giuliomoro See if you have a folder in /root/_BelaUpdateBackup and how much space it takes:
will check.
giuliomoro it may be projects, project files, build files and any big wave audio files you may have in there.
well, that's why i checked the size of /root/Bela/projects/*...
that does not at all account for 3.4G of space..
and i shouldn't have any audio files on the EMMC, as i supposedly read everything from the sd card..
if i find the cause of the disk being full (and can remove what is taking up the space), i might even be able to run the Oled example without upgrading, as i think that is what went wrong trying to install that project as well.
thing is, upgrading is not the problem, it's the installed externals, going through the process of automounting the sd etc.. all that is working now, so i'm a bit reluctant to mess with it.
that would be in the pd-externals project, i believe. will double check.
folder_list is an external that's part of the HCS library. i installed that library (had to remove some elements of it that caused the install to fail), some things show up as .pd files, others don't. this one doesn't. it's the only thing in the lib i'm actually using..
