Curious if anyone has managed to tame voltage output well enough for getting quantized pitch values out of bela pepper.
Assuming 5v output, mapped 0-1 within PD, 1v would be equal to .2 in PD. Divide that by 12 for semitones and you get .0166666666 (6 repeating).
The problem appears to be that real voltage output deviates quite a bit from calculated values within PD. The deviation also seems to grow slightly as pitch gets higher. I know this is expected because analog values are not THAT precise.
Has anyone ever found a way to compensate for this and get closer to desired values?
