getFloat(m, 0);
    			int port = (int) hv_msg_getFloat(m, 1);
    		//	rt_printf("port: %d, byte: %d\n", port, byte);
    			midi[port]->writeOutput(byte);
    			break;
    		case 0x6E64CDC1: { //save_table custom
    		   if (!hv_msg_hasFormat(m, "f")) return;
    		   int bank_nr = (int) hv_msg_getFloat(m, 0);
    		   char fileName4[10];
    		    sprintf(fileName4, "presets%d.wav", bank_nr);
    		    //const char fileName[] = "presets.wav";
    		const char tableName[] = "presets";
    		hv_uint32_t tableHash = hv_stringToHash(tableName);
    			float * table = hv_table_getBuffer(gHeavyContext, tableHash);
    			writeSamples(fileName4, table, 656);
    		break;
    		  	  case 0x116A3F3C: { //switch_preset_file
    		    char fileName3[10];
    		    sprintf(fileName3, "presets%d.wav", bank_nr);
    int sampleLen = getNumFrames(fileName3);
    hv_table_setLength(gHeavyContext, tableHash, sampleLen); // resize the table
    float * table = hv_table_getBuffer(gHeavyContext, tableHash); // once resized, get a pointer to the array
    int channel = 0; // take the first channel of the file
    int startFrame = 0; // start from the beginning
    int lastFrame = sampleLen; // until the end of the file
    getSamples(fileName3, table, channel, startFrame, lastFrame);
    		break;
    	/*	case 0x5466427a: { //save current preset for restart
    		    const char fileName[] = "current.wav";
    		const char tableName[] = "current";
    			writeSamples(fileName, table, 2);
    		break;
    		default: {
    			break;
     * SETUP, RENDER LOOP & CLEANUP
    bool setup(BelaContext *context, void *userData)	{
    	        int fifoFactor = 8; // 16 to 128
            BelaContext* longContext = gBcf.setup(context, fifoFactor);
            if(!longContext)
            	fprintf(stderr, "Error: unable to initialise BelaContextFifo\n");
                 return false;}
           longThreadTask = Bela_createAuxiliaryTask(longThread, 94, "long-thread", NULL);
           Bela_scheduleAuxiliaryTask(longThreadTask);
         gBlockDurationMs = context->audioFrames * fifoFactor / context->audioSampleRate * 1000;
          //long thread setup (lv2host)
    		return false;
    	if(!gLv2Host.setup(longContext->audioSampleRate, longContext->audioFrames,
    				longContext->audioInChannels, longContext->audioOutChannels))
    		return false;
    		gLv2Host.add(name);
    		return false;
    //noisegate
    gLv2Host.setPort(0, 0, -15);
    	gLv2Host.setPort(0, 2, -20);
    	//autotune
    //vocoder (talkbox)
    				gLv2Host.setPort(3, 2, 1);
    					//mda subsynth
    	//compressor
    	gLv2Host.setPort(5, 1, 2);
    	gLv2Host.setPort(5, 3, 0.6);
    	gLv2Host.setPort(5, 4, 0.3);
    //	gLv2Host.setPort(5, 6, 20);
    	//mda detune
    	gLv2Host.setPort(6, 0,0.1 );
    	gLv2Host.setPort(6, 1,0.5 );
    gLv2Host.setPort(6, 3,0.3 );
    	gLv2Host.setPort(6, 2, 0.3);
    //mda stereo
    	gLv2Host.setPort(7, 0, 0.5);
    	gLv2Host.setPort(7, 1, 0.3);
    	//echo
    	gLv2Host.setPort(8, 11, 0);
    	gLv2Host.setPort(8, 4, 100);
    	//_reverb
    	gLv2Host.setPort(9, 0, 40);
    	gLv2Host.setPort(9, 3, 0.1);
    	// Turn LED on
    //	pinMode(context, 0, gLedPin, OUTPUT); // Set pin as output
    //	digitalWrite(context, 0, gLedPin, 1); //Turn LED on
    //	return true;
    	// Check if digitals are enabled
    		gDigitalEnabled = 1;
