RexOsaurus It seems as though there is a file called osc.ini that takes:
remoteip = 192.168.1.92
localport = 65001
remoteport = 65002
When I match the values above with the OSC connection values in TouchOSC the connection does not work:
Host: 192.168.1.92
Send Port: 65001
Receive Port: 65002
The ports seem OK: where one sends, the other receives and viceversa; the remoteIp and Host depend on the IP addresses of the TouchOSC and Bela device on the network they are both on (I assume your Bela is connected to WiFi?), but in any case they cannot be the same. On Bela, you need to set as remoteIp the address of the TouchOSC device. How to retrieve the address of that depends on your device.
On the TouchOSC device you need to send as Host the IP address of Bela. It may be that bela.local works as a wildcard as a Host on TouchOSC, otherwise here's how to find out the IP address of Bela. To find out the IP address of Bela, you can run ip a in the console at the bottom of the IDE and that will print the IP addresses of all the interfaces. You will typically see something like:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether c8:a0:30:bf:8e:37 brd ff:ff:ff:ff:ff:ff
3: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether be:1a:30:bf:8e:39 brd ff:ff:ff:ff:ff:ff
inet6 fe80::bc1a:30ff:febf:8e39/64 scope link
4: usb1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether be:1a:30:bf:8e:3c brd ff:ff:ff:ff:ff:ff
inet6 fe80::bc1a:30ff:febf:8e3c/64 scope link
If your ethernet cable is connected, then eth0 will also show an IP address and if you have a wireless dongle connected to it, you will see another interface, typically called wlan0, which will have an IP address if it is properly connected to a network. usb0 and usb1 are the IP addresses of the board on the virtual networks over USB (see here). The IP address to pick depends on how the board is connected to the TouchOSC device: pick the IP address from the corresponding network interfac (if connected via USB, probably 192.168.7.2 is the one that most commonly works).
