I am having the same issue as the original poster, using the same dongle and driver. I do not know how to compile the externally provided driver, but there is some driver preinstalled in the OS.
root@bela:~# ifdown wlan0; ifup wlan0 --verbose
ifup: configuring interface wlan0=wlan0 (inet)
/bin/run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/hostapd
hostapd: /usr/sbin/hostapd -B -P /run/hostapd.wlan0.pid /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211 driver initialization failed.
wlan0: interface state UNINITIALIZED->DISABLED
wlan0: AP-DISABLED
hostapd_free_hapd_data: Interface wlan0 wasn't started
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
/bin/ip addr add 192.168.30.1/255.255.255.0 broadcast 192.168.30.255 dev wlan0 label wlan0
/bin/ip link set dev wlan0 up
/bin/run-parts --exit-on-error --verbose /etc/network/if-up.d
run-parts: executing /etc/network/if-up.d/avahi-daemon
run-parts: executing /etc/network/if-up.d/openssh-server
run-parts: executing /etc/network/if-up.d/upstart
run-parts: executing /etc/network/if-up.d/wpasupplicant
root@bela:~# dmesg
[ 0.000000] Linux version 4.14.108-ti-xenomai-r143 (giulio@builder) (gcc version 7.5.0 (GCC)) #1xross PREEMPT Thu Nov 4 22:48:35 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c13d4ac8, node_mem_map dfb79000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x3c8 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[ 0.000000] Memory: 498260K/524288K available (12288K kernel code, 962K rwdata, 3608K rodata, 1024K init, 843K bss, 26028K reserved, 0K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1300000 (1024 kB)
.data : 0xc1300000 - 0xc13f0af4 ( 963 kB)
.bss : 0xc13f2000 - 0xc14c4e54 ( 844 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000039] I-pipe, 24.000 MHz clocksource, wrap in 178956 ms
[ 0.000058] clocksource: ipipe_tsc: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000081] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000090] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002197] timer_probe: no matching timers found
[ 0.002575] Interrupt pipeline (release #7)
[ 0.002912] Console: colour dummy device 80x30
[ 0.002964] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.021589] pid_max: default: 32768 minimum: 301
[ 0.021794] Security Framework initialized
[ 0.021811] Yama: becoming mindful.
[ 0.021855] AppArmor: AppArmor disabled by boot time parameter
[ 0.021926] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.021940] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.022953] CPU: Testing write buffer coherency: ok
[ 0.023023] CPU0: Spectre v2: using BPIALL workaround
[ 0.023998] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.024203] Hierarchical SRCU implementation.
[ 0.028632] devtmpfs: initialized
[ 0.048084] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.048549] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.048573] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.048922] xor: automatically using best checksumming function neon
[ 0.048936] pinctrl core: initialized pinctrl subsystem
[ 0.051112] NET: Registered protocol family 16
[ 0.052726] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.103158] omap_hwmod: debugss: _wait_target_disable failed
[ 0.153292] OMAP GPIO hardware version 0.1
[ 0.170985] No ATAGs?
[ 0.171008] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.182951] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.182966] raid6: .... xor() 0 MB/s, rmw enabled
[ 0.182974] raid6: using neon recovery algorithm
[ 0.192286] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.199053] SCSI subsystem initialized
[ 0.199364] usbcore: registered new interface driver usbfs
[ 0.199428] usbcore: registered new interface driver hub
[ 0.199595] usbcore: registered new device driver usb
[ 0.200343] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.200411] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.200459] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.200680] pps_core: LinuxPPS API ver. 1 registered
[ 0.200688] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.200713] PTP clock support registered
[ 0.201764] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.202544] Advanced Linux Sound Architecture Driver Initialized.
[ 0.203261] NetLabel: Initializing
[ 0.203276] NetLabel: domain hash size = 128
[ 0.203283] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.203384] NetLabel: unlabeled traffic allowed by default
[ 0.203978] clocksource: Switched to clocksource ipipe_tsc
[ 0.372449] VFS: Disk quotas dquot_6.6.0
[ 0.372540] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.386096] NET: Registered protocol family 2
[ 0.387031] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.387078] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.387117] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.387245] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.387265] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.387498] NET: Registered protocol family 1
[ 0.388365] RPC: Registered named UNIX socket transport module.
[ 0.388378] RPC: Registered udp transport module.