    	gAudioChannelsInUse = std::max(context->audioInChannels, context->audioOutChannels);
    	gAnalogChannelsInUse = std::max(context->analogInChannels, context->analogOutChannels);
    	// Channel distribution
    	gFirstAnalogChannel = std::max(context->audioInChannels, context->audioOutChannels);
    	gFirstDigitalChannel = gFirstAnalogChannel + std::max(context->analogInChannels, context->analogOutChannels);
    	gDigitalChannelOffset = gFirstDigitalChannel + 1;
    	// Create hashes for digital channels
    	generateDigitalNames(gDigitalChannelsInUse, gDigitalChannelOffset, gHvDigitalInHashes);
    	/* HEAVY */
    	std::array<std::string,  11> outs = {{
    		"__hv_noteout",
    		"__hv_ctlout",
    		"__hv_pgmout",
    		"__hv_touchout",
    		"__hv_polytouchout",
    		"__hv_bendout",
    		"__hv_midiout",
    		"switch_bank",
    		"save_table",
    		"last_state",
    /*	for(auto &st : outs)
    		// uncomment this if you want to display the hashes for midi
    		// outs. Then hardcode them in the switch() in sendHook()
    	  //	printf("%s: %#x\n", st.c_str(), hv_stringToHash(st.c_str()));
    	hvMidiHashes[kmmNoteOn] = hv_stringToHash("__hv_notein");
    //	hvMidiHashes[kmmNoteOff] = hv_stringToHash("noteoff"); // this is handled differently, see the render function
    	hvMidiHashes[kmmControlChange] = hv_stringToHash("__hv_ctlin");
    	// Note that the ones below are not defined by Heavy, but they are here for (wishing) forward-compatibility
    	// You need to receive from the corresponding symbol in Pd and unpack the message, e.g.:
    	//[r __hv_pgmin]
    	//[unpack f f]
    	//|   [print pgmin_channel]
    	//[print pgmin_number]
    	hvMidiHashes[kmmProgramChange] = hv_stringToHash("__hv_pgmin");
    	hvMidiHashes[kmmPolyphonicKeyPressure] = hv_stringToHash("__hv_polytouchin");
    	hvMidiHashes[kmmChannelPressure] = hv_stringToHash("__hv_touchin");
    	hvMidiHashes[kmmPitchBend] = hv_stringToHash("__hv_bendin");
    	gHeavyContext = hv_bela_new_with_options(context->audioSampleRate, 10, 2, 0);
    	gHvInputChannels = hv_getNumInputChannels(gHeavyContext);
    	gHvOutputChannels = hv_getNumOutputChannels(gHeavyContext);
    	// add the lines below
    	//	int k = 0;
    	/*	const char fileName[] = "presets0.wav";
       //sprintf(lengthName, "samplelength%d", k);
    int sampleLen = getNumFrames(fileName);
    getSamples(fileName, table, channel, startFrame, lastFrame);
    const char fileName5[] = "current.wav";
    const char tableName5[] = "current";
    int sampleLen5 = getNumFrames(fileName5);
    hv_uint32_t tableHash5 = hv_stringToHash(tableName5);
    hv_table_setLength(gHeavyContext, tableHash5, sampleLen5); // resize the table
    float * table5 = hv_table_getBuffer(gHeavyContext, tableHash5); // once resized, get a pointer to the array
    int lastFrame5 = sampleLen5; // until the end of the file
    getSamples(fileName5, table5, channel, startFrame, lastFrame5);
    char fileName2[10];
     char tableName2[8];
     //char lengthName2[14];
     for (int k = 0; k < 48; k++) {
       sprintf(fileName2, "wt%d.wav", k);
       sprintf(tableName2, "wt%d", k);
       //  sprintf(lengthName2, "samplelength%d", k);
    int sampleLen = getNumFrames(fileName2);
    hv_uint32_t tableHash = hv_stringToHash(tableName2);
    getSamples(fileName2, table, channel, startFrame, lastFrame);
    	gScopeChannelsInUse = gHvOutputChannels > gFirstScopeChannel ?
