Dear giuliomoro @giuliomoro ,
I'm currently working on a project that involves acquiring six input channels and processing them into two output channels. Ideally, I would like to maintain a sampling rate of 44.1kHz throughout the system. I am using the Bela Starter Kit (REV C) along with the Audio Expander.
From the discussion before, I understand that when using more than four channels on the expander, the sampling rate is reduced to 22.05kHz. I was wondering: would it be possible to instead use 2 audio input channels from the audio channel on the Bela cape and 4 analog input channels from the expander, all at 44.1kHz, to achieve the required six input channels?
Do you know if this configuration is supported, or if there are any limitations I should be aware of?
Thank you very much for your time and assistance.