[ 0.388385] RPC: Registered tcp transport module.
[ 0.388391] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.389387] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.389538] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.391358] audit: initializing netlink subsys (disabled)
[ 0.392612] [Xenomai] scheduling class idle registered.
[ 0.392623] [Xenomai] scheduling class rt registered.
[ 0.392769] I-pipe: head domain Xenomai registered.
[ 0.394254] audit: type=2000 audit(0.388:1): state=initialized audit_enabled=0 res=1
[ 0.400652] [Xenomai] Cobalt v3.0.11 [DEBUG]
[ 0.400824] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.408247] zbud: loaded
[ 0.411367] NFS: Registering the id_resolver key type
[ 0.411414] Key type id_resolver registered
[ 0.411422] Key type id_legacy registered
[ 0.411443] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.411830] fuse init (API version 7.26)
[ 0.412753] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 0.423480] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.423776] io scheduler noop registered
[ 0.423788] io scheduler deadline registered
[ 0.424345] io scheduler cfq registered (default)
[ 0.424357] io scheduler mq-deadline registered
[ 0.424366] io scheduler kyber registered
[ 0.426376] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.427404] ------------[ cut here ]------------
[ 0.427444] WARNING: CPU: 0 PID: 1 at kernel/irq/chip.c:57 irq_set_chip+0xcc/0xdc
[ 0.427452] irqchip 44e07000.gpio is not pipeline-safe!
[ 0.427459] Modules linked in:
[ 0.427480] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.108-ti-xenomai-r143 #1xross
[ 0.427487] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 0.427493] I-pipe domain: Linux
[ 0.427535] [<c0110ad4>] (unwind_backtrace) from [<c010e098>] (show_stack+0x20/0x24)
[ 0.427552] [<c010e098>] (show_stack) from [<c0c3e7e4>] (dump_stack+0x24/0x28)
[ 0.427568] [<c0c3e7e4>] (dump_stack) from [<c013a780>] (warn+0xf4/0x10c)
[ 0.427582] [<c013a780>] (warn) from [<c013a7f0>] (warn_slowpath_fmt+0x58/0x74)
[ 0.427598] [<c013a7f0>] (warn_slowpath_fmt) from [<c0196554>] (irq_set_chip+0xcc/0xdc)
[ 0.427616] [<c0196554>] (irq_set_chip) from [<c0197870>] (irq_set_chip_and_handler_name+0x24/0x3c)
[ 0.427640] [<c0197870>] (irq_set_chip_and_handler_name) from [<c080a9e4>] (gpiochip_irq_map+0x50/0xc8)
[ 0.427657] [<c080a9e4>] (gpiochip_irq_map) from [<c019a380>] (irq_domain_associate+0x84/0x1f8)
[ 0.427671] [<c019a380>] (irq_domain_associate) from [<c019ad48>] (irq_create_mapping+0x144/0x1fc)
[ 0.427684] [<c019ad48>] (irq_create_mapping) from [<c080aa84>] (gpiochip_to_irq+0x28/0x58)
[ 0.427698] [<c080aa84>] (gpiochip_to_irq) from [<c0809e14>] (gpiod_to_irq+0x58/0x70)
[ 0.427717] [<c0809e14>] (gpiod_to_irq) from [<c0810af4>] (gpio_is_visible+0x8c/0xac)
[ 0.427741] [<c0810af4>] (gpio_is_visible) from [<c0392d10>] (internal_create_group+0xdc/0x30c)
[ 0.427758] [<c0392d10>] (internal_create_group) from [<c03933a0>] (sysfs_create_groups+0x54/0x90)
[ 0.427784] [<c03933a0>] (sysfs_create_groups) from [<c08c7630>] (device_add+0x4cc/0x614)
[ 0.427801] [<c08c7630>] (device_add) from [<c08c7948>] (device_create_groups_vargs+0xc4/0xd0)
[ 0.427816] [<c08c7948>] (device_create_groups_vargs) from [<c08c7a30>] (device_create_with_groups+0x44/0x60)
[ 0.427831] [<c08c7a30>] (device_create_with_groups) from [<c0811468>] (gpiod_export+0x178/0x39c)
[ 0.427845] [<c0811468>] (gpiod_export) from [<c080fce0>] (gpio_request_one+0x114/0x12c)
[ 0.427860] [<c080fce0>] (gpio_request_one) from [<c0809704>] (devm_gpio_request_one+0x58/0x90)
[ 0.427874] [<c0809704>] (devm_gpio_request_one) from [<c0811e28>] (gpio_of_helper_probe+0x19c/0x650)
[ 0.427895] [<c0811e28>] (gpio_of_helper_probe) from [<c08cd1b4>] (platform_drv_probe+0x60/0xbc)
[ 0.427909] [<c08cd1b4>] (platform_drv_probe) from [<c08cac14>] (driver_probe_device+0x298/0x47c)
[ 0.427923] [<c08cac14>] (driver_probe_device) from [<c08caf08>] (driver_attach+0x110/0x12c)