    			gHvOutputChannels - gFirstScopeChannel : 0;
    	if(gDigitalEnabled)
    		gDigitalSigInChannelsInUse = gHvInputChannels > gFirstDigitalChannel ?
    			gHvInputChannels - gFirstDigitalChannel : 0;
    		gDigitalSigOutChannelsInUse = gHvOutputChannels > gFirstDigitalChannel ?
    			gHvOutputChannels - gFirstDigitalChannel - gScopeChannelsInUse: 0;
    	else
    		gDigitalSigInChannelsInUse = 0;
    		gDigitalSigOutChannelsInUse = 0;
    	printf("Starting Heavy context with %d input channels and %d output channels\n",
    			gHvInputChannels, gHvOutputChannels);
    	printf("Channels in use:\n");
    	printf("Digital in : %u, Digital out: %u\n", gDigitalSigInChannelsInUse, gDigitalSigOutChannelsInUse);
    	printf("Scope out: %u\n", gScopeChannelsInUse);
    	if(gHvInputChannels != 0) {
    		gHvInputBuffers = (float *)calloc(gHvInputChannels * context->audioFrames,sizeof(float));
    	if(gHvOutputChannels != 0) {
    		gHvOutputBuffers = (float *)calloc(gHvOutputChannels * context->audioFrames,sizeof(float));
    	// Set heavy print hook
    	hv_setPrintHook(gHeavyContext, printHook);
    	// Set heavy send hook
    	hv_setSendHook(gHeavyContext, sendHook);
    	unsigned int n = 0;
    		Midi* newMidi = openMidiDevice(gMidiPortNames[n], true, true);
    		if(newMidi)
    			++n;
    		} else {
    	dumpMidi();
    	if(gScopeChannelsInUse > 0){
    #if __clang_major__ == 3 && __clang_minor__ == 8
    		fprintf(stderr, "Scope currently not supported when compiling heavy with clang3.8, see #265 https://github.com/BelaPlatform/Bela/issues/265. You should specify `COMPILER gcc;` in your Makefile options\n");
    		exit(1);
    #endif
    		scope = new Scope();
    		scope->setup(gScopeChannelsInUse, context->audioSampleRate);
    	// Bela digital
    	if(gDigitalEnabled)
    		if(gDigitalChannelsInUse> 0){
    				dcm.setCallbackArgument(ch, (void *) gHvDigitalInHashes[ch].c_str());
    	// unlike libpd, no need here to bind the bela_digitalOut.. receivers
    	// but make sure you do something like [send receiverName @hv_param]
    	// when you want to send a message from Heavy to the wrapper.
    	multiplexerTableHash = hv_stringToHash(multiplexerArray);
    	if(context->multiplexerChannels > 0){
    		pdMultiplexerActive = true;
    		hv_table_setLength(gHeavyContext, multiplexerTableHash, multiplexerArraySize);
    		hv_sendFloatToReceiver(gHeavyContext, hv_stringToHash("bela_multiplexerChannels"), context->multiplexerChannels);
    		fx_nr = (fx_nr + 1)%3;
    		rt_printf("fx_nr: %d\n", fx_nr);
    //button is pressed down
        debounce_b0++;
        cState_b0 = 0;
    	if (fx_nr != old_fx) {
    switch (fx_nr) {
     case 0: {
       break;
     case 1: {
       break;
      case 2: {
       break;
     old_fx = fx_nr;
    	if (fx_nr == 0) {
    	int num;
    			switch(message.getType()){
    			case kmmNoteOn: {
    				//message.prettyPrint();
    				if (velocity > 0) gIsNoteOn = 1;
    				gNote = noteNumber;
    				// rt_printf("message: noteNumber: %f, velocity: %f, channel: %f\n", noteNumber, velocity, channel);
    				hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmNoteOn], 0, "fff",
    						(float)noteNumber, (float)velocity, (float)channel+1);
    				break;
    			case kmmNoteOff: {
    				 * with a velocity of 0.
