Jun 14 19:08:08 bela stdbuf[679]: Audio channels in use: 2
Jun 14 19:08:08 bela stdbuf[679]: Analog channels in use: 8
Jun 14 19:08:08 bela stdbuf[679]: Digital channels in use: 0
Jun 14 19:08:08 bela stdbuf[679]: The following MIDI devices are enabled:
Jun 14 19:08:08 bela stdbuf[679]: Num Name In Out Pd channels
Jun 14 19:08:08 bela stdbuf[679]: [ 0] hw:1,0,0 x x (1-16)
Jun 14 19:08:08 bela stdbuf[679]: bonk version 1.5
Jun 14 19:08:08 bela stdbuf[679]: fiddle version 1.1 TEST4
Jun 14 19:08:08 bela stdbuf[679]: pique 0.1 for PD version 23
Jun 14 19:08:08 bela stdbuf[679]: sigmund~ version 0.07
root@bela ~/Bela# dmesg | cat
[ 0.000000] Linux version 4.14.108-ti-xenomai-r135 (giulio@builder) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1xross PREEMPT Sat May 23 11:49:30 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c13d4bc8, node_mem_map dfb79000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x3c8 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[ 0.000000] Memory: 498272K/524288K available (12288K kernel code, 963K rwdata, 3616K rodata, 1024K init, 843K bss, 26016K reserved, 0K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1300000 (1024 kB)
.data : 0xc1300000 - 0xc13f0ce4 ( 964 kB)
.bss : 0xc13f2000 - 0xc14c4e5c ( 844 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000020] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000040] I-pipe, 24.000 MHz clocksource, wrap in 178956 ms
[ 0.000060] clocksource: ipipe_tsc: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000083] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000090] OMAP clocksource: timer1 at 24000000 Hz
[ 0.001610] timer_probe: no matching timers found
[ 0.001981] Interrupt pipeline (release #7)
[ 0.002316] Console: colour dummy device 80x30
[ 0.002369] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.022081] pid_max: default: 32768 minimum: 301
[ 0.022283] Security Framework initialized
[ 0.022299] Yama: becoming mindful.
[ 0.022343] AppArmor: AppArmor disabled by boot time parameter
[ 0.022414] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.022427] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.023443] CPU: Testing write buffer coherency: ok
[ 0.023512] CPU0: Spectre v2: using BPIALL workaround
[ 0.024487] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.024693] Hierarchical SRCU implementation.
[ 0.029181] devtmpfs: initialized
[ 0.048643] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 0.049121] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.049145] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.049503] xor: automatically using best checksumming function neon
[ 0.049517] pinctrl core: initialized pinctrl subsystem
[ 0.051625] NET: Registered protocol family 16
[ 0.053252] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.097388] omap_hwmod: debugss: _wait_target_disable failed
[ 0.146771] OMAP GPIO hardware version 0.1
[ 0.163041] No ATAGs?
[ 0.163064] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.175114] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.175128] raid6: .... xor() 0 MB/s, rmw enabled
[ 0.175137] raid6: using neon recovery algorithm
[ 0.184246] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.190189] SCSI subsystem initialized
[ 0.190518] usbcore: registered new interface driver usbfs
[ 0.190583] usbcore: registered new interface driver hub
[ 0.190752] usbcore: registered new device driver usb
[ 0.191462] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.191531] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.191579] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.191777] pps_core: LinuxPPS API ver. 1 registered
[ 0.191785] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.191816] PTP clock support registered
[ 0.192742] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.193505] Advanced Linux Sound Architecture Driver Initialized.
[ 0.194324] NetLabel: Initializing
[ 0.194336] NetLabel: domain hash size = 128
[ 0.194343] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.194445] NetLabel: unlabeled traffic allowed by default
[ 0.195062] clocksource: Switched to clocksource ipipe_tsc
[ 0.360406] VFS: Disk quotas dquot_6.6.0
[ 0.360513] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.374120] NET: Registered protocol family 2
[ 0.375030] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.375186] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.375227] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.375386] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.375406] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.375661] NET: Registered protocol family 1
[ 0.376423] RPC: Registered named UNIX socket transport module.