[ 0.427937] [<c08caf08>] (driver_attach) from [<c08c8634>] (bus_for_each_dev+0x70/0xd0)
[ 0.427952] [<c08c8634>] (bus_for_each_dev) from [<c08ca3b4>] (driver_attach+0x2c/0x30)
[ 0.427995] [<c08ca3b4>] (driver_attach) from [<c08c9d1c>] (bus_add_driver+0x1d0/0x274)
[ 0.428009] [<c08c9d1c>] (bus_add_driver) from [<c08cbcd4>] (driver_register+0x88/0x104)
[ 0.428023] [<c08cbcd4>] (driver_register) from [<c08cd0fc>] (platform_driver_register+0x50/0x58)
[ 0.428049] [<c08cd0fc>] (platform_driver_register) from [<c1245284>] (gpio_of_helper_driver_init+0x20/0x28)
[ 0.428067] [<c1245284>] (gpio_of_helper_driver_init) from [<c0101d70>] (do_one_initcall+0x64/0x19c)
[ 0.428087] [<c0101d70>] (do_one_initcall) from [<c1200f94>] (kernel_init_freeable+0x150/0x1ec)
[ 0.428106] [<c1200f94>] (kernel_init_freeable) from [<c0c55148>] (kernel_init+0x18/0x124)
[ 0.428126] [<c0c55148>] (kernel_init) from [<c0109918>] (ret_from_fork+0x18/0x24)
[ 0.428146] ---[ end trace a9189f1e9248918a ]---
[ 0.428752] gpio-of-helper ocp:cape-universal: ready
[ 0.432575] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.434220] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.437719] console [ttyS0] disabled
[ 0.437822] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 38, base_baud = 3000000) is a 8250
[ 0.449726] console [ttyS0] enabled
[ 0.453103] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.537710] libphy: Fixed MDIO Bus: probed
[ 0.596049] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 0.596081] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 0.596726] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 0.598510] libphy: 4a101000.mdio: probed
[ 0.598535] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.599714] cpsw 4a100000.ethernet: Detected MACID = b4:ac:9d:fa:a1:de
[ 0.599859] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 0.599871] cpsw 4a100000.ethernet: ALE Table size 1024
[ 0.599921] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 0.601115] mmc1: new high speed MMC card at address 0001
[ 0.604397] mmcblk1: mmc1:0001 MK2704 3.53 GiB
[ 0.608303] mmcblk1boot0: mmc1:0001 MK2704 partition 1 2.00 MiB
[ 0.608697] mmcblk1boot1: mmc1:0001 MK2704 partition 2 2.00 MiB
[ 0.609086] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.609137] ehci-platform: EHCI generic platform driver
[ 0.609527] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.610398] usbcore: registered new interface driver usb-storage
[ 0.612274] mmcblk1rpmb: mmc1:0001 MK2704 partition 3 512 KiB
[ 0.613971] mmcblk1: p1 p2
[ 0.618444] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.621857] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 0.626296] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.626341] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.626710] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.626724] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.626733] usb usb1: Product: MUSB HDRC host driver
[ 0.626742] usb usb1: Manufacturer: Linux 4.14.108-ti-xenomai-r143 musb-hcd
[ 0.626751] usb usb1: SerialNumber: musb-hdrc.1
[ 0.627625] hub 1-0:1.0: USB hub found
[ 0.627695] hub 1-0:1.0: 1 port detected
[ 0.637032] mousedev: PS/2 mouse device common for all mice
[ 0.639676] omap_rtc 44e3e000.rtc: registered as rtc0
[ 0.640855] i2c /dev entries driver
[ 0.642590] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.646164] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.646955] ashmem: initialized
[ 0.647392] remoteproc remoteproc0: wkup_m3 is available
[ 0.654632] NET: Registered protocol family 10
[ 0.656400] Segment Routing with IPv6
[ 0.656488] mip6: Mobile IPv6
[ 0.656509] NET: Registered protocol family 17
[ 0.656631] Key type dns_resolver registered
[ 0.656641] mpls_gso: MPLS GSO support
[ 0.656901] omap_voltage_late_init: Voltage driver support not added
[ 0.663809] PM: Cannot get wkup_m3_ipc handle
[ 0.668412] ThumbEE CPU extension supported.