    				// note we are sending the below to hvHashes[kmmNoteOn] !!
    						(float)noteNumber, (float)0, (float)channel+1);
    				break;
    			case kmmControlChange: {
    				gControl = controller;
    				gCCVal = value;
    				hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmControlChange], 0, "fff",
    						(float)value, (float)controller, (float)channel+1);
    				break;
    			case kmmProgramChange: {
    				hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmProgramChange], 0, "ff",
    						(float)program, (float)channel+1);
    				break;
    			case kmmPolyphonicKeyPressure: {
    				//TODO: untested, I do not have anything with polyTouch... who does, anyhow?
    				hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmPolyphonicKeyPressure], 0, "fff",
    						(float)channel+1, (float)pitch, (float)value);
    				break;
    			case kmmChannelPressure:
    				hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmChannelPressure], 0, "ff",
    						(float)value, (float)channel+1);
    				break;
    			case kmmPitchBend:
    				int value = ((message.getDataByte(1) << 7) | message.getDataByte(0));
    				hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmPitchBend], 0, "ff",
    				break;
    			case kmmSystem:
    			case kmmNone:
    			case kmmAny:
    				break;
    	// De-interleave the data
    	if(gHvInputBuffers != NULL) {
    			for(unsigned int ch = 0; ch < gHvInputChannels; ch++) {
    				if(ch >= gAudioChannelsInUse + gAnalogChannelsInUse) {
    					// THESE ARE PARAMETER INPUT 'CHANNELS' USED FOR ROUTING
    					// 'sensor' outputs from routing channels of dac~ are passed through here
    					// these could be also digital channels (handled by the dcm)
    					// or parameter channels used for routing (currently unhandled)
    					break;
    				} else {
    					// If more than 2 ADC inputs are used in the pd patch, route the analog inputs
    					// i.e. ADC3->analogIn0 etc. (first two are always audio inputs)
    					if(ch >= gAudioChannelsInUse)
    						unsigned int analogCh = ch - gAudioChannelsInUse;
    						if(analogCh < context->analogInChannels)
    							int m = n;
    							float mIn = analogReadNI(context, m, analogCh);
    							gHvInputBuffers[ch * context->audioFrames + n] = mIn;
    					} else {
    						if(ch < context->audioInChannels)
    							gHvInputBuffers[ch * context->audioFrames + n] = audioReadNI(context, n, ch);
    	if(pdMultiplexerActive){
    			memcpy(hv_table_getBuffer(gHeavyContext, multiplexerTableHash), (float *const)context->multiplexerAnalogIn, multiplexerArraySize * sizeof(float));
    	// Bela digital in
    	if(gDigitalEnabled)
    		// note: in multiple places below we assume that the number of digital frames is same as number of audio
    		// Bela digital in at message-rate
    		dcm.processInput(context->digital, context->digitalFrames);
    		// Bela digital in at signal-rate
    		if(gDigitalSigInChannelsInUse > 0)
    			unsigned int j, k;
    			float *p0, *p1;
    			const unsigned int gLibpdBlockSize = context->audioFrames;
    			const unsigned int  audioFrameBase = 0;
    			float* gInBuf = gHvInputBuffers;
    			// block below copy/pasted from libpd, except
    			// 16 has been replaced with gDigitalSigInChannelsInUse
    				unsigned int digitalFrame = audioFrameBase + j;
    						k < gDigitalSigInChannelsInUse; ++k, p1 += gLibpdBlockSize) {
    	// replacement for bang~ object
    	//hv_sendMessageToReceiverV(gHeavyContext, "bela_bang", 0.0f, "b");
    	// heavy audio callback
    	hv_processInline(gHeavyContext, gHvInputBuffers, gHvOutputBuffers, context->audioFrames);