[ 0.376434] RPC: Registered udp transport module.
[ 0.376441] RPC: Registered tcp transport module.
[ 0.376447] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.377414] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.377545] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.379461] audit: initializing netlink subsys (disabled)
[ 0.380584] [Xenomai] scheduling class idle registered.
[ 0.380596] [Xenomai] scheduling class rt registered.
[ 0.380740] I-pipe: head domain Xenomai registered.
[ 0.382232] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.388501] [Xenomai] Cobalt v3.0.10 [DEBUG]
[ 0.388671] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.396171] zbud: loaded
[ 0.399639] NFS: Registering the id_resolver key type
[ 0.399688] Key type id_resolver registered
[ 0.399696] Key type id_legacy registered
[ 0.399717] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.400072] fuse init (API version 7.26)
[ 0.400738] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 0.411559] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.411860] io
scheduler noop registered
[ 0.411870] io scheduler deadline registered
[ 0.412271] io scheduler cfq registered (default)
[ 0.412282] io scheduler mq-deadline registered
[ 0.412291] io scheduler kyber registered
[ 0.414140] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.415754] ------------[ cut here ]------------
[ 0.415796] WARNING: CPU: 0 PID: 1 at kernel/irq/chip.c:57 irq_set_chip+0xcc/0xdc
[ 0.415804] irqchip 44e07000.gpio is not pipeline-safe!
[ 0.415812] Modules linked in:
[ 0.415833] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.108-ti-xenomai-r135 #1xross
[ 0.415840] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 0.415846] I-pipe domain: Linux
[ 0.415888] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[ 0.415905] [] (show_stack) from [] (dump_stack+0x24/0x28)
[ 0.415922] [] (dump_stack) from [] (__warn+0xf4/0x10c)
[ 0.415935] [] (__warn) from [] (warn_slowpath_fmt+0x58/0x74)
[ 0.415951] [] (warn_slowpath_fmt) from [] (irq_set_chip+0xcc/0xdc)
[ 0.415969] [] (irq_set_chip) from [] (irq_set_chip_and_handler_name+0x24/0x3c)
[ 0.415993] [] (irq_set_chip_and_handler_name) from [] (gpiochip_irq_map+0x50/0xc8)
[ 0.416009] [] (gpiochip_irq_map) from [] (irq_domain_associate+0x84/0x1f8)
[ 0.416023] [] (irq_domain_associate) from [] (irq_create_mapping+0x144/0x1fc)
[ 0.416036] [] (irq_create_mapping) from [] (gpiochip_to_irq+0x28/0x58)
[ 0.416050] [] (gpiochip_to_irq) from [] (gpiod_to_irq+0x58/0x70)
[ 0.416069] [] (gpiod_to_irq) from [] (gpio_is_visible+0x8c/0xac)
[ 0.416092] [] (gpio_is_visible) from [] (internal_create_group+0xdc/0x30c)
[ 0.416109] [] (internal_create_group) from [] (sysfs_create_groups+0x54/0x90)
[ 0.416134] [] (sysfs_create_groups) from [] (device_add+0x4d0/0x618)
[ 0.416151] [] (device_add) from [] (device_create_groups_vargs+0xc4/0xd0)
[ 0.416166] [] (device_create_groups_vargs) from [] (device_create_with_groups+0x44/0x60)
[ 0.416181] [] (device_create_with_groups) from [] (gpiod_export+0x178/0x398)
[ 0.416196] [] (gpiod_export) from [] (gpio_request_one+0x114/0x12c)
[ 0.416210] [] (gpio_request_one) from [] (devm_gpio_request_one+0x58/0x90)
[ 0.416224] [] (devm_gpio_request_one) from [] (gpio_of_helper_probe+0x19c/0x64c)
[ 0.416243] [] (gpio_of_helper_probe) from [] (platform_drv_probe+0x60/0xbc)
[ 0.416257] [] (platform_drv_probe) from [] (driver_probe_device+0x298/0x478)
[ 0.416271] [] (driver_probe_device) from [] (__driver_attach+0x110/0x12c)
[ 0.416286] [] (__driver_attach) from [] (bus_for_each_dev+0x70/0xd0)
[ 0.416300] [] (bus_for_each_dev) from [] (driver_attach+0x2c/0x30)
[ 0.416312] [] (driver_attach) from [] (bus_add_driver+0x1d0/0x274)
[ 0.416325] [] (bus_add_driver) from [] (driver_register+0x88/0x104)
[ 0.416338] [] (driver_register) from [] (__platform_driver_register+0x50/0x58)
[ 0.416367] [] (__platform_driver_register) from [] (gpio_of_helper_driver_init+0x20/0x28)
[ 0.416385] [] (gpio_of_helper_driver_init) from [] (do_one_initcall+0x64/0x19c)
[ 0.416407] [] (do_one_initcall) from [] (kernel_init_freeable+0x154/0x1f4)
[ 0.416425] [] (kernel_init_freeable) from [] (kernel_init+0x18/0x11c)
[ 0.416445] [] (kernel_init) from [] (ret_from_fork+0x18/0x24)
[ 0.416466] ---[ end trace f571251660ec7603 ]---
[ 0.416850] gpio-of-helper ocp:cape-u
niversal: ready
