giuliomoro That's only for inputs though, not for outputs.
Oh interesting!
The wording on the product page is a bit ambiguous where it reads as you can use 64 additional I/O (so up to 64 outputs if you wanted, with the same sr caveat).
So you can do, potentially, up to 64 analog outs (@5V) with 22kHz sr, with only increases of inputs requiring the downsampling?
giuliomoro The J9 header carries differential, DC-coupled line outputs. These have a 1.8Vpp range, centred around 1.2V IIRC. On Pepper Rev B, a differential amplifier is used to obtain ±5V outputs from these. If you are not using Pepper, you could peruse its schematics to use as a starting point for a custom output frontend.
Very good to know as well. Although 44.1k is better than 22k, if it works out of the box that way, that'd obviously be easier as I could skip. faffing around with voltage scaling.
