giuliomoro i guess from
https://github.com/BelaPlatform/Bela/files/4431515/else-v1.0-beta27.zip
I have tried several times to delete my project and the "pd-externals" dummy project to make a "clean" install,
and every time Bela ask to replace or not the files, as if everything was still in place after deleting the "pd-externals" dummy project.
And because i have also try to manually upload objects (from my computer pd-externals library) in my project, could they are still there even after delete the project ?
It become foggy for me !
FatJak Or perhaps i don't understand which file you are speaking about ?
that seems to be the right question to the answer. Weird that you'd get SIGILL from it. Anyhow that's an old version so I'll build a newer one.
    So, just to confirm what I believe to understand, it's not possible to use Pd externals before your intervention ?
    Or there is other ways to use them ?
    one can build them for themselves and not wait for me, but build instructions may change for each external which is why I am building them on request. In the issue you linked to I provide build instructions for building ELSE so you may want to try rebuilding its latest version following those instructions and maybe it'll work for you.
      giuliomoro Ok, ... this is going to be brainly overloaded for me. I've already hundred questions to even begin to try. I'll try one day. Thanks !
      can you confirm whether the illegal instruction error still happens with the latest build of else?