[ 0.420227] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.421697] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.425274] console [ttyS0] disabled
[ 0.425377] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 38, base_baud = 3000000) is a 8250
[ 0.437180] console [ttyS0] enabled
[ 0.440271] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.523426] libphy: Fixed MDIO Bus: probed
[ 0.579119] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 0.579136] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 0.579753] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 0.581713] libphy: 4a101000.mdio: probed
[ 0.581739] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.582745] cpsw 4a100000.ethernet: Detected MACID = 64:cf:d9:98:5b:c9
[ 0.582885] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 0.582895] cpsw 4a100000.ethernet: ALE Table size 1024
[ 0.582942] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 0.587393] mmc1: new high speed MMC card at address 0001
[ 0.590872] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.590919] ehci-platform: EHCI generic platform driver
[ 0.591473] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 0.592066] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.592886] usbcore: registered new interface driver usb-storage
[ 0.594487] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 0.594886] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 0.596733] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.597151] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB
[ 0.598805] mmcblk1: p1 p2
[ 0.604903] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 0.609290] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.609333] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.609691] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.609703] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.609712] usb usb1: Product: MUSB HDRC host driver
[ 0.609721] usb usb1: Manufacturer: Linux 4.14.108-ti-xenomai-r135 musb-hcd
[ 0.609730] usb usb1: SerialNumber: musb-hdrc.1
[ 0.610634] hub 1-0:1.0: USB hub found
[ 0.610713] hub 1-0:1.0: 1 port detected
[ 0.620022] mousedev: PS/2 mouse device common for all mice
[ 0.622636] omap_rtc 44e3e000.rtc: registered as rtc0
[ 0.623800] i2c /dev entries driver
[ 0.625447] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.628793] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.629560] ashmem: initialized
[ 0.629994] remoteproc remoteproc0: wkup_m3 is available
[ 0.636994] NET: Registered protocol family 10
[ 0.638529] Segment Routing with IPv6
[ 0.638614] mip6: Mobile IPv6
[ 0.638633] NET: Registered protocol family 17
[ 0.638765] Key type dns_resolver registered
[ 0.638774] mpls_gso: MPLS GSO support
[ 0.639043] omap_voltage_late_init: Voltage driver support not added
[ 0.646077] PM: Cannot get wkup_m3_ipc handle
[ 0.650730] ThumbEE CPU extension supported.
[ 0.651860] registered taskstats version 1
[ 0.651997] zswap: loaded using pool lzo/zbud
[ 0.654518] Btrfs loaded, crc32c=crc32c-generic
[ 0.656059] Key type encrypted registered
[ 0.691233] random: fast init done
[ 0.701547] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 0.702133] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.702645] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.702722] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.704467] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[ 0.706286] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.706676] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.707211] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.707625] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.707692] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[ 0.709261] remoteproc remoteproc0: powering up wkup_m3
[ 0.709288] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 0.709540] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 0.709564] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[ 0.715274] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,000C,2019BBBG0277'
[ 0.715308] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 0.743934] bone_capemgr bone_capemgr: slot #0: No cape found
[ 0.771282] bone_capemgr bone_capemgr: slot #1: No cape found
[ 0.800217] bone_capemgr bone_capemgr: slot #2: No cape found
[ 0.827563] bone_capemgr bone_capemgr: slot #3: No cape found
[ 0.827644] bone_capemgr bone_capemgr: initialized OK.