    	for(int n = 0; n < context->audioFrames*gHvOutputChannels; ++n)
    		printf("%.3f, ", gHvOutputBuffers[n]);
    		if(n % context->audioFrames == context->audioFrames - 1)
    			printf("\n");
    	// Bela digital out
    	if(gDigitalEnabled)
    		// Bela digital out at signal-rate
    		if(gDigitalSigOutChannelsInUse > 0)
    				unsigned int j, k;
    				float *p0, *p1;
    				float* gOutBuf = gHvOutputBuffers;
    				// context->digitalChannels has been replaced with gDigitalSigOutChannelsInUse
    					unsigned int digitalFrame = (audioFrameBase + j);
    							k < gDigitalSigOutChannelsInUse; k++, p1 += gLibpdBlockSize) {
    		// Bela digital out at message-rate
    		dcm.processOutput(context->digital, context->digitalFrames);
    	// Bela scope
    		unsigned int j, k;
    		float *p0, *p1;
    			for (k = 0, p1 = p0  + gLibpdBlockSize * gFirstScopeChannel; k < gScopeChannelsInUse; k++, p1 += gLibpdBlockSize) {
    				gScopeOut[k] = *p1;
    			scope->log(gScopeOut);
    	// Interleave the output data
    	if(gHvOutputBuffers != NULL) {
    			for(unsigned int ch = 0; ch < gHvOutputChannels; ch++) {
    					// THESE ARE SENSOR OUTPUT 'CHANNELS' USED FOR ROUTING
    					// they are the content of the 'sensor output' dac~ channels
    				} else {
    					if(ch >= gAudioChannelsInUse)	{
    						int m = n;
    						if(analogCh < context->analogOutChannels)
    							analogWriteOnceNI(context, m, analogCh, gHvOutputBuffers[ch*context->audioFrames + n]);
    					} else {
    						if(ch < context->audioOutChannels)
    							audioWriteNI(context, n, ch, gHvOutputBuffers[ch * context->audioFrames + n]);
    } else {
    		int num;
    			case kmmNoteOn: {
    			//	int channel = message.getChannel();
    				break;
    			case kmmNoteOff: {
    				break;
    				break;
    			case kmmPitchBend:
    			case kmmSystem:
    			case kmmNone:
    			case kmmAny:
    			break;
    		gBcf.push(BelaContextFifo::kToLong, context);
    /// receive from the "long" render
        const InternalBelaContext* rctx = (InternalBelaContext*)gBcf.pop(BelaContextFifo::kToShort);
        if(rctx) {
            BelaContextSplitter::contextCopyData(rctx, (InternalBelaContext*)context);
    	hv_delete(gHeavyContext);
    	free(gHvInputBuffers);
    	free(gHvOutputBuffers);
    	delete[] gScopeOut;
    	delete scope;
    i already tried commenting the digital write and read parts in the heavy render, but that did not help...
    so, even with the whole heavy part in render commented out the problem still persists, my guess is that the switching of blocksize via
         if(rctx) {
    is somehow causing this.
    Probably a bug in the BelaContextSplitter, or in its integration. Will have a look tomorrow
    so it seems that the persistency of analog and digital outputs is broken when using the BelaContextSplitter. There is no easy solution for it, as it requires quite some refactoring of the code, moving/copying the handling of persistency of digitals and analogs from PRU.cpp to BelaContextSplitter::pop().
    lokki bracket around the digitalWrite part it works as expected, but it seems like a waste of CPU to run the digitalWrite even if nothing has changed. or is this just how it works?
    It is not actually a huge waste of CPU, so you should be able to safely remove the conditional if (switch_fx != old_fx) { and everything will be fine.
      giuliomoro so it seems that the persistency of analog and digital outputs is broken when using the BelaContextSplitter
      good to know i am not crazy and thanks for checking.