[ 0.669433] registered taskstats version 1
[ 0.669565] zswap: loaded using pool lzo/zbud
[ 0.672260] Btrfs loaded, crc32c=crc32c-generic
[ 0.673554] Key type encrypted registered
[ 0.708037] random: fast init done
[ 0.718942] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 0.719529] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.720237] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.720323] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.721944] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[ 0.723787] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.724379] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.724796] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.725180] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.725244] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[ 0.727074] remoteproc remoteproc0: powering up wkup_m3
[ 0.727206] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 0.730670] PM: Cannot get wkup_m3_ipc handle
[ 0.735433] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 0.735458] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 0.736401] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 0.736416] of_cfs_init
[ 0.736548] of_cfs_init: OK
[ 0.737346] ALSA device list:
[ 0.737355] No soundcards found.
[ 0.749543] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.749649] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.750603] devtmpfs: mounted
[ 0.752259] Freeing unused kernel memory: 1024K
[ 1.013936] systemd[1]: System time before build time, advancing clock.
[ 1.044119] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.073193] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.098978] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.102569] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.115553] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.116662] systemd[1]: Detected architecture arm.
[ 1.117914] systemd[1]: Set hostname to <bela>.
[ 1.192900] usb 1-1: New USB device found, idVendor=0bda, idProduct=8179
[ 1.192919] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.192929] usb 1-1: Product: 802.11n NIC
[ 1.192938] usb 1-1: Manufacturer: Realtek
[ 1.192946] usb 1-1: SerialNumber: 00E04C0001
[ 1.195260] PM: bootloader does not support rtc-only!
[ 1.318370] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[ 1.735869] systemd[1]: Reached target Remote File Systems.
[ 1.737473] systemd[1]: Listening on udev Control Socket.
[ 1.739266] systemd[1]: Created slice System Slice.
[ 1.741204] systemd[1]: Created slice system-getty.slice.
[ 1.741687] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 1.742507] systemd[1]: Listening on Journal Audit Socket.
[ 1.742716] systemd[1]: Reached target Swap.
[ 2.083059] rtdm_pruss_irq: loading out-of-tree module taints kernel.
[ 2.083845] rtdm_pruss_irq version 2 loaded
[ 2.177864] usbcore: registered new interface driver snd-usb-audio
[ 2.869793] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 3.155014] systemd-journald[96]: Received request to flush runtime journal from PID 1
[ 5.865920] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 5.928844] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.990181] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 6.187803] usbcore: registered new interface driver r8188eu
[ 8.035858] using random self ethernet address
[ 8.035878] using random host ethernet address
[ 8.101501] using random self ethernet address
[ 8.101521] using random host ethernet address
[ 8.177749] Mass Storage Function, version: 2009/09/11
[ 8.177772] LUN: removable file: (no medium)
[ 9.737152] usb0: HOST MAC be:1a:9d:fa:a1:df
[ 9.737467] usb0: MAC be:1a:9d:fa:a1:e0
[ 9.742369] usb1: HOST MAC be:1a:9d:fa:a1:e2
[ 9.742734] usb1: MAC be:1a:9d:fa:a1:e3
[ 10.109539] configfs-gadget gadget: high-speed config #1: c
[ 10.719906] random: crng init done
[ 10.719930] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.268348] MAC Address = 98:48:27:5a:cd:0d
[ 11.275491] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.303227] net eth0: initializing cpsw version 1.12 (0)
[ 11.389614] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 11.414496] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.305651] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 85.686259] R8188EU: indicate disassoc
[ 85.986205] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
root@bela:~# lsmod | grep 88
r8188eu 454656 0
cfg80211 593920 1 r8188eu
root@bela:~#
Here is my output after following your suggested instructions! Any guidance is appreciated, I am very new to Bela and linux as a whole, and I feel very lost. Thank you for reading this far down. 🙂