[ 0.832610] PM: bootloader does not support rtc-only!
[ 0.833315] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 0.833332] of_cfs_init
[ 0.833474] of_cfs_init: OK
[ 0.834244] ALSA device list:
[ 0.834254] No soundcards found.
[ 0.837546] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[ 0.837561] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[ 1.071134] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[ 1.220348] usb 1-1: New USB device found, idVendor=1c75, idProduct=0288
[ 1.220361] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.220371] usb 1-1: Product: Arturia KeyStep 32
[ 1.220379] usb 1-1: Manufacturer: Arturia
[ 1.220388] usb 1-1: SerialNumber: 00000000001A
[ 1.254928] EXT4-fs (mmcblk1p2): recovery complete
[ 1.256930] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.257036] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.258108] devtmpfs: mounted
[ 1.259701] Freeing unused kernel memory: 1024K
[ 1.517966] systemd[1]: System time before build time, advancing clock.
[ 1.570668] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.600600] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.604082] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.616805] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.617665] systemd[1]: Detected architecture arm.
[ 1.618972] systemd[1]: Set hostname to .
[ 1.778832] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[ 2.232936] systemd[1]: Listening on udev Kernel Socket.
[ 2.235691] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.236304] systemd[1]: Listening on Syslog Socket.
[ 2.236960] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.237480] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.237974] systemd[1]: Listening on udev Control Socket.
[ 2.240107] systemd[1]: Created slice User and Session Slice.
[ 2.373064] rtdm_pruss_irq: loading out-of-tree module taints kernel.
[ 2.373875] rtdm_pruss_irq version 2 loaded
[ 3.307350] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 4.093040] systemd-journald[101]: Received request to flush runtime journal from PID 1
[ 5.670847] rtdm_pruss_irq_open
[ 8.869188] usbcore: registered new interface driver snd-usb-audio
[ 9.132843] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 13.250180] musb-hdrc musb-hdrc.1: Babble
[ 13.255992] musb-hdrc musb-hdrc.1: Babble
[ 13.263201] usb 1-1: USB disconnect, device number 2
[ 13.323585] random: crng init done
[ 13.323604] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.691458] musb-hdrc musb-hdrc.1: Babble
[ 13.697229] musb-hdrc musb-hdrc.1: Babble
[ 13.719291] usb 1-1: new full-speed USB device number 3 using musb-hdrc
[ 14.385875] using random self ethernet address
[ 14.385896] using random host ethernet address
[ 14.580190] using random self ethernet address
[ 14.580211] using random host ethernet address
[ 14.589902] usb 1-1: New USB device found, idVendor=1c75, idProduct=0288
[ 14.589924] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 14.589934] usb 1-1: Product: Arturia KeyStep 32
[ 14.589943] usb 1-1: Manufacturer: Arturia
[ 14.589952] usb 1-1: SerialNumber: 00000000001A
[ 14.710886] Mass Storage Function, version: 2009/09/11
[ 14.710910] LUN: removable file: (no medium)
[ 17.649290] usb0: HOST MAC be:1a:d9:98:5b:ca
[ 17.656731] usb0: MAC be:1a:d9:98:5b:cb
[ 17.662238] usb1: HOST MAC be:1a:d9:98:5b:cd
[ 17.662631] usb1: MAC be:1a:d9:98:5b:ce
[ 18.882601] net eth0: initializing cpsw version 1.12 (0)
[ 18.972603] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 19.006780] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.161664] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 20.820752] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 60.893798] rtdm_pruss_irq_close
[ 62.552434] rtdm_pruss_irq_open
[ 376.301637] configfs-gadget gadget: high-speed config #1: c
[ 376.302242] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 378.876078] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 602.673865] rtdm_pruss_irq_close
[ 603.886552] rtdm_pruss_irq_open
